[RELEASE] Pixelblaze addressable LED Controller Driver v1.00
So I FINALLY got around to installing my LED strip around my deck with my pixelblaze.
Has anyone automated patterns for different holidays?
I run the Holiday Lighting app [Release] Holiday Lighting
and cycle my hue bulbs different colors for the holidays. I got it to make my LED strip a solid color, but I'm struggling on picking a pattern. The only thing I can think of is a big Rule Machine rule with all the holidays listed out in it with each pattern.
Hi, I've got this setup and working. However I'm noticing an issue. Tangentially related, to the work I did with firestorm, I noticed that it would flood the websockets on the pixelblaze, and it would eventually just stop responding Firestorm with HWv3.6 PB(SWv3.30) using Sensor Expansion after standby PB is unresponsive until PB reboot and disconnecting Firestorm - #4 by thatcalifire - Troubleshooting - ElectroMage Forum.
I'm seeing the exact same behavior with this plugin. Can this be investigated? Or any idea on how to troubleshoot this from the hubitat side?
I can power off the device, and it seems to reset things and the Pixelblaze UI will start responding again. Reinitializing doesn't seem to do anything.
dev:2362025-03-09 12:56:01.516 PM debug sent ping but didn't receive pong within 30000ms (after 262 successful ping/pongs)
dev:2362025-03-08 10:01:29.299 PM debug sent ping but didn't receive pong within 30000ms (after 305 successful ping/pongs)
