[Release] Reolink Integration - Cameras, Doorbells, NVRs & Home Hubs
There are two versions:
  1. Built-in (what you have): this comes with the Hubitat platform and updates through Hubitat’s own platform releases. gopher.ny pulls fixes from my code into the built-in version, so the fixes in 1.6.14 to 1.6.16 will reach you in a future Hubitat update. You don’t need to do anything, just keep your hub updated.
  2. Community (HPM): this is my version on GitHub, installed through Hubitat Package Manager. It gets fixes first, as soon as I release them.
The built-in version isn’t a different integration. It’s the same code, built from the same GitHub source, but it follows Hubitat’s release schedule instead of mine.
You can switch to the HPM version if you want fixes sooner, but it isn’t an in-place upgrade. They’re separate apps, so you’d remove your devices from the built-in version and add them again in the HPM version. Please don’t run both against the same cameras at once, or each camera gets two connections and duplicate devices.
For most people on the built-in version, waiting for the next Hubitat update is the easiest path.
Release: Reolink Integration v1.6.17
Tidier main page banner.
Problem:
The status banner at the top of the main page had extra space above it, a heavier border and a larger icon than Hubitat's built-in apps, and it got cramped on a phone.
The Fix:
Spacing and size now match the built-in apps, and the banner stacks cleanly on narrow screens. Cosmetic only.
Action needed:
HPM users: update through HPM now.
Built-in users: no action needed, fixes come with a future Hubitat platform update (possibly sooner on beta firmware).
Thanks to @gopher.ny for the PR.
I assume this is just a red herring as I have Connected in the app?
Possibly. Check the time.
Maybe a backup? Or maybe a reset if your in a zone for time change ?
We don't have a time change.
Maybe it was expecting one. Time is correct on the hub.
Things like this make me nervous. :wink:
On a reboot I get about 60-70 of these p2p entries in Pi-Hole.
How much of Reolink is really local? Is this just the authentication stuff but everything else is private
Reolink states that these P2P servers only handle the registration, connection setup, and authentication.
The actual video stream is encrypted end-to-end between the camera and your phone.
Thanks. There sure are a lot of them.
