[RELEASE] Samsung TV Remote (2016 and later TVs)
NOTE: Upcoming platform release 2.5.3 will include built-in TV Remote integrations, including for Samsung TVs. This community integration may continue to be maintained if there is both value and interest.
Samsung TV Remote is a driver for Samsung Tizen TVs from 2016 on. It controls the TV over its local network API, with an optional SmartThings connection for what that API doesn't report. It is @djgutheinz 's Samsung TV Remote, carried on with his agreement now that he is retiring his own version. Existing devices on his driver keep working (see Moving from Dave's driver below).
Thank you, Dave, for writing this driver and supporting it for years.
  • Finding the TV: leave the IP blank and the driver finds the TV on the network. If the TV's IP changes, the driver follows it. Find TVs searches again.
  • Power: on sends Wake-on-LAN and repeats it until the TV answers; off sends the power key. switch follows the TV's power state; Refresh reads it at once.
  • Keys: sendKey takes any Samsung key name (KEY_HOME is HOME), plus commands for the usual ones: arrows, enter, home, Return, exit, menu, guide, channel and volume keys, play, pause, stop.
  • Apps: appOpenByName and appClose, for apps whose codes the device knows (the Scan for App Codes preference finds them, or SmartThings reports the running app).
  • Presets: save a channel or an app and recall it with presetExecute, or from a dashboard button.
  • Frame TVs: artMode turns art mode on and artModeStatus reports it.
  • With SmartThings: volume, mute, channel, input source, picture and sound mode.
Status
NOTE: updated to RELEASE status 2026/11/07.
Tested TVs
Mock TV profiles (the driver is tested against each before a release):
  • Built from tester reports on real TVs:
    • 2020 TU7000 (UN50TU7000)
    • 2022 QN88B (QN55QN88B): reports standby while still answering after power-off
    • 2022 QN95B (QN75QN95B): takes over 6 s to accept the connection
  • Frame TVs, modelled on known behaviour:
    • 2024 Frame
    • 2025 Frame: reports standby while showing art
  • Made-up test cases:
    • TV without PowerState
    • TV without token authentication
    • Allow prompt refused on the TV
    • TV that answers the remote-control SSDP search
Run the Samsung TV Remote Tester on your TV and post the report here: each new model becomes a profile.
Known limits:
  • SmartThings personal access tokens expire after 24 hours; when one expires the driver stops SmartThings polling and falls back to remote keys for channels.
  • Without SmartThings, mute and unmute both send the mute key, which toggles.
  • Some TVs stopped reporting PowerState after a firmware update. The driver then checks power through the TV's websocket on each poll.
Install
With Hubitat Package Manager: search for Samsung TV Remote (hubitrep).
By hand: in Drivers Code, choose New Driver, then Import, and paste https://raw.githubusercontent.com/hubitrep/SamsungTvRemote/main/SamsungTVRemote.groovy.
Setup
  1. On the TV, make sure AirPlay is enabled.
  2. On the TV, under Settings → General → Network → Expert Settings, turn on Power On with Mobile and IP Remote.
  3. Turn the TV on. Add a virtual device with the Samsung TV Remote driver, leave the IP blank and click Save Preferences. The driver finds the TV. With several TVs, pick one under TV and save again.
  4. Send a command such as Home. The TV asks whether to allow the connection; choose Allow.
Finding the TV needs a 2018 or later TV on the same subnet as the hub, with AirPlay on. Otherwise enter the TV's IP address, with a DHCP reservation in your router. After a power cut the hub may not find the TV again until the hub restarts; standby is fine.
The driver keeps Dave's driver name and namespace, so existing devices, rules and dashboards keep working.
  • Installed with HPM:
    1. Package Manager Settings → Un-Match a Package → Remove a Matched Package: pick Samsung TV Remote (Dave's package).
    2. Match Up: pick Samsung TV Remote (hubitrep).
    3. Repair: pick Samsung TV Remote (hubitrep) to download the code.
  • Installed by hand: open the driver in Drivers Code, Import from the URL above and Save.
  • Installed from Dave's bundle: import the driver as above. The davegut libraries the bundle added to Libraries Code are no longer used by this driver.
Each TV device updates itself at its next power poll and keeps its settings. To go back, import Dave's driver by hand.
Help wanted: test it on your TV
The package includes an optional app, Samsung TV Remote Tester, that runs the driver through a fixed set of tests and reports where your TV behaves differently from what the driver expects. Add it with HPM's Modify (it is an optional component of the package), or import https://raw.githubusercontent.com/hubitrep/SamsungTvRemote/main/tests/SamsungTVRemoteTester.groovy in Apps Code.
  1. Add the app, select your Samsung TV Remote device and click Run.
  2. The tests take 3 to 4 minutes and change what is on the screen: they press Home, open and close YouTube or Netflix if the device knows its code, switch a Frame to art mode, and turn the TV off and on.
  3. Copy the report from the app page into a reply here. It leaves out IP and MAC addresses, the TV's name and the connection token.
Reports from Frame TVs, from TVs that no longer report PowerState, and from 2018–2019 and 2024+ models would help the most.
Documentation: README · Dave's guides (installation, commands, apps and presets)
Questions, bugs and reports are welcome in this thread.
2.4.4 (beta) is out, in HPM and on GitHub.
  • Setup without an IP. Add the device, turn the TV on, leave the IP blank and click Save. The driver finds the TV on the network. With several TVs, pick one under TV and save again.
  • IP changes. When the TV stops answering, the driver finds it at its new address, checked by MAC, and carries on.
  • Find TVs command: searches again. Use it to switch the device to another TV.
Needs a 2018 or later TV, on the same subnet as the hub, with AirPlay on in the TV's settings. Tested on hub firmware 2.5.2 and later. Otherwise type the IP, as before.
After a power cut the hub may not find the TV again until the hub restarts. Standby is fine. A DHCP reservation avoids this.
The Tester (0.3.0) adds a Discovery test. If you have a Frame or a 2018–2019 or 2024+ model, a report would help.
I have installed the latest version on my HE hub using HPM. It found my Bedroom 75" OLED Samsung 2025 TV (QN75QN90FAF SAMSUNG QN75QN90FAFXZA 4K NEO).
I have added my Samsung API and Device keys, but get the following error in the logs:
java.lang.NullPointerException: Cannot get property 'pictureMode' on null object on line 1877 (method statusParse)
Line 1877: String pictureMode = mainData["custom.picturemode"].pictureMode.value
Thanks, that log has what was needed. Your 2025 TV reports picture and sound mode under different SmartThings names than older models (mine is 2020). 2.4.5 is out with the fix. Setting picture or sound mode on these models is untested: could you try Set Picture Mode with one of your modes (e.g. AI Customization) and post the log if it fails?
Samsung TV Remote Tester report
app 0.3.0 · driver 2.4.5 · hub firmware 2.5.2.139
TV: QN55QN88BAFXZC · platform 22_PONTUSM_QTV · API 2.0.25 · Frame false · token auth true · PowerState true · SmartThings setting off
run: done · polling 60 s · slowest log read 2583 ms
TV differs: the TV does something the driver doesn't assume · driver differs: the driver didn't act on what the TV sent
  1. Device info — as expected
    keyCount=29 frameKey=true deviceKeys=EdgeBlendingSupport,EdgeBlendingSupportGroup,FrameTVSupport,GamePadSupport,ImeSyncedSupport,Language,OS,PowerState,TokenAuthSupport,VoiceSupport,WallScreenRatio,WallService,countryCode,description,developerIP,developerMode,duid,firmwareVersion,id,ip,model,modelName,name,networkType,resolution,smartHubAgreement,type,udn,wifiMac tokenKey=true powerState=on powerStateReported=true apiVersion=2.0.25 restStatus=200 isSupport={"remote_available":"true","DMP_DRM_WIDEVINE":"false","remote_touchPad":"true","remote_voiceControl":"true","EDEN_available":"true","DMP_DRM_PLAYREADY":"false","DMP_available":"true","ImeSyncedSupport":"true","FrameTVSupport":"false","TokenAuthSupport":"true","remote_fourDirections":"true"} restMs=23 deviceInfo={"OS":"Tizen","developerMode":"0","GamePadSupport":"true","description":"Samsung DTV RCR","FrameTVSupport":"false","type":"Samsung SmartTV","TokenAuthSupport":"true","WallService":"false","resolution":"3840x2160","modelName":"QN55QN88BAFXZC","VoiceSupport":"true","Language":"en_US","ImeSyncedSupport":"true","model":"22_PONTUSM_QTV","smartHubAgreement":"true","firmwareVersion":"Unknown","networkType":"wired","PowerState":"on","WallScreenRatio":"-1"}
  2. Remote socket — as expected
    handshake=ms.channel.connect keySent=true tokenInReply=true connectMs=1801 openEvent=true
    lines:
    12:59:46.685 rx remote: {"data":{"clients":[{"attributes":{"name":"","token":""},"connectTime":1792256312674,"deviceName":"","id":"e263b65-88ad-409f-8842-1be9a727a347","isHost":false},{"attributes":{"name":"","token":""},"connectTime":1792256323573,"deviceName":"","id":"xxxxxxx-xxxx-xxxx-xxxxxxxxx","isHost":false},{"attributes":{"name":"","token":""},"
  3. Key burst — as expected
    keysSent=3 opens=1
  4. Apps — skipped: the device has no app code for YouTube or Netflix (turn on its app search, or link SmartThings)
  5. App list — TV differs (answered)
    answered=false apps=null
    trace:
    13:00:13.874 tx remote: {"method":"ms.channel.emit","params":{"event":"ed.installedApp.get","to":"host"}}
  6. Discovery — as expected
    result=found keys=acl,at,deviceid,features,fex,flags,fv,gcgl,gid,integrator,manufacturer,model,pi,pk,protovers,psi,rsf,serialNumber,srcvers model=QBQ85D
  7. Art mode — skipped: not a Frame TV
  8. Power off — as expected
    offEvent=true noFlap=true offMs=1059 wentAway=REST stopped, PowerState standby restAfterOffS=7
  9. Standby check — skipped: the TV reports PowerState, so the driver doesn't probe
  10. Power on — as expected
    onEvent=true onMs=20097 wolSends=3 firstAnswerMs=20094
mock profile (for the maintainer):
"deviceInfo": {
"OS": "Tizen",
"developerMode": "0",
"GamePadSupport": "true",
"description": "Samsung DTV RCR",
"FrameTVSupport": "false",
"type": "Samsung SmartTV",
"TokenAuthSupport": "true",
"WallService": "false",
"resolution": "3840x2160",
"modelName": "QN55QN88BAFXZC",
"VoiceSupport": "true",
"Language": "en_US",
"ImeSyncedSupport": "true",
"model": "22_PONTUSM_QTV",
"smartHubAgreement": "true",
"firmwareVersion": "Unknown",
"networkType": "wired",
"PowerState": "on",
"WallScreenRatio": "-1"
"isSupport": {
"remote_available": "true",
"DMP_DRM_WIDEVINE": "false",
"remote_touchPad": "true",
"remote_voiceControl": "true",
"EDEN_available": "true",
"DMP_DRM_PLAYREADY": "false",
"DMP_available": "true",
"remote_fourDirections": "true"
"apiVersion": "2.0.25",
"handshake": "ms.channel.connect",
"connectMs": 1801,
"answered": false,
"apps": null,
"wentAway": "REST stopped, PowerState standby",
"restAfterOffS": 7,
"airplay": {
"model": "QBQ85D"
"otherMessages": ""
Driver Version 2.4.5: Getting more information:
@jbwrd3 thanks for the report. Everything the driver depends on behaved as expected on the QN88B. The app-list request going unanswered is a known difference (my 2020 TV doesn't answer it either). To exercise the Apps test, turn on Scan for App Codes in the device preferences, save, and run the tester again.
@KurtSanders thanks, the log shows the fix working: picture and sound mode now update on each poll. It also showed that Save Preferences with the TV off got only Standard as a sound mode. 2.4.6 refreshes the mode lists while the TV is on. If you get a chance, try Set Picture Mode with AI Customization.
@hubitrep I just installed your latest driver on my 2026 83" SAMSUNG QN83S95HAEXZA 4K OLED. Looks like it worked as expected. Only comments are with the values in these two fields. I would rather see the value be SpectrumTV.
nowPlaying: null: sNUyBbfvHf.SpectrumTV
tvChannelName: sNUyBbfvHf.SpectrumTV
Your TV reports an empty channel while an app is playing, where older TVs don't, so that triggered a bug in the code. 2.4.7 fixes that: after you next switch apps, appName should show the app, and nowPlaying reads app: <name> after a Refresh. tvChannelName keeps the code SmartThings reports, whatever it is, as on other TVs.
@hubitrep Upgraded to latest: 2.4.7.
I did not see appName in these attributes? What am I missing?
Sorry, 2.4.7 only looked up the app when the code changed, and your device already had it from 2.4.6, so appName was never set (hence "app: null"). 2.4.8 fixes that: update, then Refresh while Spectrum is playing. appName should then show the app, and nowPlaying reads app: . If appName stays blank, turn on debug logging, Refresh, and post the updateAppName log line.
Worked! :clap:
I have the beta package working with my Samsung QN95B connected via Ethernet.
Feedback:
  • The instructions should probably mention that Airplay needs to be enabled
  • The driver should probably have a more robust IP field string handler (I had a leading space by accident when I cut the IPA from the logs, and this was throwing an exception as not being a valid IP address)
  • The "wake on lan" command appears to not be working (see logs below). I made sure that this was IP remote was enabled in Network Connection settings, and re-ran the test with the below results. I can turn the TV on with the SmartThings app.
Thanks ya'll ! Will let you know if I see any other issues or room for improvement.
Report:
app 0.3.1 · driver 2.4.8 · hub firmware 2.5.2.139
TV: QN75QN95BAFXZA · platform 22_PONTUSM_QTV · API 2.0.25 · Frame false · token auth true · PowerState true · SmartThings setting off
run: done · polling 60 s · slowest log read 163 ms
    keyCount=29 frameKey=true deviceKeys=EdgeBlendingSupport,EdgeBlendingSupportGroup,FrameTVSupport,GamePadSupport,ImeSyncedSupport,Language,OS,PowerState,TokenAuthSupport,VoiceSupport,WallScreenRatio,WallService,countryCode,description,developerIP,developerMode,duid,firmwareVersion,id,ip,model,modelName,name,networkType,resolution,smartHubAgreement,type,udn,wifiMac tokenKey=true powerState=on powerStateReported=true apiVersion=2.0.25 restStatus=200 isSupport={"remote_available":"true","DMP_DRM_WIDEVINE":"false","remote_touchPad":"true","remote_voiceControl":"true","EDEN_available":"true","DMP_DRM_PLAYREADY":"false","DMP_available":"true","ImeSyncedSupport":"true","FrameTVSupport":"false","TokenAuthSupport":"true","remote_fourDirections":"true"} restMs=16 deviceInfo={"OS":"Tizen","developerMode":"0","GamePadSupport":"true","description":"Samsung DTV RCR","FrameTVSupport":"false","type":"Samsung SmartTV","TokenAuthSupport":"true","WallService":"false","resolution":"3840x2160","modelName":"QN75QN95BAFXZA","VoiceSupport":"true","Language":"en_US","ImeSyncedSupport":"true","model":"22_PONTUSM_QTV","smartHubAgreement":"true","firmwareVersion":"Unknown","networkType":"wired","PowerState":"on","WallScreenRatio":"-1"}
  2. Remote socket — TV differs (connectMs, otherMessages)
    handshake=ms.channel.connect keySent=true otherMessages=ms.error tokenInReply=true connectMs=6618 openEvent=true
    trace:
    08:55:25.066 ws remote: status: open
    08:55:28.089 tx remote: {"method":"ms.remote.control","params":{"Cmd":"Click","DataOfCmd":"KEY_HOME","Option":"false","TypeOfRemote":"SendRemoteKey"}}
    08:55:28.106 rx remote: {"data":{"message":"No Authorized"},"event":"ms.error"}
    08:55:31.684 rx remote: {"data":{"clients":[{"attributes":{"id":"","name":"","token":""},"connectTime":1794063301109,"deviceName":"","id":"","isHost":false},{"attributes":{"name":"","token":""},"connectTime":1794063325581,"deviceName":"","id":"","isHost":false}],
    keysSent=3 opens=1
    trace:
    08:55:49.902 tx remote: {"method":"ms.channel.emit","params":{"event":"ed.installedApp.get","to":"host"}}
    result=found keys=acl,at,deviceid,features,fex,flags,fv,gcgl,gid,integrator,manufacturer,model,pi,pk,protovers,psi,rsf,serialNumber,srcvers model=QBQ95
    offEvent=true noFlap=true offMs=1074 wentAway=PowerState standby restAfterOffS=22
  10. Power on — driver differs (onEvent); TV differs (onMs)
    onEvent=false onMs=null wolSends=3 firstAnswerMs=2680
    trace:
    08:57:39.368 wol: sent
    08:57:42.040 rest: status=200 ms=16 PowerState=standby
    08:57:49.380 wol: sent
    08:57:49.399 rest: status=200 ms=17 PowerState=standby
    08:57:59.394 wol: sent
    08:57:59.412 rest: status=200 ms=17 PowerState=standby
    08:58:42.029 rest: status=200 ms=15 PowerState=standby
"deviceInfo": {
"OS": "Tizen",
"modelName": "QN75QN95BAFXZA",
"PowerState": "on",
"isSupport": {
"connectMs": 6618,
"answered": false,
"apps": null,
"wentAway": "PowerState standby",
"restAfterOffS": 22,
"airplay": {
"model": "QBQ95"
"otherMessages": "ms.error"
Thanks, I've added your test dump to the test harness and deployed a new version. Details below, from the clanker.
Note that the next platform release 2.5.3.x will have a built-in integration for Samsung TVs. I may continue to update this integration if there is value and interest beyond what the built-in offers.
Thanks for the report and the feedback. 2.4.9 is out:
  • Keys lost: your TV takes over 6 s to accept the connection and refuses keys until then (the ms.error in test 2). The driver now sends them again once it does, which also covers Off sent while the connection is closed.
  • IP field: spaces around the address are removed on Save.
  • AirPlay: the install notes now list the TV settings the driver needs: AirPlay (to find the TV; not needed if you type the IP), plus Power On with Mobile and IP Remote under Settings → General → Network → Expert Settings.
Power on is still open. Your TV stays on the network in standby but ignored all three Wake-on-LAN packets. Could you check:
  1. Is Power On with Mobile on?
  2. On the device page, under Data, is deviceMac the same MAC your router shows for the TV's IP? No need to post it, just whether they match.
  1. Yes, "Power On with Mobile" is selected.
  2. Yes, the MACs match.
I feel like I have to apologize for my flakey TV. :slight_smile: I imported the new Samsung TV Remote Tester Apps Code (now 0.3.2), but I didn't see an updated 2.4.9 in HPM (still running 2.4.8).
Edti: I see the update. Will re-run shortly.
app 0.3.2 · driver 2.4.9 · hub firmware 2.5.2.139
run: done · polling 60 s · slowest log read 134 ms
keyCount=29 frameKey=true deviceKeys=EdgeBlendingSupport,EdgeBlendingSupportGroup,FrameTVSupport,GamePadSupport,ImeSyncedSupport,Language,OS,PowerState,TokenAuthSupport,VoiceSupport,WallScreenRatio,WallService,countryCode,description,developerIP,developerMode,duid,firmwareVersion,id,ip,model,modelName,name,networkType,resolution,smartHubAgreement,type,udn,wifiMac tokenKey=true powerState=on powerStateReported=true apiVersion=2.0.25 restStatus=200 isSupport={"remote_available":"true","DMP_DRM_WIDEVINE":"false","remote_touchPad":"true","remote_voiceControl":"true","EDEN_available":"true","DMP_DRM_PLAYREADY":"false","DMP_available":"true","ImeSyncedSupport":"true","FrameTVSupport":"false","TokenAuthSupport":"true","remote_fourDirections":"true"} restMs=34 deviceInfo={"OS":"Tizen","developerMode":"0","GamePadSupport":"true","description":"Samsung DTV RCR","FrameTVSupport":"false","type":"Samsung SmartTV","TokenAuthSupport":"true","WallService":"false","resolution":"3840x2160","modelName":"QN75QN95BAFXZA","VoiceSupport":"true","Language":"en_US","ImeSyncedSupport":"true","model":"22_PONTUSM_QTV","smartHubAgreement":"true","firmwareVersion":"Unknown","networkType":"wired","PowerState":"on","WallScreenRatio":"-1"}
handshake=ms.channel.connect keySent=true tokenInReply=true connectMs=1458 openEvent=true
lines:
 17:27:44.665 rx remote: {"data":{"clients":\[{"attributes":{"name":"<name>","token":"<token>"},"connectTime":1794094063007,"deviceName":"<name>","id":"<id>","isHost":false}\],"id":"<id>"},"event":"ms.channel.connect"}
keysSent=3 opens=1
8. Apps — skipped: the device has no app code for YouTube or Netflix (turn on its app search, or link SmartThings)
9. App list — TV differs (answered)
trace:
 17:28:03.130 tx remote: {"method":"ms.channel.emit","params":{"event":"ed.installedApp.get","to":"host"}}
10. Discovery — TV differs (result)
result=other
trace:
 17:28:19.988 mdns: name=<name> ip=<ip> manufacturer=Samsung model=HW-Q990C keys=acl,deviceid,features,flags,fv,gcgl,gid,manufacturer,model,pi,pk,protovers,rsf,serialNumber,srcvers
 17:28:27.006 No Samsung TV answered. The TV must be on, on the same network as the hub, with AirPlay on. 2016-2017 TVs need the IP typed.
 17:28:28.024 rest: status=200 ms=13 PowerState=on
4. Power off — as expected
offEvent=true noFlap=true offMs=1051 wentAway=REST stopped, PowerState standby restAfterOffS=6
6. Standby check — skipped: the TV reports PowerState, so the driver doesn't probe
5. Power on — driver differs (onEvent); TV differs (onMs)
onEvent=false onMs=null wolSends=3 firstAnswerMs=10042
trace:
 17:29:51.722 wol: sent
 17:30:01.737 wol: sent
 17:30:01.756 rest: status=200 ms=16 PowerState=standby
 17:30:11.833 wol: sent
 17:30:11.852 rest: status=200 ms=13 PowerState=standby
 17:30:28.025 rest: status=200 ms=12 PowerState=standby
"deviceInfo": {
    "OS": "Tizen",
    "PowerState": "on",
"isSupport": {
"connectMs": 1458,
"answered": false,
"apps": n
ull,
"restAfterOffS": 6,
"otherMessages": ""
Follow-up: this might be exactly what you said, but the wake on lan does work. The issue I see is that after turning the TV off, there is about a 6 second time where the Samsung One Connect box is shutting down and will not respond to the WoL. If I just wait, then issue the on command the TV does come on.
2.4.10 is out, in HPM and on GitHub. The driver is unchanged (2.4.9); this release is the Tester (0.4.0).
  • Opens in its own page. Open the Tester app and click Open tester. Each test shows as it runs, with a countdown to the end of the step it waits on.
  • Questions only you can answer appear next to the test: Allow on the TV, whether the Home screen showed, the screen went off, the picture came on, art shows, the app opened, AirPlay is on. Turn off I'm at the TV to run it with no questions.
  • It also asks about two settings the TV doesn't report (Power On with Mobile, IP Remote), checks the device's MAC against the TV and the hub, and reads the TV's status every 5 s around power off and on.
  • A remote with every driver command, plus Send key, works outside a run. Its log shows what the TV answered to each press.
