[RELEASE] Tile Builder - Build Beautiful Dashboards
Haha, I cheated, and lazy :slight_smile:
I just changed the oversized tile option in the current tile and now it shows up in the cloud endpoint.
So maybe just something off when storing over 1024 as I'm at 1258?
What was it set to before you changed it?
Set to file manager I believe.
Not something I have altered before.
Well that explains it then and means all is working as expected.
A ways back you had kept it under 1,024 so it would display just fine for local or cloud. Somewhere along the way you bumped the size to greater than 1,024 and then the output was sent to a file. That meant it was only accessible when you are at home (that is when you can access the files on the hub).
By changing it to cloud endpoint you are able to access it from anywhere.
You had said in a prior message that you had been able to access it remotely once upon a time and that you had not changed anything. But I believe that is wrong but is why I thought you were already configured to use the cloud endpoint.
Glad it is working.
Interesting. I wonder what broke the 1024 barrier?
Maybe some fiddleing with the colour after I got it working.
Thanks for the investigation!
@garyjmilne
Quick question. :wink:
I was trying to pad a text replacement but it only seems take one space.
Multiple spaces seem to be ignored.
I can use other chars and they work fine but ugly.
Do I need some sort of CSS thing here instead?
Just trying to move "Present" over. I know, I need a life.
Easiest way is to use a null character. You can usually generate a null by holding down the Alt key and typing 255 on your keypad. The character will be invisible but the cursor will move forward one space. Alternatively you can use an HTML non breaking space [&nbsp] but it uses 7 characters va the one that the null uses. There is a null character between these two quotes " " which you can cut and paste.
Thanks. Here are the results:
10 nulls didn't move the the label Guest.
&nbsp gave me <>
First column uses &nbsp to add spaces.
Second column uses null to do the same thing.
I don't have those fields - Template or Text Fields.
I am using Attr Monitor - Advanced.
I was just searching and replacing with your suggestions but maybe I'm in the wrong child app?
PS while looking for the template field I clicked on Add New Thermostat and it's a 404; coming soon possibly?
I was using Grid as an example. For what you are doing Grid is a much more flexible choice. But you can do it in Attribute Monitor like this:
This uses a sequence of nulls to increase separation between the 1st and 2nd words.
It's been out for a while. You get that error because the child module is not installed on your Hub. HPM\Modify.
