[RELEASE] Patterns Plus - Create custom patterns with the Lifx Light Strip (and more)
Awesome!
For now yes. You can always install another instance of the parent app to control other strips. BUT, let me think about the best way to add more devices to the new code.
Great, looking forward to see what you'll come up with !
In preparation for the new version, please EXPORT all of your patterns. Once you update the app, the old version will NOT work but you will be able to convert each of your patterns to the new format.
The new version will be out in a couple of days. It's done, just going to give people a little time to export the patterns.
@yannick00000, new app supports up to 100 zones. Will that work for you? :grin:
Yes, Lifx as a maximum of 80 zones (10 strips).
New MAJOR update on Github... and a new name: Patterns Plus
1.1.0 - Major upgrade
Hi, is this still available? I've looked everywhere on your github with no luck and your link in the second post is returning a 404. Thanks in advance
Hi,
PP is now in Bundle Manager
@bptworld Bryan I notice in the app you mention the future possibility of adding custom colors. Love this app for a variety of use cases that would become eminently more doable if color choice was RGB, HSL, or the like. Is this in the cards?
New version...
1.1.3 - 09/03/22 - Added custom color option
I didn't test this so let me know if it blows up! :boom: :grinning:
One of these days, I’d love to understand how you do it. Not how you code; how you find the time.
Like many others around here, I’m incredibly grateful for your efforts. Will beta test and revert to you.
Bryan, started to play with custom color, but I think I’m missing something simple. Once you specify custom color for a given zone or group, it gives you options for level and delay, as expected. But how/where do you specify the custom color?
1.1.4 - 09/04/22 - Custom color attempt two
Looks like this is working perfectly, cheers. Will circle back if I notice anything odd.
@bptworld Bug: Setting things up.
Click device master list and click one device
Click Select device and pick device
Click Test Device switch get error
Log
App is completely pooched until removed and re-added to hubitat.
A debug log would help :upside_down_face:
Definitely something screwy going on there. I just installed a fresh copy to compare your screenshot and yours has several fields missing. Please try a fresh copy from Bundle Manager to see if this fixes it.
I did that. Removed, deleted the apps code (both main and child) and then reinstalled from bundle manager. Same thing I only screenshotted the lower part
I re-uploaded the bundle to Github.
PLEASE download the bundle again. Everything is there.
Same thing... deleted from apps code, reinstalled from bundle manager, repeated steps above. I don't know if it helps but the bulb is a Lifx bulb.
