Love your driver.. Working perfectly with tasmota firmware!!!!!
But can you add flash options such as : christmas, police and just auto changing colors..
@848667 Thank you. I will look into adding the options. I'll have to see if the options are available in the Tasmota firmware as it would be hard to have the Hub control the lights in this fashion.
Are you using these with LED bulbs or Addressable Strips?
Thanks for sharing this! After a fair bit of trial and error, I've finally got my first bulb re-flashed to tasmoto and configured properly. Your driver took over from there, and controls nearly every aspect perfectly.
There are one or two things that don't seem to work right though. As far as I can tell, the set color temperature button sends the same exact command to the bulb, regardless of what temperature I enter.
One other thing you can see in the above image - the driver always sends 4 colors (RGBW), but my bulb is actually RGBWW. It handles it fine, just treating the 5th section as 00s, but I thought I'd mention it. How much trouble would it be to add support for RGBWW bulbs?
Hiya!
Here's what I been using with my RGBWW bulbs. I modified this driver by merging stuff from damon.dinsmore's Tuneable white driver, and fixed a color problem it had. Feel free to use it if ya want.
Thanks! I actually did the same thing, and sent a pull request to @damon.dinsmore, but they've been busy and haven't had a chance to review it yet. I'll take a look at yours and see if your approach looks any different from mine.
My next challenge with this driver is that it doesn't work to add to Google Home via hubitat. I need to see what is required to make that compatible, my son wants to tell google to change the colors of his lights again.
Okay got it working with Google Home. Had to add a couple of capabilities to the driver definition for it to be recognized. Sorry bout that. I don't use Google Home, had to go dig an old Home Mini out of storage.
@NeighborGeek BTW Do you have a link to the RBGWW bulb you are using? I may want to buy one. And when did you flash Tasmota? And wat this an OTA flash?
Anyone that wants to send me makes of bulbs and capabilities so that I can compile a list of supported bulbs would be great.
I purchased the bulbs a couple of months ago, and had connected them with the feit electric app until now. (There must not be a fw update for these to block 3rd party fw, as they would have installed it if there were.) Flashed using Tyua-convert.
I've been using these LOHAS RGBWW bulbs. They flashed with right away with the new Tuya-Convert. I love the range of brightness you can get on these compared to my Sengled bulbs.
Thanks for the driver BTW. I was thinking of using that Hubitat specific Tasmota image. But it's still on 6.x, and I like to stay on the most recent Tasmota version.
