After running the existing Ring polling integrations and finding them too slow and complex to configure, I built a new integration from scratch. It's been running in my home for a few months and I'm ready to share it.
GitHub: https://github.com/thaeropath/Hubitat_Ring_Integration
What it supports
| Ring Device | Events → Hubitat | Commands ← Hubitat |
| Camera / Doorbell | motion active/inactive, doorbell ding | — |
| Contact sensor | open / closed | — |
| Alarm hub PIR motion sensor | motion active/inactive | — |
| Ring Alarm | armed-away, armed-home, disarmed + who triggered | arm away, arm home, disarm |
| Door lock | locked / unlocked + who triggered | lock, unlock |
| Smart light (Ring Bridge) | on/off, brightness level | on, off, set level |
Alarm hub devices (contact sensors, PIR motion sensors, locks, alarm mode, Ring Bridge lights) are delivered in real time via Ring's alarm hub WebSocket — no polling. Camera motion and doorbell ding use FCM push notifications with a REST polling fallback every 20 seconds for networks where push is unavailable.
How it works
A small Node.js bridge server runs on your local network — Raspberry Pi, NAS, or any always-on machine with Docker. It holds a persistent WebSocket connection to Ring's cloud using the excellent ring-client-api library and pushes events directly to a custom endpoint on the Hubitat hub. No Maker API needed — the integration app creates its own OAuth endpoint.
Ring Cloud ──(WebSocket)──► Bridge Server ──(HTTP POST)──► Hubitat Hub
└───────────(HTTP POST)────────┘
commands (arm, lock, etc.)
Installation
Available in Hubitat Package Manager — search for Ring Integration. Full manual install instructions and troubleshooting are in the README.
Configuration notes worth knowing before you start
Alarm hub devices load async — after starting the bridge, wait for the
✔ Ready for Hubitat device discoverylog line (~10 seconds) before running discovery in Hubitat. Running it too early will miss sensors and locks. -
Camera motion requires port 5228 — FCM push needs outbound TCP to
mtalk.google.com:5228. If your router blocks it, setCAMERA_PUSH=falsein.envand the polling fallback takes over automatically. -
Alarm control is optional — set
ALARM_CONTROL=falsein.envto make the alarm read-only from Hubitat (mode still reports; arm/disarm commands are blocked at the bridge). -
Ring token rotation is automatic — Ring invalidates the refresh token after every authentication. The bridge detects this, saves the new token to disk, and continues without interruption.
What I'm looking for feedback on
Testing on different Ring account configurations (multiple locations, different device mixes)
Whether HPM install and update flow works cleanly
Any Ring device types not currently recognized
Happy to answer questions. Full README with troubleshooting tips is at the GitHub link above.
Tested on: Hubitat C-8, Docker on macOS (validates the Docker/ARM64 image), ring-client-api v14.3.0
