[RELEASE] Pebble Watch App - Hubitat Control
Hello everyone! Here is my newest development - a Pebble watch app that allows you to control your Hubitat devices via the Maker API. It is available on the Pebble Appstore. There are no apps or drivers to install in Hubitat except for the built-in Maker API.
It was created with security and efficiency in mind. The README is copied below, but is maintained here. I have a limited set of devices currently, as I am moving, but feel free to test it out and report back. I will be making a sister post on the Pebble side as well.
Here is the Pebble App Store link.
Hubitat Control
Control your Hubitat home from your wrist.
A Pebble watch app for lights, dimmers, speakers, locks, garage doors, shades and
sensors, talking to your hub through its built-in Maker API app — over your
home network, or through Hubitat's cloud relay when you are out.
No account, no third-party service, no bridge to install. Your hub and your phone
are the only things involved.
Features
  • Every device on one list, with its current state — On - 75%, Locked,
    Closed, 72°.
  • One-button control. Select toggles; up and down drive dimmers, volume and
    shade position.
  • Local or Cloud, switchable from the watch itself — no digging through phone
    settings when you leave the house.
  • Fast. The device list is cached, so the menu is on screen before the
    network is touched. Live states load in behind it.
  • Careful with your credentials. The watch never holds your access token, and
    the app refuses to send it to a network that has not proven it is your own.
  • Careful with your battery. Nothing polls, nothing runs in the background,
    and the app closes itself after a minute rather than sitting open on your wrist.
Supported watches
Every Pebble ever made, including the new ones.
Watch Screen
Pebble Classic / Steel 144×168 black & white
Pebble Time / Time Steel 144×168 colour
Pebble Time Round 180×180 round colour
Pebble 2 144×168 black & white
Pebble Time 2 200×228 colour
Pebble 2 Duo 144×168 black & white
Pebble Round 2 260×260 round colour
What you need
  • A Hubitat Elevation hub on your network.
  • A Pebble watch, paired to the Pebble phone app.
  • Five minutes to turn on Maker API and paste two URLs.
Setting it up
1. Expose your devices in Hubitat
  1. In the hub's web interface, go to Apps → Add Built-In App → Maker API.
  2. Under Select Devices, pick every device you want on the watch. Only these
    are ever visible to the app.
  3. Turn on Allow Access via Local IP Address. If you want control while away
    from home, also turn on Allow Access via Cloud.
  4. Click Done, then reopen the app. Near the bottom it lists example URLs.
    The two you want are both labelled Get All Devices:
    http://192.168.1.10/apps/api/34/devices?access_token=xxxxxxxx-xxxx-…
    https://cloud.hubitat.com/api/<hub-id>/apps/34/devices?access_token=xxxxxxxx-xxxx-…
2. Configure the watch app
Open the app's settings from the Pebble phone app and paste those two URLs into
Local URL and Cloud URL, exactly as the hub printed them. The address,
app id and access token are read out of them — there is nothing to assemble by
hand.
Then set Cloud Access Available to match whether you enabled Allow Access via
Cloud
above, pick a starting Control Mode, and save. If you have no cloud
access, leave the Cloud URL blank and turn that setting off — the app will run
Local-only and say so.
Your access token is a password for every device you selected. Anyone who
has it can unlock what it can unlock. Treat the settings page like a password
field, and see Security for what the app does to protect it.
Using it
Main menu
Row What it does
Devices Opens the device list. The subtitle shows how many were found.
Refresh Devices Re-reads the hub from scratch. Use after adding a device in Hubitat, or to retry after an error.
Connection Switches Local ⇄ Cloud. Reads Local only when no cloud route is configured.
Status What the link last did, or why it failed. Select re-reads all states.
Device list
Button Action
Up / Down Move through the list
Select Open the device
Hold Select Toggle a switch, plug or light without opening it
Back Leave the app
Hold-to-toggle deliberately does not act on locks, garage doors or door
controls — holding select on one of those opens its screen instead, so unlocking
is always something you chose to do. See Locks and doors.
Device screen
Button Switch / Lock / Door Dimmer / Volume / Shade Sensor
Select Toggle on ⇄ off Toggle on ⇄ off Re-read now
Up Turn on / lock / open Raise the level —
Down Turn off / unlock / close Lower the level —
Holding up or down repeats. The level is sent once you stop moving it, so
dragging a dimmer from 10% to 80% is one command to your hub, not fourteen.
Momentary buttons fire on a single Select, with a short buzz to confirm.
It closes itself
After a minute with no button pressed, the app closes and hands the screen
back to your watchface. Any press starts the minute again — moving through the
list, opening a device, or coming back from one.
This is deliberate. A control app is something you use for a few seconds and walk
away from, and one left open on your wrist keeps the watch awake for no reason.
Readings arriving from your hub do not count as activity: the app closes because
you stopped using it, not because the hub went quiet.
Settings
All of these live on the app's settings page in the Pebble phone app.
Hub
Setting Default What it does
Local URL — The http:// example URL from Maker API, with your hub's IP
Cloud URL — The https://cloud.hubitat.com example URL
Control Mode Local Which route to start on
Device list
Show Read-Only Devices On Include sensors and meters, which display a reading but take no commands
Order By name By name, by type then name, or the hub's own order
Dimmer / Volume Step 5% How far one press of up or down moves a level (1–25%)
Away from home
Cloud Access Available On Turn off if your hub has no cloud access. The app becomes Local-only.
VPN To Home Network Off Turn on if you use a VPN home, so Local is expected to work while away
Verify Hub Before Sending Token On The safeguard described in Security. Leave it on.
Locks and doors
Allow Locks And Doors In Shortcut Off Lets hold-to-toggle unlock doors and open garages. Read the warning first.
Devices it understands
Worked out from the capabilities your hub reports, most specific first.
Capability Shown as Select Up / Down
Lock Lock lock / unlock lock / unlock
GarageDoorControl, DoorControl Door open / close open / close
WindowShade Shade open / close set position
AudioVolume, MusicPlayer Volume on/off, or mute/unmute if it has no switch set volume
SwitchLevel Dimmer on / off set level
Switch Switch on / off on / off
Momentary, PushableButton Button push —
anything else Sensor re-read —
Read-only devices show their most interesting reading — temperature, motion,
contact, presence, humidity, illuminance, power, battery and a few more, in that
order. Turn off Show Read-Only Devices to leave them out entirely.
What gets fetched, and when
The hub is asked for its device list once, and that list is then reused:
  • First launch reads every device, works out what each one is, sends the list
    to the watch and caches it.
  • Later launches send the cached list straight to the watch, so the menu is up
    before the network is touched — then read live states and fill them in.
  • The cache is dropped when you choose Refresh Devices, save the settings, or
    change hub or token.
  • States are never cached. They are read fresh every launch.
A device added in Hubitat after the list was cached will not appear until you
choose Refresh Devices. That is the design, not a bug.
Security
Your token, and public networks
The Maker API access token is a key to every device you exposed. In Local
mode it is sent to a private address like 192.168.1.10 — and on a café, hotel
or airport network, that address very often belongs to somebody else's machine.
So Local mode has to prove it is on the right network first. Before any token
moves, the app makes one token-free request to the hub's address. A real hub
identifies itself by refusing an unauthenticated caller (401/403) or by
answering JSON. Silence, a timeout, or a captive portal answering with HTML all
count as not home, and your token is never sent.
What happens then depends on your settings:
Cloud access VPN Away from home
Yes either Falls back to Cloud automatically — Away - using Cloud
No Yes Stops: Not home - connect VPN
No No Stops: Not on home network
In the last two it genuinely stops — the verdict is cached, so nothing further is
attempted. The app will not poll a network it should not be on. Refresh
Devices, switching Local/Cloud, or saving settings all re-check immediately, so
walking back in the door costs one button press.
The URL itself is checked
A token is never sent in clear text anywhere it could leave your network. A URL
is refused outright, with the reason shown on the watch, when it is:
  • http:// to anything that is not a private address. Accepted: 10.x,
    172.16–31.x, 192.168.x, 127.x, 169.254.x, a bare hostname, or a
    .local / .lan / .home / .internal name. A public IP or a real domain is
    not.
  • missing its access_token, or not http(s) at all.
So pasting the cloud URL as http:// instead of https://, or pointing the
local URL at a public address, fails closed rather than quietly leaking the key
to your house.
Locks and doors
Hold-to-toggle on the device list does not act on locks, garage doors or door
controls. A long press is easy to make by accident, and unlocking a front door is
the one action here with a physical consequence — so holding select on one opens
its screen instead. The press still does something useful, and nothing
irreversible.
Allow Locks And Doors In Shortcut turns that off if you want it. Be clear
about what you are choosing: one long press on a list row can then unlock your
door or open your garage, with nothing to confirm it.
Actions do not fire late
If the watch loses Bluetooth just as you press something, that press does not sit
around waiting for the link to come back.
  • A momentary blip — a second or two — resumes as you would expect, and the
    press is delivered.
  • Anything longer than about ten seconds and the press is discarded. You
    have walked away; a command you gave before losing the link is no longer a safe
    statement of what you want now, and an unlock arriving minutes later behind
    your back is exactly the wrong outcome.
On reconnecting after a real absence the watch says Dropped stale actions and
re-reads every device, so what you see is the state of your home now rather than
whatever it assumed before the link went down.
What this cannot protect against
Stated plainly, because security features that oversell themselves are worse than
none:
  • The probe proves something at that address behaves like a hub — not that it
    is yours.
    A hostile access point that deliberately answers JSON could still
    pass it. This removes the everyday risk of a stranger's router or NAS quietly
    receiving your token; it does not defeat a targeted attacker. If that is your
    threat model, use Cloud away from home, or a VPN.
  • Local mode is plain HTTP. Hubitat's Maker API offers no local TLS, so on
    your own network the token travels in clear text and anything else on that
    network could read it. This is a property of the hub's API, not of this app.
    If you suspect exposure, regenerate the token in the Maker API app and re-save
    your settings here.
  • The settings page shows your token, because it holds the URL you pasted.
    Anyone with your unlocked phone can read it.
  • The cached device list on your phone holds device names, which describe your
    home. No credentials, but not nothing.
The watch itself never holds your token, never makes a network request, and
remembers only which mode you last chose.
Battery
The app is entirely event-driven. Nothing polls, and nothing runs in the
background on either device
— no sensor subscriptions, no periodic refresh, no
checking in with the hub — and the phone-side code shuts down with the watch app,
so a closed app costs nothing at all. Sitting on an open menu, the only thing
scheduled is the timer that closes the app.
Action Cost
Launch one read of all devices, plus the list and states to the watch
Open a device one read — skipped if states were refreshed in the last 20 s
Send a command the command, plus one confirming read once it settles
Drag a dimmer one command, not one per step
Idle nothing
It also does not stay open — see It closes itself. That is
the single biggest saving available to a watch app, because an app left running
keeps the watch out of the low-power state its watchface sits in.
Failure paths are where a home-control app usually drains a battery, so both are
capped:
  • Watch out of range of the phone. The watch stops transmitting rather than
    retrying into a dead link, and resumes automatically on reconnect. A press that
    did not make it is only delivered if the gap was momentary — see
    Actions do not fire late.
  • Phone with no signal, or in airplane mode. Local requests give up after 6
    seconds, and after three failures in a row the app stops trying for a minute,
    failing instantly with no radio use at all. Refresh Devices, switching mode, or
    saving settings clears that immediately.
  • A hub that answers with an error (a wrong token, say) is a settings problem, not
    a signal one, so it never trips the backoff and stays visible.
Troubleshooting
The watch says What it means
Set the local URL / Set the cloud URL Nothing pasted for the current mode. Check the settings page.
URL has no access token The URL was pasted without its ?access_token=… part. Copy the whole line from Maker API.
Refusing HTTP to a public address A http:// URL pointing somewhere off your network. Cloud URLs must be https://.
Not on home network You are away, and there is no cloud route configured. Turn on Cloud Access Available and add a Cloud URL.
Not home - connect VPN You are away with VPN selected — connect the VPN, then choose Refresh Devices.
Hub unreachable - try Cloud Local could not reach the hub. Use the Connection row to switch to Cloud.
Phone disconnected The watch has lost Bluetooth. It resumes on its own when the phone is back.
Dropped stale actions The link was down long enough that a queued press was discarded rather than delivered late. States are being re-read.
No devices exposed Maker API has no devices selected, or Show Read-Only Devices is off and everything you exposed is a sensor.
Local only on the Connection row No usable Cloud URL, or Cloud Access Available is off.
Cloud access is turned off You tried to switch to Cloud with that setting off.
The app closed on its own. That is the inactivity timeout, not a crash — a
minute with no button pressed and it returns you to your watchface. See
It closes itself.
A device is missing. The list is cached on purpose. Choose Refresh
Devices
after adding anything in Hubitat.
A device shows the wrong state. Choose Status → Select to re-read
everything, or open the device to re-read just that one.
Everything is slow on a big hub. Every launch reads all device states. Turn
off Show Read-Only Devices to cut the list down to things you can act on.
How it works
The watch holds no credentials and makes no network calls. It sends an operation
code over Bluetooth; the phone-side JavaScript owns the hub connection.
src/c/
  main.c              app lifecycle, routes updates to the open windows
  comm.c/.h           AppMessage transport, request queue, link state
  devices.c/.h        the device table and the wire-format parser
  main_menu.c/.h      devices / refresh / connection / status
  device_list.c/.h    the scrolling device list
  device_window.c/.h  one device's control screen
  idle.c/.h           the inactivity timeout that closes the app
  theme.h             colours, with monochrome fallbacks
src/pkjs/
  index.js            Maker API client, device classification, cache, safeguards
  config.js           settings page
Commands are semantic. The watch only ever sends on, off, level or
push. The phone translates each into the Maker API command that particular
device accepts, so adding a device type touches the JavaScript and one enum, not
every button handler.
Optimism, then correction. A press updates the watch immediately so the
screen never feels laggy; the phone then reads the device back once it has
settled — a second for a light, three for a lock — and pushes the real state.
Layout comes from the screen bounds, not the platform. Font sizes step with
screen width and round insets scale with the display, so a 260 px circle and a
144 px rectangle are both laid out correctly without per-model special cases.
The wire format. Devices cross in chunked records sized to whatever message
buffer the watch could allocate, which it reports at handshake along with how
many rows it can hold — 48 on the oldest hardware, 160 on the largest.
