I have seen that the sonoff temp sensors only report on a 0.5C. change, so with a stable well insulated room, they may not report for hours and log the no presence.
I have 2 sonoff sensors at opposite ends of a large room running into a virtual thermostat doing the average between. This is because the Vthermostat will switch to emergency mode if it does not see a change after so many hrs. From either sensor.
I just leave them alone, when the sensor(s) report , the Vthermostat switches back to normal.
I sometimes check them just by blowing/breathing on them which if working (but asleep) they will start reporting again
If you need a lower reporting threshold ( 0.1 deg for example) or more frequent reporting for SNZB-02 SonOff T/H sensor, you can temporarily use the driver linked here, and then switch back to the driver that you are using now.
Drivers featured in this post are no longer maintained and users may experience issues using them. If you'd like to continue the conversation about these drivers, please consider creating a new thread.
