This is my release of the Tasmota Tuneable White LED Light Bulb Device Handler Driver
Use the following to flash the Tuya bulbs
Tuya-Convert
Tuya-Convert
Updated to Version 1.0.1 Added to ability to use Level Duration to fade the light in and out.
Thanks for the driver, Damon. I used it to add a Mirabella Genio non-tuneable LED bulb to HE and it works fine. I can't foresee any issues using it despite it not being tuneable, right? Anyhow, if you ever have the inclination to create a driver for a non-tuneable Tasmota bulb, I'd be happy to test it out for you!
Your welcome Stevan. Glad you're getting some use out of it. There shouldn't be any issues with using a non-tuneable bub as you are just using the parts of the driver as a switch and dimmer.
