Shelly Wave 1PM & 1PM Mini Z-Wave 800 Driver for Hubitat (works with ZWaveJS)
ZWaveJS friendly replacement of Rene Boers [RELEASE]Shelly Wave 1PM Driver
Description
This is a custom driver for Shelly Wave 1PM (QNSW-001P16EU) and Shelly Wave 1PM Mini (QMSW-0A1P8EU), single-channel in-wall relays with power metering. It also carries the fingerprints of Shelly Wave 1 and Shelly Wave 1 Mini, which share the same firmware without the power metering part.
The driver started as a rewrite of Rene Boer's "Shelly Wave 1PM" driver v1.2 and keeps all of its functionality:
- switch control,
- power and energy metering with the lowest and highest power seen since the last meter reset (PM models only),
- remote reboot of the device for troubleshooting,
- all parameters defined in the manual are configurable, and the configuration is properly saved on the device.
It differs in the implementation:
- it works on both the legacy Z-Wave stack and Z-Wave JS: on Z-Wave JS the platform supervises commands itself, so the driver does not wrap them again, the optimistic value echo of the stack is filtered out, and meter reports are parsed as Meter CC v5 because the v6 report objects cannot be constructed by the platform,
- supervision on the legacy stack retries a bounded number of times and cannot loop (no more relays toggling on and off with retry warnings on S2 devices),
- the set of configuration parameters follows the firmware version: firmware 13 and later adds the detach mode (No. 7) and the remote reboot (No. 117) and drops the alarm responses (No. 91 - 94).
Notes
- The driver has been tested on Shelly Wave 1PM with firmware version 11.10 and Shelly Wave 1PM Mini with firmware version 11.05 from EU distribution, both securely paired (S2 Authenticated) with Hubitat.
- The firmware 13 and 14 parameter set comes from the vendor's release notes and the Z-Wave JS device database and has not been tested on a device.
- Shelly Wave 1 and Shelly Wave 1 Mini are recognised by the fingerprint but have not been tested.
- Association groups 2 and 3 (Basic Set and Switch Multilevel to other devices) are not configurable from the driver.
Changelog
- v0.1.0 - 20.09.2026: Initial release: switch control, power and energy metering with lowest and highest power tracking, remote reboot and all parameters of Wave 1PM and Wave 1PM Mini, working on both the legacy Z-Wave stack and Z-Wave JS.
Installation
It is recommended to install through Hubitat Package Manager by searching for Shelly Wave 1PM. Alternatively, you can download the code and install it manually.
Download
