@fc352bf0a6929e9fa80f
Hey I just received the QS-Zigbee-D02-TRIAC-2C-LN today, and wired it up in a test harness on my desk.
It has the right model listed _TYZB01_v8gtiaed but when I installed it, it didn't create a child device for the second switch.
The way I installed it was to add the driver to my list of drivers, plugged in the module and the light started flashing (the physical switch was turned off), when I saw the light flashing I started the pairing mode and the device was added to the network.
I wouldn't think this would make a difference, but I only have 1 light connected to the module instead of 2. I wouldn't have expected the device + driver to be that smart that it would detect that I didn't connect a second light and not create the child devices.
Any help would be appreciate. Not sure what logs you might find useful. I didn't have the log opened up when I paired it anyway
edit:
actually I had more of a play around after enabling debug logging and found this issue:
[dev:79](http://192.168.1.5/logs#dev79)2021-01-23 00:34:21.786 [debug](http://192.168.1.5/device/edit/79)onSwitchLevel: Value=183 level=72
[dev:79](http://192.168.1.5/logs#dev79)2021-01-23 00:34:21.771 [debug](http://192.168.1.5/device/edit/79)onSwitchLevel: value=183
[dev:79](http://192.168.1.5/logs#dev79)2021-01-23 00:34:21.766 [debug](http://192.168.1.5/device/edit/79)Received parsed: [raw:9BAE01000808000020B7, dni:9BAE, endpoint:01, cluster:0008, size:08, attrId:0000, encoding:20, command:0A, value:B7, clusterInt:8, attrInt:0]
[dev:79](http://192.168.1.5/logs#dev79)2021-01-23 00:34:21.761 [info](http://192.168.1.5/device/edit/79)Received raw: read attr - raw: 9BAE01000808000020B7, dni: 9BAE, endpoint: 01, cluster: 0008, size: 08, attrId: 0000, encoding: 20, command: 0A, value: B7
[dev:79](http://192.168.1.5/logs#dev79)2021-01-23 00:34:15.731 [debug](http://192.168.1.5/device/edit/79)true Living Room Lights Living Room Lights 1
[dev:79](http://192.168.1.5/logs#dev79)2021-01-23 00:34:15.726 [debug](http://192.168.1.5/device/edit/79)Received parsed: [raw:9BAE0100060800001001, dni:9BAE, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0]
[dev:79](http://192.168.1.5/logs#dev79)2021-01-23 00:34:15.722 [info](http://192.168.1.5/device/edit/79)Received raw: read attr - raw: 9BAE0100060800001001, dni: 9BAE, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01
[dev:79](http://192.168.1.5/logs#dev79)2021-01-23 00:33:48.367 [debug](http://192.168.1.5/device/edit/79)true Living Room Lights Living Room Lights 0
[dev:79](http://192.168.1.5/logs#dev79)2021-01-23 00:33:48.362 [debug](http://192.168.1.5/device/edit/79)Received parsed: [raw:9BAE0100060800001000, dni:9BAE, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0]
[dev:79](http://192.168.1.5/logs#dev79)2021-01-23 00:33:48.358 [info](http://192.168.1.5/device/edit/79)Received raw: read attr - raw: 9BAE0100060800001000, dni: 9BAE, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00
[dev:79](http://192.168.1.5/logs#dev79)2021-01-23 00:33:43.660 [debug](http://192.168.1.5/device/edit/79)true Living Room Lights Living Room Lights 1
[dev:79](http://192.168.1.5/logs#dev79)2021-01-23 00:33:43.655 [debug](http://192.168.1.5/device/edit/79)Received parsed: [raw:9BAE0100060800001001, dni:9BAE, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0]
[dev:79](http://192.168.1.5/logs#dev79)2021-01-23 00:33:43.651 [info](http://192.168.1.5/device/edit/79)Received raw: read attr - raw: 9BAE0100060800001001, dni: 9BAE, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01
[dev:79](http://192.168.1.5/logs#dev79)2021-01-23 00:33:26.892 [debug](http://192.168.1.5/device/edit/79)true Living Room Lights Living Room Lights 0
[dev:79](http://192.168.1.5/logs#dev79)2021-01-23 00:33:26.884 [debug](http://192.168.1.5/device/edit/79)Received parsed: [raw:9BAE0100060800001000, dni:9BAE, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0]
[dev:79](http://192.168.1.5/logs#dev79)2021-01-23 00:33:26.880 [info](http://192.168.1.5/device/edit/79)Received raw: read attr - raw: 9BAE0100060800001000, dni: 9BAE, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00
[dev:79](http://192.168.1.5/logs#dev79)2021-01-23 00:33:11.752 [error](http://192.168.1.5/device/edit/79)com.hubitat.app.exception.UnknownDeviceTypeException: Device type 'Tuya Zigbee dimmer module V2' in namespace 'matthammonddotorg' not found on line 205 (updated)
[dev:79](http://192.168.1.5/logs#dev79)2021-01-23 00:33:11.711 [info](http://192.168.1.5/device/edit/79)Creating child 0 with dni 9BAE-01
[dev:79](http://192.168.1.5/logs#dev79)2021-01-23 00:33:11.700 [debug](http://192.168.1.5/device/edit/79){application=41, manufacturer=_TYZB01_v8gtiaed, model=TS110F}
[dev:79](http://192.168.1.5/logs#dev79)2021-01-23 00:33:11.666 [info](http://192.168.1.5/device/edit/79)updated parent->child
