Updated and all my comms errors have disappeared AND hub has gained in speed. Much appreciated!
Hi, Dave. Would you please look at this and tell me what I'm doing wrong?
Every five minutes:
And if I hit the on or off from the device:
Thanks for your time and talents.
EDIT: With trace logging:
Just upgraded? What I am seeing indicates you may not have followed the upgrade instructions (on gitHub readme.md shown on main page):
- Replace the contents of the existing driver and application.
- Run the application (this will update the required data elements.
- Test a sampling of devices.
What I need to know to continue:
- Version upgraded from (best of your recollection). I assume it is 3.x or earlier from the checkError running every 5 minutes (used on old version in the Smart App.
- Confirmation you upgraded both the Application and Drivers per the instructions above.
- Did you run the Application at least once?
Appreciate the help. I'll try to answer as best I can. I don't know the previous version, but here's what I have now.
I've tried running the app, but it doesn't find any devices. I checked via the official Kasa app and it does see and correctly control, including status, the device. Interestingly, using your DH, the on/off functionality works, but it does not correctly see the status.
Please advise. Thank you!
So... Never mind.
I realized I was using the wrong driver. The plug is an HS105 and the right driver is the Plug Switch but I was using the Multi Plug. It's working just fine, now.
Although, I still don't know why the app doesn't see the device.
Glad you are up and running. Mistakes are allowed!
The app will not see the device since it is already installed. Although not required, I use the method of only displaying devices that are not already children. Makes the interface make more sense (to this old man).
Dave
Hello Dave,
I have two HS110 plugs and both of them are showing this error log.
2019-03-18 08:53:37.336 pm [error] java.lang.NullPointerException: Cannot get property 'get_monthstat' on null object on line 183 (energyThisMonthResponse)
Living 4.2.01 LED Living: Power is 0 Watts.
Living 4.2.01 LED Living: Power: off
Apps and drivers are on V4.2 Thanks!
Hey @djgutheinz,
FYI, like @KVHubitat, I'm seeing this error using a HS110 with both App and Driver (TP-Link Engr Mon Plug) on v4.2.01, however it's being listed as line 207 in the log but it's otherwise functioning well...
dev:9302019-03-19 07:49:34.225 pm errorjava.lang.NullPointerException: Cannot get property 'get_monthstat' on null object on line 207 (energyThisMonthResponse)
dev:9302019-03-19 07:49:34.081 pm infoTP-Link Outlet #1 4.2.01 TP-Link Outlet #1: Power is 0 Watts.
dev:9302019-03-19 07:49:33.967 pm infoTP-Link Outlet #1 4.2.01 TP-Link Outlet #1: Power: on
dev:9302019-03-19 07:49:19.925 pm errorjava.lang.NullPointerException: Cannot get property 'get_monthstat' on null object on line 207 (energyThisMonthResponse)
dev:9302019-03-19 07:49:19.824 pm infoTP-Link Outlet #1 4.2.01 TP-Link Outlet #1: Power is 5.809 Watts.
dev:9302019-03-19 07:49:19.708 pm infoTP-Link Outlet #1 4.2.01 TP-Link Outlet #1: Power: off
Cheers,
Nic
Fixed and uploaded. NEED your response on if it works (do not need logs if it works). I do not have a HS110.
I believe I found and corrected the error. I used the incorrect preamble for the return data in two places (used bulb preamble vice plug).
Dave
Hello Dave,
This is the new error message.
[error]java.lang.NullPointerException: Cannot get property 'energy' on null object on line 214 (energyThisMonthResponse)
Indulge me for a while. I do not have a HS110. Updated driver on GitHub. It will now log a return data I need to see. It will be preambled with "SPECIAL LOG MESSAGE LINE 185:".
PS - where are you located? I assume US (I need to know this since the Australian version uses a different data structure).
US
[dev:170]2019-03-19 11:18:07.197 am [error]java.lang.NullPointerException: Cannot get property 'energy' on null object on line 211 (energyThisMonthResponse)
[dev:170]2019-03-19 11:18:06.978 am [info]Living 4.2.02 Living: Power is 63.825737 Watts.
[dev:170]2019-03-19 11:18:06.957 am [error]SPECIAL LOG MESSAGE LINE 185: cmdResponse = [emeter:[get_realtime:[current:0.905803, total:3.741000, err_code:0, power:63.825737, voltage:125.458749]]]
[dev:170]2019-03-19 11:18:06.830 am [info]Living 4.2.02 Living: Power: off
Quick try:
Try doing an Save Preferences from the device's GitHub page (where you can also set refresh rate).
Dave,
I’m in Australia. Lol
I’ll update, test and report.
Dave after updating JUST the driver and hitting Save Preferences, I get this in the logs now.
Also when plug is ON Power is not displayed BUT when plug is OFF power is shown.
There was a newer test driver on GitHub. Could you
Load the new driver.
SAVE PREFERENCES
Run the device and capture log.
Thanks.
I love Australia. Spent 1 year in Melbourne working with BAE.
turn on traceLog in preferences. I need to see what is happening before the error.
Is this the best format to post logs ??
dev:3542019-03-20 08:16:59.036 am debugcondition: 1240 | condition text: Light rain shower | condition factor: 0.8 | lux: 1730
dev:3542019-03-20 08:16:59.032 am debugbetween sunrise and noon
dev:9302019-03-20 08:16:51.984 am errorjava.lang.NullPointerException: Cannot get property 'energy_wh' on null object on line 208 (energyThisMonthResponse)
dev:9302019-03-20 08:16:51.955 am traceTP-Link Outlet #1 4.2.02 energyThisMonthResponse: cmdResponse = [emeter:[get_monthstat:[month_list:, err_code:0]]]
dev:9302019-03-20 08:16:51.951 am traceTP-Link Outlet #1 4.2.02 parseInput: response = [emeter:[get_monthstat:[month_list:, err_code:0]]]
dev:9302019-03-20 08:16:51.948 am traceTP-Link Outlet #1 4.2.02 inputXOR: cmdResponse = {"emeter":{"get_monthstat":{"month_list":,"err_code":0}}}
dev:9302019-03-20 08:16:51.847 am traceTP-Link Outlet #1 4.2.02 sendCmd: command = {"emeter":{"get_monthstat":{"year": null}}} // device IP = 192.168.1.6
dev:9302019-03-20 08:16:51.846 am traceTP-Link Outlet #1 4.2.02 getEnergyThisMonth: month = 3 / year = 2019
dev:9302019-03-20 08:16:51.844 am infoTP-Link Outlet #1 4.2.02 TP-Link Outlet #1: Power is 5.626 Watts.
dev:9302019-03-20 08:16:51.830 am errorSPECIAL LOG MESSAGE LINE 185: cmdResponse = [emeter:[get_realtime:[voltage_mv:242424, power_mw:5626, err_code:0, total_wh:142, current_ma:49]]]
dev:9302019-03-20 08:16:51.828 am traceTP-Link Outlet #1 4.2.02 powerResponse: cmdResponse = [emeter:[get_realtime:[voltage_mv:242424, power_mw:5626, err_code:0, total_wh:142, current_ma:49]]]
dev:9302019-03-20 08:16:51.825 am traceTP-Link Outlet #1 4.2.02 parseInput: response = [emeter:[get_realtime:[voltage_mv:242424, power_mw:5626, err_code:0, total_wh:142, current_ma:49]]]
dev:9302019-03-20 08:16:51.822 am traceTP-Link Outlet #1 4.2.02 inputXOR: cmdResponse = {"emeter":{"get_realtime":{"voltage_mv":242424,"current_ma":49,"power_mw":5626,"total_wh":142,"err_code":0}}}
dev:9302019-03-20 08:16:51.729 am infoTP-Link Outlet #1 4.2.02 TP-Link Outlet #1: Power: off
dev:9302019-03-20 08:16:51.703 am traceTP-Link Outlet #1 4.2.02 sendCmd: command = {"emeter":{"get_realtime":{}}} // device IP = 192.168.1.6
dev:9302019-03-20 08:16:51.701 am traceTP-Link Outlet #1 4.2.02 getPower
dev:9302019-03-20 08:16:51.700 am traceTP-Link Outlet #1 4.2.02 parseInput: response = [system:[get_sysinfo:[dev_name:Smart Wi-Fi Plug With Energy Monitoring, hw_ver:2.0, rssi:-41, latitude_i:-339337, err_code:0, type:IOT.SMARTPLUGSWITCH, longitude_i:1512426, deviceId:8006B44052AC733A105F7D33B1DA13FB1A04618A, mac:AC:84:C6:54:A3:B9, active_mode:none, icon_hash:, updating:0, led_off:0, on_time:0, feature:TIM:ENE, relay_state:0, alias:TP-Link Outlet #1, oemId:6480C2101948463DC65D7009CAECDECC, model:HS110(AU), hwId:A28C8BB92AFCB6CAFB83A8C00145F7E2, fwId:00000000000000000000000000000000, sw_ver:1.5.2 Build 171201 Rel.084625]]]
dev:9302019-03-20 08:16:51.694 am traceTP-Link Outlet #1 4.2.02 inputXOR: cmdResponse = {"system":{"get_sysinfo":{"sw_ver":"1.5.2 Build 171201 Rel.084625","hw_ver":"2.0","type":"IOT.SMARTPLUGSWITCH","model":"HS110(AU)","mac":"AC:84:C6:54:A3:B9","dev_name":"Smart Wi-Fi Plug With Energy Monitoring","alias":"TP-Link Outlet #1","relay_state":0,"on_time":0,"active_mode":"none","feature":"TIM:ENE","updating":0,"icon_hash":"","rssi":-41,"led_off":0,"longitude_i":1512426,"latitude_i":-339337,"hwId":"A28C8BB92AFCB6CAFB83A8C00145F7E2","fwId":"00000000000000000000000000000000","deviceId":"8006B44052AC733A105F7D33B1DA13FB1A04618A","oemId":"6480C2101948463DC65D7009CAECDECC","err_code":0}}}
dev:9302019-03-20 08:16:51.658 am traceTP-Link Outlet #1 4.2.02 refreshResponse: response = index:00, mac:AC84C654A3B9, ip:c0a80106, port:270f, type:LAN_TYPE_UDPCLIENT, payload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
dev:9302019-03-20 08:16:51.609 am traceTP-Link Outlet #1 4.2.02 sendCmd: command = {"system" :{"get_sysinfo" :{}}} // device IP = 192.168.1.6
dev:9302019-03-20 08:16:51.588 am traceTP-Link Outlet #1 4.2.02 commandResponse: response = index:00, mac:AC84C654A3B9, ip:c0a80106, port:270f, type:LAN_TYPE_UDPCLIENT, payload:D0F281F88BFF9AF7D5EF94B6C5A0D48BF99CF091E8B7C4B0D1A5C0E2D8A381E496E4BBD8B7D3B694AE9EE39EE3
dev:9302019-03-20 08:16:51.555 am traceTP-Link Outlet #1 4.2.02 sendCmd: command = {"system" :{"set_relay_state" :{"state" : 0}}} // device IP = 192.168.1.6
dev:9302019-03-20 08:16:51.549 am traceTP-Link Outlet #1 4.2.02 off
dev:9302019-03-20 08:16:29.920 am errorjava.lang.NullPointerException: Cannot get property 'energy_wh' on null object on line 208 (energyThisMonthResponse)
dev:9302019-03-20 08:16:29.888 am traceTP-Link Outlet #1 4.2.02 energyThisMonthResponse: cmdResponse = [emeter:[get_monthstat:[month_list:, err_code:0]]]
dev:9302019-03-20 08:16:29.885 am traceTP-Link Outlet #1 4.2.02 parseInput: response = [emeter:[get_monthstat:[month_list:, err_code:0]]]
dev:9302019-03-20 08:16:29.878 am traceTP-Link Outlet #1 4.2.02 inputXOR: cmdResponse = {"emeter":{"get_monthstat":{"month_list":,"err_code":0}}}
dev:9302019-03-20 08:16:29.804 am traceTP-Link Outlet #1 4.2.02 sendCmd: command = {"emeter":{"get_monthstat":{"year": null}}} // device IP = 192.168.1.6
dev:9302019-03-20 08:16:29.801 am traceTP-Link Outlet #1 4.2.02 getEnergyThisMonth: month = 3 / year = 2019
dev:9302019-03-20 08:16:29.799 am infoTP-Link Outlet #1 4.2.02 TP-Link Outlet #1: Power is 0 Watts.
dev:9302019-03-20 08:16:29.787 am errorSPECIAL LOG MESSAGE LINE 185: cmdResponse = [emeter:[get_realtime:[voltage_mv:242049, power_mw:0, err_code:0, total_wh:142, current_ma:26]]]
dev:9302019-03-20 08:16:29.786 am traceTP-Link Outlet #1 4.2.02 powerResponse: cmdResponse = [emeter:[get_realtime:[voltage_mv:242049, power_mw:0, err_code:0, total_wh:142, current_ma:26]]]
dev:9302019-03-20 08:16:29.785 am traceTP-Link Outlet #1 4.2.02 parseInput: response = [emeter:[get_realtime:[voltage_mv:242049, power_mw:0, err_code:0, total_wh:142, current_ma:26]]]
dev:9302019-03-20 08:16:29.784 am traceTP-Link Outlet #1 4.2.02 inputXOR: cmdResponse = {"emeter":{"get_realtime":{"voltage_mv":242049,"current_ma":26,"power_mw":0,"total_wh":142,"err_code":0}}}
dev:9302019-03-20 08:16:29.684 am infoTP-Link Outlet #1 4.2.02 TP-Link Outlet #1: Power: on
dev:9302019-03-20 08:16:29.657 am traceTP-Link Outlet #1 4.2.02 sendCmd: command = {"emeter":{"get_realtime":{}}} // device IP = 192.168.1.6
dev:9302019-03-20 08:16:29.654 am traceTP-Link Outlet #1 4.2.02 getPower
dev:9302019-03-20 08:16:29.652 am traceTP-Link Outlet #1 4.2.02 parseInput: response = [system:[get_sysinfo:[dev_name:Smart Wi-Fi Plug With Energy Monitoring, hw_ver:2.0, rssi:-41, latitude_i:-339337, err_code:0, type:IOT.SMARTPLUGSWITCH, longitude_i:1512426, deviceId:8006B44052AC733A105F7D33B1DA13FB1A04618A, mac:AC:84:C6:54:A3:B9, active_mode:none, icon_hash:, updating:0, led_off:0, on_time:0, feature:TIM:ENE, relay_state:1, alias:TP-Link Outlet #1, oemId:6480C2101948463DC65D7009CAECDECC, model:HS110(AU), hwId:A28C8BB92AFCB6CAFB83A8C00145F7E2, fwId:00000000000000000000000000000000, sw_ver:1.5.2 Build 171201 Rel.084625]]]
dev:9302019-03-20 08:16:29.646 am traceTP-Link Outlet #1 4.2.02 inputXOR: cmdResponse = {"system":{"get_sysinfo":{"sw_ver":"1.5.2 Build 171201 Rel.084625","hw_ver":"2.0","type":"IOT.SMARTPLUGSWITCH","model":"HS110(AU)","mac":"AC:84:C6:54:A3:B9","dev_name":"Smart Wi-Fi Plug With Energy Monitoring","alias":"TP-Link Outlet #1","relay_state":1,"on_time":0,"active_mode":"none","feature":"TIM:ENE","updating":0,"icon_hash":"","rssi":-41,"led_off":0,"longitude_i":1512426,"latitude_i":-339337,"hwId":"A28C8BB92AFCB6CAFB83A8C00145F7E2","fwId":"00000000000000000000000000000000","deviceId":"8006B44052AC733A105F7D33B1DA13FB1A04618A","oemId":"6480C2101948463DC65D7009CAECDECC","err_code":0}}}
dev:9302019-03-20 08:16:29.574 am traceTP-Link Outlet #1 4.2.02 refreshResponse: response = index:00, mac:AC84C654A3B9, ip:c0a80106, port:270f, type:LAN_TYPE_UDPCLIENT, payload:D0F281F88BFF9AF7D5EF94B6D1B4C09FEC95E68FE187E8CAF08BA9DAADF284E193B18BA998B683AD9FBFFD88E18DE9C9F8CFFECCFCCDEDBFDAB698A890A492A095B79BB9D1A6F98FEA98BA80A290BE8EAC80A2D6AFDFBA98A280C986D2FCAFE2A3F1A5F5B9ECABF8AFE6B2F1B99BB795F897F396FAD8E2C088DBEADBEBC382D7FEDCF0D2BFDEBD9FA587C685BF87B389CAFCC6F3C7FDBC8FB5F7CEECC0E286E395CAA4C5A8CDEFD5F7A4C9A8DAAE8ED9B09DDBB292C2AEDBBC9CCBA2D6BE9EDBB5D0A2C5BC9CD1BED0B9CDA2D0B9D7B092BE9CFD91F899EAC8F2D084D4F9B5DCB2D9F9B6C3B7DBBECAEAC9F8DAF6D4A6C3AFCEB7E89BEF8EFA9FBD87B69AB8D7B9E692FB96F3D1EBDBF7D5B4D7A3CABCD986EB84E085A79DBFD1BED0B597BB99FF9AFB8FFA88EDCFF5D783CA87BDF8B6F3D1FDDFAADABEDFABC2ACCBE9D3E3CFED84E788E6B9D1B0C3AB89B391B39FBDCFBCCFA684BE93A796BA98F491F5AAC5A3C5E7DDEDC1E38FE08EE980F481E580DFB694AE9FAA9BA99DAF99B597FB9AEE87F386E287D8B193A984B784BD8EBD8AA684EC9BD2B694AE8CCDFFC784BCFEBC85B7F6B0F3B187C485C381B98ACBF3B080B081B580C6F1B486A488AACCBBF296B48EAC9CAC9CAC9CAC9CAC9CAC9CAC9CAC9CAC9CAC9CAC9CAC9CAC9CAC9CAC9CAC9CAC8EA280E481F79EFD98D1B597AD8FB787B781C3F7C3F3C6F4B5F6C1F2C180B181B4F2C581B281C3F2B6F7C6F5B3F1C081B185B382BAFBD9F5D7B8DDB0F99DBF85A791A59DADEEDCEDDDECD5E1D9EDDBE8ACEFD9ECA89FAF9FA6E5A4E1A2E6A3E0A381AD8FEA98EAB5D6B9DDB89AA090ED90ED
dev:9302019-03-20 08:16:29.510 am traceTP-Link Outlet #1 4.2.02 sendCmd: command = {"system" :{"get_sysinfo" :{}}} // device IP = 192.168.1.6
dev:9302019-03-20 08:16:29.466 am traceTP-Link Outlet #1 4.2.02 commandResponse: response = index:00, mac:AC84C654A3B9, ip:c0a80106, port:270f, type:LAN_TYPE_UDPCLIENT, payload:D0F281F88BFF9AF7D5EF94B6C5A0D48BF99CF091E8B7C4B0D1A5C0E2D8A381E496E4BBD8B7D3B694AE9EE39EE3
dev:9302019-03-20 08:16:29.431 am traceTP-Link Outlet #1 4.2.02 sendCmd: command = {"system" :{"set_relay_state" :{"state" : 1}}} // device IP = 192.168.1.6
dev:9302019-03-20 08:16:29.425 am traceTP-Link Outlet #1 4.2.02 on
dev:9302019-03-20 08:16:25.020 am errorjava.lang.NullPointerException: Cannot get property 'year' on null object on line 234 (energyStatResponse)
dev:9302019-03-20 08:16:25.007 am traceTP-Link Outlet #1 4.2.02 energyStatResponse: cmdResponse = [emeter:[get_monthstat:[month_list:, err_code:0]]]
dev:9302019-03-20 08:16:25.006 am traceTP-Link Outlet #1 4.2.02 parseInput: response = [emeter:[get_monthstat:[month_list:, err_code:0]]]
dev:9302019-03-20 08:16:25.003 am traceTP-Link Outlet #1 4.2.02 inputXOR: cmdResponse = {"emeter":{"get_monthstat":{"month_list":,"err_code":0}}}
dev:9302019-03-20 08:16:24.964 am traceTP-Link Outlet #1 4.2.02 sendCmd: command = {"emeter":{"get_monthstat":{"year": 2018}}} // device IP = 192.168.1.6
dev:9302019-03-20 08:16:24.963 am traceTP-Link Outlet #1 4.2.02 getPrevYear: year = 2018
dev:9302019-03-20 08:16:24.961 am traceTP-Link Outlet #1 4.2.02 energyStatResponse: cmdResponse = [emeter:[get_monthstat:[month_list:[[month:1, year:2019, energy_wh:3737], [month:2, year:2019, energy_wh:1910], [month:3, year:2019, energy_wh:142]], err_code:0]]]
dev:9302019-03-20 08:16:24.960 am traceTP-Link Outlet #1 4.2.02 parseInput: response = [emeter:[get_monthstat:[month_list:[[month:1, year:2019, energy_wh:3737], [month:2, year:2019, energy_wh:1910], [month:3, year:2019, energy_wh:142]], err_code:0]]]
dev:9302019-03-20 08:16:24.954 am traceTP-Link Outlet #1 4.2.02 inputXOR: cmdResponse = {"emeter":{"get_monthstat":{"month_list":[{"year":2019,"month":1,"energy_wh":3737},{"year":2019,"month":2,"energy_wh":1910},{"year":2019,"month":3,"energy_wh":142}],"err_code":0}}}
dev:9302019-03-20 08:16:24.896 am traceTP-Link Outlet #1 4.2.02 sendCmd: command = {"emeter":{"get_monthstat":{"year": 2019}}} // device IP = 192.168.1.6
dev:9302019-03-20 08:16:24.884 am traceTP-Link Outlet #1 4.2.02 getEnergyStats: year = 2019
dev:9302019-03-20 08:16:22.144 am errorjava.lang.NullPointerException: Cannot get property 'energy_wh' on null object on line 208 (energyThisMonthResponse)
dev:9302019-03-20 08:16:22.134 am traceTP-Link Outlet #1 4.2.02 energyThisMonthResponse: cmdResponse = [emeter:[get_monthstat:[month_list:, err_code:0]]]
dev:9302019-03-20 08:16:22.133 am traceTP-Link Outlet #1 4.2.02 parseInput: response = [emeter:[get_monthstat:[month_list:, err_code:0]]]
dev:9302019-03-20 08:16:22.132 am traceTP-Link Outlet #1 4.2.02 inputXOR: cmdResponse = {"emeter":{"get_monthstat":{"month_list":,"err_code":0}}}
dev:9302019-03-20 08:16:22.103 am traceTP-Link Outlet #1 4.2.02 sendCmd: command = {"emeter":{"get_monthstat":{"year": null}}} // device IP = 192.168.1.6
dev:9302019-03-20 08:16:22.101 am traceTP-Link Outlet #1 4.2.02 getEnergyThisMonth: month = 3 / year = 2019
dev:9302019-03-20 08:16:22.092 am infoTP-Link Outlet #1 4.2.02 TP-Link Outlet #1: Power is 0 Watts.
dev:9302019-03-20 08:16:22.088 am errorSPECIAL LOG MESSAGE LINE 185: cmdResponse = [emeter:[get_realtime:[voltage_mv:241680, power_mw:0, err_code:0, total_wh:142, current_ma:26]]]
dev:9302019-03-20 08:16:22.087 am traceTP-Link Outlet #1 4.2.02 powerResponse: cmdResponse = [emeter:[get_realtime:[voltage_mv:241680, power_mw:0, err_code:0, total_wh:142, current_ma:26]]]
dev:9302019-03-20 08:16:22.085 am traceTP-Link Outlet #1 4.2.02 parseInput: response = [emeter:[get_realtime:[voltage_mv:241680, power_mw:0, err_code:0, total_wh:142, current_ma:26]]]
dev:9302019-03-20 08:16:22.083 am traceTP-Link Outlet #1 4.2.02 inputXOR: cmdResponse = {"emeter":{"get_realtime":{"voltage_mv":241680,"current_ma":26,"power_mw":0,"total_wh":142,"err_code":0}}}
dev:9302019-03-20 08:16:22.012 am infoTP-Link Outlet #1 4.2.02 TP-Link Outlet #1: Power: off
dev:9302019-03-20 08:16:22.005 am traceTP-Link Outlet #1 4.2.02 sendCmd: command = {"emeter":{"get_realtime":{}}} // device IP = 192.168.1.6
dev:9302019-03-20 08:16:22.004 am traceTP-Link Outlet #1 4.2.02 getPower
dev:9302019-03-20 08:16:22.002 am traceTP-Link Outlet #1 4.2.02 parseInput: response = [system:[get_sysinfo:[dev_name:Smart Wi-Fi Plug With Energy Monitoring, hw_ver:2.0, rssi:-41, latitude_i:-339337, err_code:0, type:IOT.SMARTPLUGSWITCH, longitude_i:1512426, deviceId:8006B44052AC733A105F7D33B1DA13FB1A04618A, mac:AC:84:C6:54:A3:B9, active_mode:none, icon_hash:, updating:0, led_off:0, on_time:0, feature:TIM:ENE, relay_state:0, alias:TP-Link Outlet #1, oemId:6480C2101948463DC65D7009CAECDECC, model:HS110(AU), hwId:A28C8BB92AFCB6CAFB83A8C00145F7E2, fwId:00000000000000000000000000000000, sw_ver:1.5.2 Build 171201 Rel.084625]]]
dev:9302019-03-20 08:16:21.998 am traceTP-Link Outlet #1 4.2.02 inputXOR: cmdResponse = {"system":{"get_sysinfo":{"sw_ver":"1.5.2 Build 171201 Rel.084625","hw_ver":"2.0","type":"IOT.SMARTPLUGSWITCH","model":"HS110(AU)","mac":"AC:84:C6:54:A3:B9","dev_name":"Smart Wi-Fi Plug With Energy Monitoring","alias":"TP-Link Outlet #1","relay_state":0,"on_time":0,"active_mode":"none","feature":"TIM:ENE","updating":0,"icon_hash":"","rssi":-41,"led_off":0,"longitude_i":1512426,"latitude_i":-339337,"hwId":"A28C8BB92AFCB6CAFB83A8C00145F7E2","fwId":"00000000000000000000000000000000","deviceId":"8006B44052AC733A105F7D33B1DA13FB1A04618A","oemId":"6480C2101948463DC65D7009CAECDECC","err_code":0}}}
dev:9302019-03-20 08:16:21.915 am traceTP-Link Outlet #1 4.2.02 refreshResponse: response = index:00, mac:AC84C654A3B9, ip:c0a80106, port:270f, type:LAN_TYPE_UDPCLIENT, payload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
dev:9302019-03-20 08:16:21.877 am traceTP-Link Outlet #1 4.2.02 sendCmd: command = {"system" :{"get_sysinfo" :{}}} // device IP = 192.168.1.6
dev:9302019-03-20 08:16:19.901 am traceTP-Link Outlet #1 4.2.02 currentDateResponse: cmdResponse = [time:[get_time:[sec:19, min:16, month:3, hour:8, year:2019, err_code:0, mday:20]]]
dev:9302019-03-20 08:16:19.900 am traceTP-Link Outlet #1 4.2.02 parseInput: response = [time:[get_time:[sec:19, min:16, month:3, hour:8, year:2019, err_code:0, mday:20]]]
dev:9302019-03-20 08:16:19.899 am traceTP-Link Outlet #1 4.2.02 inputXOR: cmdResponse = {"time":{"get_time":{"year":2019,"month":3,"mday":20,"hour":8,"min":16,"sec":19,"err_code":0}}}
dev:9302019-03-20 08:16:19.848 am traceTP-Link Outlet #1 4.2.02 sendCmd: command = {"time":{"get_time":null}} // device IP = 192.168.1.6
dev:9302019-03-20 08:16:19.771 am infoUpdating .............
Blockquote
There is no good way. This works fine.
