[Release] Samsung Multiroom WiFi Audio
First ... many thanks for your work on this functionality over the last few years ... it sure made this HA insanity a lot easier for a lot of folks!
Just wanted to let you know that I just spent about 4 hours trying to get the latest release to work with my R1 speakers. I'm just now starting to move things over to HE from ST and it was my first try with the driver and BigTalker app on HE; so I thought I was doing something wrong. Then I saw that it's a new release and tried with the version you released back in January. That worked fine ... so maybe there is a bug in the new version? I kept getting null pointer errors and assumed I wasn't initializing something correctly.
Hi, Dave. I upgraded to your latest (speaker code) and tested with a speak text command from the device handler. I'm seeing:
 09:48:07.654 pm [error](http://192.168.1.140/device/edit/1155)java.lang.IllegalArgumentException: argument type mismatch on line 500 (speak)
What did I do wrong?
It was me. Not you.
Updated driver to correct your problem.
@djgutheinz
Error when using as a music player and/or speech device looks like similar errors. Also the Queuing errors for the first time when device is installed. I captured it at the bottom. Once I did a "test" in the driver itself the line 490 error went away.
[dev:346](http://10.0.2.38/logs#dev346)2019-04-07 08:45:29.007 am [error](http://10.0.2.38/device/edit/346)java.lang.IllegalArgumentException: argument type mismatch on line 500 (speak)
[dev:346](http://10.0.2.38/logs#dev346)2019-04-07 08:45:29.005 am [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.01: generalResponse_RadioInfo
[dev:346](http://10.0.2.38/logs#dev346)2019-04-07 08:45:28.933 am [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.01: sendCmd: Command= /CPM?cmd=%3Cname%3EGetRadioInfo%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs#dev346)2019-04-07 08:45:28.922 am [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.01: playTrackAndResume: trackUri = [duration:1, uri:http://10.0.2.38/tts/2f9b24bc688d5c29cd940aa6b6aef5c6.mp3], Volume = null, playingTTS = false
[dev:346](http://10.0.2.38/logs#dev346)2019-04-07 08:45:28.909 am [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.01: playTextAndResume: Text = test, Volume = null
[dev:346](http://10.0.2.38/logs#dev346)2019-04-07 08:45:28.907 am [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.01: speak: text = test
[dev:346](http://10.0.2.38/logs#dev346)2019-04-07 08:45:24.692 am [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.01: generalResponse_PlayStatus
[dev:346](http://10.0.2.38/logs#dev346)2019-04-07 08:45:24.590 am [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.01: sendCmd: Command= /CPM?cmd=%3Cname%3EGetPlayStatus%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs#dev346)2019-04-07 08:45:24.585 am [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.01: getPlayStatus: source = wifi, submode = cp
[dev:346](http://10.0.2.38/logs#dev346)2019-04-07 08:45:19.632 am [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.01: generalResponse_RadioInfo
[dev:346](http://10.0.2.38/logs#dev346)2019-04-07 08:45:19.535 am [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.01: sendCmd: Command= /CPM?cmd=%3Cname%3EGetRadioInfo%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs#dev346)2019-04-07 08:45:19.531 am [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.01: setTrackDescription: source = wifi
[dev:346](http://10.0.2.38/logs#dev346)2019-04-07 08:45:17.613 am [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.01: generalResponse_AcmMode
[dev:346](http://10.0.2.38/logs#dev346)2019-04-07 08:45:17.525 am [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.01: sendCmd: Command= /UIC?cmd=%3Cname%3EGetAcmMode%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs#dev346)2019-04-07 08:45:17.181 am [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.01: generalResponse_VolumeLevel
[dev:346](http://10.0.2.38/logs#dev346)2019-04-07 08:45:17.021 am [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.01: sendCmd: Command= /UIC?cmd=%3Cname%3EGetVolume%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs#dev346)2019-04-07 08:45:16.574 am [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.01: generalResponse_CurrentFunc
[dev:346](http://10.0.2.38/logs#dev346)2019-04-07 08:45:16.511 am [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.01: sendCmd: Command= /UIC?cmd=%3Cname%3EGetFunc%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs#dev346)2019-04-07 08:45:16.509 am [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.01: finishRefresh
[dev:346](http://10.0.2.38/logs#dev346)2019-04-07 08:45:16.497 am [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.01: pollingResponse_MuteStatus
[dev:346](http://10.0.2.38/logs#dev346)2019-04-07 08:45:16.328 am [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.01: sendCmd: Command= /UIC?cmd=%3Cname%3EGetMute%3C/name%3E, Action = pollingResp, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs#dev346)2019-04-07 08:45:16.323 am [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.01: refresh, unreachableCount = 0
[dev:346](http://10.0.2.38/logs#dev346)2019-04-07 08:45:16.303 am [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.01: setRefreshRate: refresh rate = 5
[dev:346](http://10.0.2.38/logs#dev346)2019-04-07 08:45:16.244 am [info](http://10.0.2.38/device/edit/346)Samsung M3 updating: refresh = 5, debug = true
[dev:346](http://10.0.2.38/logs#dev346)2019-04-07 08:44:54.749 am [error](http://10.0.2.38/device/edit/346)java.lang.NullPointerException: Cannot invoke method leftShift() on null object on line 490 (speak)
There was an error corrected this AM that should fix the problem. Please in the future, send some log information so I see the error.
Thanks for the logs.
  • Driver updated on GitHub to correct typo not caught in final release.
  • Added Test Queue command that will play three messages.
  • Added "Run Preferences" to update instructions.
Audio notifications are working again which is a plus.
Question...how big is the TTS queue? I attempted to run the TTS queue test and while it was announcing I opened some doors which have TTS notification to the device driver. Those did not announce. :frowning:
just tested on my R1. Worked OK; however.......
  1. try just opening some doors without the test queue. See if it works.
  2. try test queue again and see if it works.
I am right now modifying Test Queue to run all possible commands that can cause text-based audio notification (there are four). This will test all available external inputs.
So the TTS queue works fine if I open a couple doors. TTS is spoken in correct order. When using the test queue those same actions with a couple of doors are not registering with the queue. Just wanted to make sure you knew.
Yes. I think there is a collision in the code. Probably not a worry unless you are running Test Queue.
Thanks!!!!!
@djgutheinz
Weird error coming from app. Shows as null in logs. I discovered it was the Samsung app by replacing the app code if of another app with 442 and it shows up as yours. Went through app registration and closed app. Waiting for next refresh to see if error pops up again.
 [app:442](http://10.0.2.38/logs/past#app442)2019-04-07 03:28:39.303 pm[error](http://10.0.2.38/installedapp/configure/442)java.lang.StringIndexOutOfBoundsException: String index out of range: 6 on line 428 (ssdpHandler)
[app:442](http://10.0.2.38/logs/past#app442)2019-04-07 03:28:39.286 pm[error](http://10.0.2.38/installedapp/configure/442)java.lang.StringIndexOutOfBoundsException: String index out of range: 6 on line 428 (ssdpHandler)
[app:442](http://10.0.2.38/logs/past#app442)2019-04-07 03:28:38.939 pm[error](http://10.0.2.38/installedapp/configure/442)java.lang.StringIndexOutOfBoundsException: String index out of range: 6 on line 428 (ssdpHandler)
Need debug data. Not seeing error here. Have updated SmartApp to allow debug logging selection. you will need to change near the top of the file:
> ===== HUBITAT INTEGRATION VERSION ===========================*/
> //	state.debugLogging = true
> 	state.debugLogging = false
> 	def appVersion() { return "2.1.01" }
> definition(
to
> // state.debugLogging = false
> definition(
?Hubitat_Samsung-WiFi-Audio/Samsung WiFi Audio App.groovy at master · DaveGut/Hubitat_Samsung-WiFi-Audio · GitHub?
I haven't seen anymore issues with the app. But the queue in the Samsung Speaker device has become frozen. No additional logs available besides the screenshot below of the device and the queue backed up.
That should not happen. However, SAVE PREFERENCES or run the TEST QUEUE. Both will reset the queue and the variable state.playingTTS (to false - which starts the queue action.
I will look at a design that precludes this problem - but it is not likely.
Dave
Dave,
The queue has gotten stuck three times in the last 24 hours. I did turn on debug mode and have the following logs for you. The queue showed a total of 10 messages that were stuck from the Notification App.
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:23:57.030 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_PlayStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:23:56.878 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /CPM?cmd=%3Cname%3EGetPlayStatus%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:23:56.875 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: getPlayStatus: source = wifi, submode = cp
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:23:51.239 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_RadioInfo
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:23:51.179 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /CPM?cmd=%3Cname%3EGetRadioInfo%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:23:51.178 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: setTrackDescription: source = wifi
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:23:49.227 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_AcmMode
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:23:49.161 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetAcmMode%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:23:48.694 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_VolumeLevel
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:23:48.660 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetVolume%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:23:48.284 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_CurrentFunc
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:23:48.158 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetFunc%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:23:48.158 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: finishRefresh
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:23:48.154 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: pollingResponse_MuteStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:23:48.044 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetMute%3C/name%3E, Action = pollingResp, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:23:48.040 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: refresh, unreachableCount = 0
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:23:06.503 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_PlayStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:23:06.359 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /CPM?cmd=%3Cname%3EGetPlayStatus%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:23:06.352 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: getPlayStatus: source = wifi, submode = cp
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:23:02.105 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_RadioInfo
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:23:01.276 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /CPM?cmd=%3Cname%3EGetRadioInfo%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:23:01.275 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: setTrackDescription: source = wifi
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:22:59.380 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_AcmMode
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:22:59.261 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetAcmMode%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:22:58.862 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_VolumeLevel
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:22:58.748 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetVolume%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:22:58.453 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_CurrentFunc
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:22:58.229 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetFunc%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:22:58.228 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: finishRefresh
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:22:58.208 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: pollingResponse_MuteStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:22:58.032 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetMute%3C/name%3E, Action = pollingResp, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:22:58.031 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: refresh, unreachableCount = 0
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:22:57.931 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: setRefreshRate: refresh rate = 5
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:22:57.829 pm [info](http://10.0.2.38/device/edit/346)Samsung M3 updating: refresh = 5, debug = true
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:22:11.337 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_PlayStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:22:11.230 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /CPM?cmd=%3Cname%3EGetPlayStatus%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:22:11.227 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: getPlayStatus: source = wifi, submode = cp
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:22:06.381 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_RadioInfo
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:22:06.159 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /CPM?cmd=%3Cname%3EGetRadioInfo%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:22:06.158 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: setTrackDescription: source = wifi
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:22:04.191 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_AcmMode
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:22:04.148 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetAcmMode%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:22:03.770 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_VolumeLevel
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:22:03.646 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetVolume%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:22:03.252 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_CurrentFunc
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:22:03.145 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetFunc%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:22:03.140 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: finishRefresh
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:22:03.130 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: pollingResponse_MuteStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:22:03.051 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetMute%3C/name%3E, Action = pollingResp, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:22:03.032 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: refresh, unreachableCount = 0
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:21:33.091 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: playTrackAndResume: trackUri = [duration:1, uri:http://10.0.2.38/tts/9a15271d4d94dd8f6851bf10813cad53.mp3], Volume = 90, playingTTS = true
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:21:32.973 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: playTextAndResume: Text = Patio Door has been opened, Volume = 90
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:21:32.957 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: playText: Text = Patio Door has been opened, Volume = 90
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:21:14.770 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_PlayStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:21:14.653 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /CPM?cmd=%3Cname%3EGetPlayStatus%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:21:14.651 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: getPlayStatus: source = wifi, submode = cp
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:21:09.747 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_RadioInfo
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:21:09.626 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /CPM?cmd=%3Cname%3EGetRadioInfo%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:21:09.622 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: setTrackDescription: source = wifi
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:21:07.740 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_AcmMode
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:21:07.608 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetAcmMode%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:21:07.212 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_VolumeLevel
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:21:07.106 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetVolume%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:21:06.734 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_CurrentFunc
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:21:06.604 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetFunc%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:21:06.598 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: finishRefresh
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:21:06.592 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: pollingResponse_MuteStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:21:06.268 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetMute%3C/name%3E, Action = pollingResp, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:21:06.245 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: refresh, unreachableCount = 0
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:20:11.300 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_PlayStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:20:11.249 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /CPM?cmd=%3Cname%3EGetPlayStatus%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:20:11.243 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: getPlayStatus: source = wifi, submode = cp
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:20:06.337 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_RadioInfo
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:20:06.198 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /CPM?cmd=%3Cname%3EGetRadioInfo%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:20:06.196 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: setTrackDescription: source = wifi
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:20:04.153 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_AcmMode
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:20:04.100 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetAcmMode%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:20:03.730 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_VolumeLevel
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:20:03.599 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetVolume%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:20:03.223 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_CurrentFunc
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:20:03.096 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetFunc%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:20:03.094 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: finishRefresh
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:20:03.090 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: pollingResponse_MuteStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:20:03.022 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetMute%3C/name%3E, Action = pollingResp, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:20:03.020 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: refresh, unreachableCount = 0
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:19:11.328 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_PlayStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:19:11.229 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /CPM?cmd=%3Cname%3EGetPlayStatus%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:19:11.226 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: getPlayStatus: source = wifi, submode = cp
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:19:06.359 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_RadioInfo
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:19:06.190 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /CPM?cmd=%3Cname%3EGetRadioInfo%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:19:06.187 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: setTrackDescription: source = wifi
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:19:04.188 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_AcmMode
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:19:04.140 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetAcmMode%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:19:03.763 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_VolumeLevel
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:19:03.637 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetVolume%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:19:03.254 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_CurrentFunc
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:19:03.134 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetFunc%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:19:03.129 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: finishRefresh
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:19:03.121 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: pollingResponse_MuteStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:19:03.039 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetMute%3C/name%3E, Action = pollingResp, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:19:03.035 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: refresh, unreachableCount = 0
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:18:11.661 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_PlayStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:18:11.599 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /CPM?cmd=%3Cname%3EGetPlayStatus%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:18:11.595 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: getPlayStatus: source = wifi, submode = cp
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:18:06.638 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_RadioInfo
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:18:06.573 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /CPM?cmd=%3Cname%3EGetRadioInfo%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:18:06.572 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: setTrackDescription: source = wifi
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:18:04.623 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_AcmMode
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:18:04.560 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetAcmMode%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:18:03.796 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_VolumeLevel
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:18:03.677 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetVolume%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:18:03.272 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_CurrentFunc
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:18:03.174 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetFunc%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:18:03.172 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: finishRefresh
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:18:03.162 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: pollingResponse_MuteStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:18:03.018 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetMute%3C/name%3E, Action = pollingResp, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:18:03.016 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: refresh, unreachableCount = 0
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:17:11.296 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_PlayStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:17:11.184 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /CPM?cmd=%3Cname%3EGetPlayStatus%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:17:11.180 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: getPlayStatus: source = wifi, submode = cp
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:17:06.296 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_RadioInfo
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:17:06.140 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /CPM?cmd=%3Cname%3EGetRadioInfo%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:17:06.137 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: setTrackDescription: source = wifi
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:17:04.149 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_AcmMode
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:17:04.101 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetAcmMode%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:17:03.724 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_VolumeLevel
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:17:03.599 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetVolume%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:17:03.211 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_CurrentFunc
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:17:03.097 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetFunc%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:17:03.097 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: finishRefresh
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:17:03.088 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: pollingResponse_MuteStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:17:03.022 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetMute%3C/name%3E, Action = pollingResp, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:17:03.019 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: refresh, unreachableCount = 0
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:16:11.682 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_PlayStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:16:11.515 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /CPM?cmd=%3Cname%3EGetPlayStatus%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:16:11.512 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: getPlayStatus: source = wifi, submode = cp
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:16:06.605 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_RadioInfo
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:16:06.487 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /CPM?cmd=%3Cname%3EGetRadioInfo%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:16:06.482 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: setTrackDescription: source = wifi
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:16:04.176 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_AcmMode
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:16:04.128 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetAcmMode%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:16:03.758 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_VolumeLevel
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:16:03.626 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetVolume%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:16:03.237 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_CurrentFunc
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:16:03.124 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetFunc%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:16:03.123 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: finishRefresh
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:16:03.118 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: pollingResponse_MuteStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:16:03.032 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetMute%3C/name%3E, Action = pollingResp, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:16:03.026 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: refresh, unreachableCount = 0
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:15:11.354 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_PlayStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:15:11.303 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /CPM?cmd=%3Cname%3EGetPlayStatus%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:15:11.301 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: getPlayStatus: source = wifi, submode = cp
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:15:06.332 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_RadioInfo
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:15:06.268 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /CPM?cmd=%3Cname%3EGetRadioInfo%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:15:06.267 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: setTrackDescription: source = wifi
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:15:04.206 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_AcmMode
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:15:04.158 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetAcmMode%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:15:03.785 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_VolumeLevel
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:15:03.655 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetVolume%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:15:03.267 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_CurrentFunc
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:15:03.152 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetFunc%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:15:03.152 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: finishRefresh
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:15:03.148 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: pollingResponse_MuteStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:15:03.023 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetMute%3C/name%3E, Action = pollingResp, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:15:03.019 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: refresh, unreachableCount = 0
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:14:11.284 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_PlayStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:14:11.172 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /CPM?cmd=%3Cname%3EGetPlayStatus%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:14:11.168 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: getPlayStatus: source = wifi, submode = cp
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:14:06.263 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_RadioInfo
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:14:06.148 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /CPM?cmd=%3Cname%3EGetRadioInfo%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:14:06.147 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: setTrackDescription: source = wifi
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:14:04.140 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_AcmMode
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:14:04.090 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetAcmMode%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:14:03.718 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_VolumeLevel
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:14:03.587 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetVolume%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:14:03.219 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_CurrentFunc
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:14:03.085 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetFunc%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:14:03.084 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: finishRefresh
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:14:03.080 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: pollingResponse_MuteStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:14:03.023 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetMute%3C/name%3E, Action = pollingResp, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:14:03.021 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: refresh, unreachableCount = 0
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:13:11.421 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_PlayStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:13:11.358 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /CPM?cmd=%3Cname%3EGetPlayStatus%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:13:11.353 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: getPlayStatus: source = wifi, submode = cp
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:13:06.306 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_RadioInfo
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:13:06.174 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /CPM?cmd=%3Cname%3EGetRadioInfo%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:13:06.172 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: setTrackDescription: source = wifi
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:13:04.173 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_AcmMode
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:13:04.122 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetAcmMode%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:13:03.752 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_VolumeLevel
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:13:03.620 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetVolume%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:13:03.231 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_CurrentFunc
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:13:03.117 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetFunc%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:13:03.117 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: finishRefresh
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:13:03.114 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: pollingResponse_MuteStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:13:03.020 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetMute%3C/name%3E, Action = pollingResp, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:13:03.018 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: refresh, unreachableCount = 0
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:12:11.451 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_PlayStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:12:11.343 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /CPM?cmd=%3Cname%3EGetPlayStatus%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:12:11.341 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: getPlayStatus: source = wifi, submode = cp
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:12:06.428 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_RadioInfo
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:12:06.317 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /CPM?cmd=%3Cname%3EGetRadioInfo%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:12:06.317 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: setTrackDescription: source = wifi
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:12:04.204 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_AcmMode
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:12:04.166 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetAcmMode%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:12:03.788 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_VolumeLevel
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:12:03.663 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetVolume%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:12:03.266 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_CurrentFunc
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:12:03.156 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetFunc%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:12:03.156 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: finishRefresh
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:12:03.153 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: pollingResponse_MuteStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:12:03.023 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetMute%3C/name%3E, Action = pollingResp, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:12:03.019 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: refresh, unreachableCount = 0
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:11:11.286 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_PlayStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:11:11.229 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /CPM?cmd=%3Cname%3EGetPlayStatus%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:11:11.227 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: getPlayStatus: source = wifi, submode = cp
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:11:06.261 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_RadioInfo
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:11:06.179 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /CPM?cmd=%3Cname%3EGetRadioInfo%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:11:06.175 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: setTrackDescription: source = wifi
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:11:04.136 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_AcmMode
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:11:04.096 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetAcmMode%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:11:03.716 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_VolumeLevel
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:11:03.593 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetVolume%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:11:03.197 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_CurrentFunc
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:11:03.091 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetFunc%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:11:03.091 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: finishRefresh
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:11:03.082 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: pollingResponse_MuteStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:11:03.022 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetMute%3C/name%3E, Action = pollingResp, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:11:03.019 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: refresh, unreachableCount = 0
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:10:11.214 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_PlayStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:10:11.173 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /CPM?cmd=%3Cname%3EGetPlayStatus%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:10:11.170 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: getPlayStatus: source = wifi, submode = cp
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:10:06.389 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_RadioInfo
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:10:06.143 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /CPM?cmd=%3Cname%3EGetRadioInfo%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:10:06.141 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: setTrackDescription: source = wifi
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:10:04.268 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_AcmMode
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:10:04.130 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetAcmMode%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:10:03.753 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_VolumeLevel
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:10:03.628 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetVolume%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:10:03.227 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_CurrentFunc
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:10:03.126 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetFunc%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:10:03.125 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: finishRefresh
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:10:03.108 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: pollingResponse_MuteStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:10:03.033 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetMute%3C/name%3E, Action = pollingResp, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:10:03.030 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: refresh, unreachableCount = 0
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:09:11.246 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_PlayStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:09:11.182 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /CPM?cmd=%3Cname%3EGetPlayStatus%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:09:11.179 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: getPlayStatus: source = wifi, submode = cp
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:09:06.231 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_RadioInfo
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:09:06.155 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /CPM?cmd=%3Cname%3EGetRadioInfo%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:09:06.153 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: setTrackDescription: source = wifi
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:09:04.206 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_AcmMode
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:09:04.143 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetAcmMode%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:09:03.678 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_VolumeLevel
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:09:03.642 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetVolume%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:09:03.270 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_CurrentFunc
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:09:03.140 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetFunc%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:09:03.140 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: finishRefresh
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:09:03.137 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: pollingResponse_MuteStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:09:03.032 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetMute%3C/name%3E, Action = pollingResp, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:09:03.028 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: refresh, unreachableCount = 0
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:08:11.377 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_PlayStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:08:11.298 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /CPM?cmd=%3Cname%3EGetPlayStatus%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:08:11.295 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: getPlayStatus: source = wifi, submode = cp
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:08:06.353 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_RadioInfo
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:08:06.266 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /CPM?cmd=%3Cname%3EGetRadioInfo%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:08:06.263 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: setTrackDescription: source = wifi
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:08:04.331 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_AcmMode
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:08:04.239 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetAcmMode%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:08:03.808 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_VolumeLevel
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:08:03.738 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetVolume%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:08:03.289 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_CurrentFunc
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:08:03.236 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetFunc%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:08:03.235 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: finishRefresh
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:08:03.169 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: pollingResponse_MuteStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:08:03.037 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetMute%3C/name%3E, Action = pollingResp, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:08:03.032 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: refresh, unreachableCount = 0
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:07:11.310 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_PlayStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:07:11.258 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /CPM?cmd=%3Cname%3EGetPlayStatus%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:07:11.255 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: getPlayStatus: source = wifi, submode = cp
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:07:06.287 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_RadioInfo
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:07:06.213 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /CPM?cmd=%3Cname%3EGetRadioInfo%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:07:06.212 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: setTrackDescription: source = wifi
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:07:04.163 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_AcmMode
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:07:04.112 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetAcmMode%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:07:03.745 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_VolumeLevel
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:07:03.609 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetVolume%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:07:03.230 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_CurrentFunc
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:07:03.106 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetFunc%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:07:03.105 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: finishRefresh
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:07:03.102 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: pollingResponse_MuteStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:07:03.022 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetMute%3C/name%3E, Action = pollingResp, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:07:03.018 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: refresh, unreachableCount = 0
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:06:11.341 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_PlayStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:06:11.264 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /CPM?cmd=%3Cname%3EGetPlayStatus%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:06:11.261 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: getPlayStatus: source = wifi, submode = cp
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:06:06.652 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_RadioInfo
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:06:06.170 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /CPM?cmd=%3Cname%3EGetRadioInfo%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:06:06.167 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: setTrackDescription: source = wifi
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:06:04.194 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_AcmMode
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:06:04.145 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetAcmMode%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:06:03.844 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_VolumeLevel
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:06:03.642 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: sendCmd: Command= /UIC?cmd=%3Cname%3EGetVolume%3C/name%3E, Action = generalResponse, host = 10.0.2.33:55001
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:06:03.253 pm [debug](http://10.0.2.38/device/edit/346)Samsung M3, 2.1.02: generalResponse_CurrentFunc
[dev:346](http://10.0.2.38/logs/past#dev346)2019-04-09 11:06:03.139 pm [debug]
I updated to the latest app and driver, and it no longer worked (sending notifications). I completely removed the app and driver and reinstalled them from the latest git. It searches for my 2 speakers, finds them (I click "done"), but when I look in my devices page, they are not listed there. Any ideas?
Working on it. You can go to the previous driver (no need to update smart app) in the interim.
Okay, thanks. I will try that when I get home tonight.
Chris - you are broken right now and I need to fix before trying again. I tested the app today. Following results:
Using the version I copied over to the old version, it worked as expected.
Doing a fresh install (changed app name), Discovery is not working at all! It never gets to the parse method.
Dave
But using the previous version on GitHub should get me back in business? I only saw 1 old version available.
