[RELEASE] Sinopé Neviweb Wi-Fi Thermostat Integration (Cloud, Multi-Device)
I’m sharing a Neviweb cloud integration app and driver for Hubitat that supports Sinopé Wi-Fi thermostats. This allows Hubitat to monitor and control thermostats connected via Sinopé’s Neviweb cloud service.
This integration was developed specifically to support Sinopé Wi-Fi baseboard thermostats and low-voltage models, but should work with most Neviweb-connected thermostats that expose standard Neviweb attributes.
Features
Core functionality
  • Login to Neviweb cloud directly from Hubitat
  • Discover thermostats by location
  • Import multiple thermostats (multi-select)
  • Automatic polling at configurable interval
  • Temperature reporting
  • Heating setpoint control
Thermostat mode support
Supports the following modes where exposed by the device:
  • Off
  • Heat (Manual)
  • Auto (Automatic / Schedule)
Uses native Neviweb setpointMode when available, with fallbacks for older models.
Device status and telemetry
  • Current temperature
  • Heating setpoint
  • Heating state (idle / heating)
  • Min / max setpoints
  • Operating power percentage
Hubitat compatibility
  • Fully native Hubitat app + driver
  • No external integrations required
  • Supports Hubitat automations, dashboards, and rules
  • Safe handling of Hubitat thermostat commands (no driver exceptions)
Debugging tools
  • Attribute dump command for troubleshooting and device capability discovery
  • Optional debug logging (auto-disables after 30 minutes)
Supported devices (confirmed)
Tested with:
  • Sinopé TH1124WF
  • Sinopé TH1123WF
  • Sinopé TH1310WF
  • Sinopé TH1400WF
  • Sinopé TH6500WF series
Other Neviweb Wi-Fi thermostats may also work.
Requirements
  • Hubitat Elevation hub
  • Sinopé Neviweb account
  • Sinopé Wi-Fi thermostat connected to Neviweb cloud
This integration uses Sinopé’s official Neviweb cloud API.
Installation
  1. Install the parent app code in Apps Code
  2. Install the thermostat driver in Drivers Code
  3. Add the app from Apps
  4. Enter Neviweb credentials
  5. Discover and select thermostats
  6. Click Done
Devices will be created automatically.
Limitations
  • Cloud-based (not local control)
  • Polling interval minimum ~5 minutes recommended
  • Some thermostat features may not be exposed via Neviweb API depending on model
  • Cooling and fan controls are safely stubbed for compatibility but not applicable to most baseboard units
No Technical Support / Disclaimer
This is provided as-is, without warranty or guarantee of support.
Repository Here:
Github Link to App and Driver
Hello user5278, I know your application wasn't designed to interact with Sinope's Zigbee models, but I'm open to working with you if you'd like to develop that aspect. Your application successfully detected my TH1124ZB-G2 thermostats. It seems that, for now, the only thing I can control is the heating setpoint, and it doesn't support decimals. Feel free to get in touch if you're interested.
