[RELEASE] Pihole Integration - Monitoring & Management
Presenting a complete Pihole Integration. Already available in HPM, this Integration App+Drivers allows you to add and support single or multiple Pihole servers, including group management.
What you get
For each Pihole, one Hubitat device exposing:
  • Blocking — on/off as a standard switch, with an optional timer that Pihole itself reverses
  • Queries — total, blocked, percent blocked, forwarded, cached, per second
  • Clients — active now and seen in total
  • Blocklist — size, when it was last rebuilt, top domains and clients
  • Host health — CPU temperature, load, memory, uptime
  • Versions — Core, FTL and Web, plus whether an update is waiting
  • Diagnostics — online/offline, Pihole's own warning count, last error
Everything is a standard Hubitat attribute, so it all works in Rule Machine, dashboards, and any other app.
The app adds notifications when a Pihole stops responding, when blocking is turned off, when an update appears, and when your block rate falls below a threshold you set — often the first sign a device is bypassing your DNS.
I hope those of you looking to merge home networking and smart home functionality together appreciate it!
Cheer!
:clap: Nice work, installed like a charm!
Now I gotta get me a raspberrypi! Been wanting to use pihole for the longest. Nice work!
Let me give this a spin …
L.E. I submitted a PR.
