Hi @silverton38 , I have a C7 with the latest version, and everything works as described in the Readme.
Please follow all the steps in the Readme, and especially, the following.
There is still an oAuth button in the App code submenu of the IDE. You then need to click
on the smartapp and you should see its code and the oAuth button in the upper right corner.
2) Create a new smartapp (My ecobee Init)
go to http://192.168.xx.xx/app/list (insert your own hub's IP address)
a) Hit the "+New App" at the top right corner
b) Copy and paste the code from the corresponding txt file in the zip
c) Hit the save button on the right inside of the screen
d) Make sure to enable OAuth in Smartapp is active (click oAuth in the upper right corner)
- Hit "Update" at the bottom
If the instructions above are not clear enough, you can refer to the troubleshooting section below with some pictures:
http://thingsthataresmart.wiki/index.php?title=My_Ecobee_Init#Issue_.231:_I_don.27t_know_how_to_create_a_custom_smartapp
Regards.
