Fixed. Updated code to correct error and updated initial instructions to include the following:
SPECIAL INITIAL INSTALL INSTRUCTIONS:
Press 'Next' to install.
Immediately select 'Done' on the next page (installs app).
Run app again (now installed) and continue.
(For some reason, discovery does not work unless you install then run app again? I will investigate this further and try to resolve. But that is for another day.)
I am working on it. Still not able to replicate. It is not long term; but will take the rest of the week. It is more complex that I thought and I still can not replicate.
You use the mac field for ID of the child device, but it is null when the speaker is on a routed subnet. I use a modified version of your driver, where the ID is the SSDP UUID, and it works properly in all cases, maybe you should do something similar... This is how I solved the problem in the app:
def ssdpHandler(evt) {
def parsedEvent = parseLanMessage(evt.description)
logDebug("ssdpHandler: parsedEvent = ${parsedEvent}")
def ip = convertHexToIP(parsedEvent.networkAddress)
def port = convertHexToInt(parsedEvent.deviceAddress)
def mac = parsedEvent.mac == "null" ? "unknown" : convertDniToMac(parsedEvent.mac)
def ssdpUSN = parsedEvent.ssdpUSN
def uuid = ssdpUSN.replaceAll(/uuid:/, "").take(36)
def speakers = state.speakers
if (speakers."${uuid}") {
def d = speakers."${uuid}"
def child = getChildDevice(uuid)
if (d.ip != ip) {
d.ip = ip
if (child) {
logDebug("ssdpHandler: updating child, IP = ${ip}")
child.updateDataValue("deviceIP", ip)
child.updateDataValue("appVersion", appVersion())
} else {
def speaker = [:]
speaker["dni"] = uuid
speaker["mac"] = mac
speaker["ip"] = ip
speaker["ssdpPort"] = port
speaker["ssdpPath"] = parsedEvent.ssdpPath
speakers << ["${uuid}": speaker]
logDebug("ssdpHandler: speaker = ${speaker}")
Dave, I decided to start over again, and uninstalled everything, rebooted the HE, and reinstalled the driver and app. I can get it working, but like Aaron my queue gets stuck and I need to save preferences to clear it. Then it will work again.
I tried the previous git driver and app, and it wouldn't find my speakers with those. I am using the latest versions.
By the way, I really appreciate your work on this.
I am working on the queuing problem. I think it is caused by a new message coming in at the same time the queue is shutting down. I will figure it out.
Do a Save Preferences. It will create the new "state.unreachableCount" which was created to temporarily stop the refresh cycle (and associated system load) if the speaker is not on the net. See post below.
Update. I am still working the TTS queuing issue. The problem 'appears' to be with use of state within Hubitat. It is not always updating properly when set and this causes this (and other unnoticed problems).
I am working on the entire code set trying to reduce the reliance on state variables to a minimum, using data instead.
Changes:
a. Fully tested all code for unnecessary activity.
b. Reworked Queuing to work per requirements.
c. Added automatic recover function to queuing. If queue is stuck, it will start queuing over in 30 seconds.
d. Tested queuing using play text, play text and resume, and speak. Had a up to 12 messages entered during the playing process with no drops, overlaps, or queue freezes.
e. Removed test queue. Use speak, play text, play text and resume.
I'm using this mainly for notifications. They have now gone from taking 1 second to execute, to now taking 3-4 seconds to execute. If I open a door, it takes 3 seconds to tell me now. Previously it was 1 second. I also have 1 Sonos, and that notification is almost instant, less than a second.
