Anyone run into an issue where different events occur but the speaker never says anything and then hours later suddenly you get a barrage of everything that had been queued up? How does that even happen?
I've seen this many times, it has something to do with the queue getting stuck. You'll be able to identify it by looking at the state variable "audio clip playing" being stuck on true. Best way to clear it is to play a high priority TTS.
I tried to troubleshoot this with @daniel.winks when he was actively developing the driver but he was unable to reproduce the issue.
Interesting. Good to know even if it's annoying. Especially after I queued up "TEST" about 25 times. ![]()
During our troubleshooting @daniel.winks proposed adding some time of queue flush if it stayed in "true" for a long time, but I don't think it was ever implemented
Would be nice if someone could pick it up or if the actual Hubitat driver could be updated to be more functional like this one. It's nice to dream.
I'm wondering if sending a blank high priority TTS on a periodic schedule might mitigate the issue? I'll try it tonight and see what happens
Are there specific features you're looking for? Non-interrupting TTS is at the top of my list, and I plan to look at it some day when other things settle down, but I'm open to other ideas if they're possible with the local API (which they hopefully don't get rid of
Definitely non-interupting TTS, queueing, and Groups. I don't actually use my Sonos for music, so that's my primary wish list
Just tracking down and fixing that bug. ![]()
With the built-in integration? I'll need more context if there is something there. ![]()
We were just discussing it above. Periodically TTS that has been sent seems like it isn't going to work and then a substantial amount of time later the log jam clears and you get all the backed up stuff. Really weird.
From the context, it sounded like that was with the community integration. Is it happening with the built-in?
Community integration is the issue, unfortunately the system app/drivers don't support queuing
Update:
It's been 6 days since I implemented the periodic (1 hour) "space" High Priority TTS rule, I'm happy to say I haven't seen the queue "sticking issue" since then. Obviously this is just a "band-aid" but it might be helpful to those tired of getting a flood of "stuck" messages.
I should note, that I implemeneted this on a "group ALL" so that I could "flush" them simultaneously.
Where is that action found?
Found it!
Thanks... set mine for 30 minutes. Does it interrupt any music playing? If so maybe I'll do the 60 like you did.
I don't use my sonos for music, not 100% sure. But I would assume it would unfortuately...
I'll see how it goes. About to move everything from Alexa to HomePod and Airplay so I'll know more when I am using Airplay to play music in every room instead of Alexa.
