[DEPRECATED] Kasa Plug, Switch, and Bulb integration
The node.js is for your raspberryPI and not for HE.
Ah, so TP-Link only works with a pi added to the setup?
If you want only local TP-Link execution and not rely on any cloud components.
ok, I'm ok with cloud on these lights, I've got the driver installed, how do i get it cloud connected?
Just follow the instructions in the HE app you installed. It covers both cloud and local.
Ah I see, have now installed this one https://raw.githubusercontent.com/DaveGut/Hubitat-TP-Link-Devices/master/Service%20Manager/TP-Link%20Hubitat%20Manager.groovy
Thanks :slight_smile:
ok, followed the instructions, it discovered the 3 plugs and i installed them but they don't appear in devices?
Did you install all of the Device handlers?
No, i had only done the one i thought it was but clearly i was wrong. I added them all and now we're golden :slight_smile:
Thank you @aaron
I just installed an HS105 and it all worked as it's supposed to. But I did need to apply a little guesswork as to which device handler was the right one. (Chose Plug-Switch over Multi-Plug and I was right.)
Thanks @djgutheinz !
@djgutheinz
I am ready to move to your node.js code and wanted to know what I need to do to transition my TP-Link devices from cloud over to local. I didn't see anything on the readme on your GitHub. So any guidance is appreciated!
It will currently require a full re-install to the latest version (see last part of this post). If you have a lot of devices - a bummer. I have to you want applet installation instructions.
I created this morning applet installation instructions for Windows, Android, and Fire devices. Installation on Raspberry Pi and MAC are beyond my experience. See next post.
If someone has instructions, I would be happy to steal for inclusion in the baseline.
Future consideration (on-request): An App and Driver version that allows switching from Hub <-> Cloud (both directions) as desired. This would work even on older versions by updating App and Driver and running app. Will take about a day to create/test.
Install Instructions for the TP-LinkHub_v3.js applet onto Windows, Android, add Fire tablet.
So what are you using outside of node.js for libraries. Maybe I can help with the Raspi. Can you send URLs of those added libraries?
Ignorant here of what you mean. The only time I use node.js is for the Hubitat and SmartThings integrations and I did not need special libraries for that script.
In your instructions you state to download servers ultimate pro and servers ultimate pro f. Hence why I am asking what libraries are you using. :grin:
These are both downloaded from Google Play or the Fire App Store. Do not know for IOS devices. Updated instruction (this was also in the first paragraph).
I am currently updating handlers and and application. One focus is to allow the auto-switch over. May take a day or so, but hope to finish by tomorrow.
Dave
Developing UDP version.
I am suspending all version 3.x development at the just released beta. I have found a way to make the UDP work so that devices can be controlled without either a node.js hub nor a Kasa Account (single install for all devices). I have to port some node.js code over to groovy for (1) discovery, and (2) encryption (done previously). After that, we will have a Version 4 app and driver set.
@djgutheinz
So I suspect you are pretty much going to abandon the Node.JS after this latest findings correct? Your development is freaky-fast! Do you work at JimmyJohns?
No. 70 YO retiree with no life. And you are correct. For Hubitat, if I get a good UDP implementation then the Node Applet is OBE - not abandoned.
