The new version of MyEcobeeDevice (v6.4) corrects the supportedThermostatModes and supportedThermostatFanModes attributes in order for them to be compatible with Hubitat's dashboards.
All you need to do is to copy &paste the new code over the existing device's code under the IDE and save.
Related "complimentary" smartapps at my github (see all use cases supported below):
All Hubitat thermostat capabilities are exposed for easier integration with Rule Engines (Rule Machine, WebCore or others)
My Ecobee device takes full advantage of the ecobee features, and does not create temporary holds for no reason.
You can leverage my ecosystem of smartapps which was mostly built upon the following principle: ecobee is responsible for the scheduling and Hubitat manages any exceptions to your regular schedules (ex. you're away when you are usually at home, or back home when you're usually away).
Hello,
I recently purchased an ecobee premium with air quality monitoring. I cant figure out how to access the "Air quality" information specifically through my hubitat. I have successfully "integrated" the ecobee into my hubitat but cannot see "Air quality" info listed in any of the data, only temp and humidity. At this point I literally have to go to the thermostat itself and look or open the ecobee app to see that information. I have emailed ecobee for more info. I purchased this thermostat with the hopes to set up rules in hubitat to be able to say turn on a fan when my CO2 levels get too high. As you understand the coding behind this thing, is this a possibility currently or something I need to bug ecobee about?
**Update - ecobee support has advised the following.
"Unfortunately, ecobee thermostat premium for air quality does not yet have the capabilities to integrate with hubitat system. However, I would be happy to put one as a feature request. We would also like you to contact hubitat and ask them to work with us on this as well."
Just thougth I'd drop a shout out to @yracine66 in the thread. I had a weird situation, and he worked it realtime with me by email. A few test driver versions later, working flawlessly. Thanks!
