It’s truly the worst command API I have ever seen.
I have this all working nicely now. I have my awning exported through the Alexa app as well. Does anyone know how to get Alexa to open and close the awning through this driver via the hubitat alexa app?
OK, nevermind! I guess it just took a little time to propagate. "Alexa close awning" just worked.
I was just going to reply with that because we use a similar phrase for our drapes.
Can you post a picture of the z-wave controller this works with? I see a couple and am not sure which is the version 2. I have a myLink now in ST, but no one has a driver for it in Hubitat.
The device the driver is designed for and tested with can be found here.
It may (or may not) work with the prior gen device. I don’t know anyone who has tested with it.
I have a copy of the myLink API, which Somfy pulled from their website about a year ago. At a low priority, I have been working on a myLink Hubitat driver. A problem is that Somfy has been changing things up because they want a walled garden, which might make a purely-local driver difficult if Somfy changes the API to prevent it, and a cloud-based version difficult if Somfy wants to prevent it.
Until then, Alexa talks to our drapes using myLink and Hubitat uses Justin Walker’s (@augoisms’s) ZRTSI II driver. Denny Page has an equally good driver that has a few more features added at the request of users in the forum.
I put in an offer on a ZRTSI, if I can get it for a good price, I’ll move to z-wave. I need a virtual ST location to use my Ring Floodlight and Spotlight cams, and to get switches back into my Harmony Remote, but I’d really like to take down my physical ST hub.
I have Hubitat talking directly to MyLink over local LAN connection, details here: Integrate Somfy in Hubitat. The code is all in github but I haven't done a proper release with installations instructions. If I can find a few volunteers to test installation instructions, I'd be happy to package it up.
Thanks for the great drivers! I was nervous to port over my ZRTSII and shades from SmartThings, but your code was perfect. Thank you so much!!
Quick question, I am trying to run a custom action in Rule Machine to access the “stop” functionality. However, I can’t seem to find the shades anywhere under Custom Actions. What device type would they show under there?
Actually I went in and edited the code to include:
capability "Actuator"
It worked like a charm for what I needed. Hope that’s okay...
I recently bought a new home and found a funky looking remote. It controlled a deck awning. I’d like to use a Luton pico, is this possible?
@dennypage I'm about to purchase a "SOMFY ZRSTI 6 CHANNEL Z-WAVE TO RTS PLUG-IN INTERFACE WALL MODULE 1811265" - is this going to work with your driver?
This?
Yes, looking at one on eBay
Yes, that’s the one.
How can I use this with a dashboard template? Switch does not work. I would love to be able to do this from my phone, but cannot find a template which will control it. I tried declaring it as having Switch functionality and cloning the open and close functions to on and off, but apparently that is not enough.
Use the Shade template
Wow, that should have been obvious. Thanks!
