This Hubitat integration is based on "The Hook Up" video tutorial.
However I reversed the Reed switch logic and location so that when the magnet comes in proximity of the switch, the garage door is 100% closed and not 100% open.
This is my Reed switch installation:
I secured the magnet to two chain links with zip-ties and the Reed switch to a L-shaped piece of plexiglass. The zip-ties are small and relatively weak, so should the chain oscillate excessively and the magnet hit the plexiglass, the zip-ties should break and hopefully leave everything else intact
I mounted the Shelly switch on a small platform I built on top of the garage opener, together with my Ecowitt and Tempest gateways. All three powered by a single 4-port USB charger:
So far everything works as designed. All in all $20 well spent
I closed my FB account 10 years ago
Could you do it for me?
After a few days of use, the only problem I've found is that, when I open the door, the torque causes the chain to oscillate a bit and the Reed switch to "flip-flop".
Not a big deal, but enough for Hubitat to send two "garage open" notifications to my cell.
I either need a better (more stable/less sensitive) Reed switch or come up with a different mounting solution.
Suggestions from anyone with prior experience?
You should use some sort of de-bounce code in the driver so that multiple on/off changes within a 1/2 second is not trigering rules, to do this use a time stamp when it first is detected and reject all new states for 1/2 second, then recheck the state to make sure it did not change just in case it was a real change of state.
That is actually an excellent idea!
Why didn't I think of it...
