[RELEASE] Package Explorer - For use with Hubitat Package Manager
New version on GitHub...
1.0.7 - 08/11/20 - Fixed an issue with category options
Since I was in the code anyway...
1.0.8 - 08/11/20 - Added search by Tag option
:wink:
Where I can find installation instruction ? Or it only can be installed true Hubitat Package Manager. ?
You can use Package Manager, but it isn't required. It is just much easier to use Package Manager than doing it manually. You will likely want Package Manager for other apps and drivers not just from Bryan, but from many other developers.
His Github is in the first post, there is no reason you couldn't import the code manually and then install the app. That is sort of outside the scope of this thread, See here for Custom App and Driver installation. Hubitat Elevation Documentation - Hubitat Documentation
I also have install instructions in my Docs folder on GitHub.
I think this should be the official package manager for Hubitat.
One more feature that would be helpful, show the diff if the current version has changed
(people make local customizations, and right now, it will be automatically override with the new version).
Thank you. I found it . Apps/ Package Explorer /
It’s a great app.
Can I ask for a cosmetic change? Uninstall and Update buttons (IMO) should be moved apart. Like update at the top followed by install. Looking at the screen with multi focal lenses makes me hit the “uninstall” more times than not vice the “update”. It seems that update would be the most used and uninstall should be about 3 up from the bottom. Again the app is a welcome tool that makes the updates easier.
You are posting in the wrong thread. This is not Hubitat Package Manager... This is Package Explorer. This is just a way to search the packages available. You can't install/uninstall/modify or anything else from here.
Please see the first post. :wink:
Yes, sorry. I updated Explorer in Manage.
I couldnt find install instructions for this app anywhere in the doc dir
It installs just like any other app. BUT read the first post in this thread, this app is no longer supported.
After some much needed updating, I am re-releasing this app!
1.1.0 - 01/27/22 - Major changes to make it work much better
@bptworld Feature Request/Change -
Today, I ran Package Explore 'Whats new'. the first 2 response I got were from a Dev that have a ~525 days old'. Could this be a problem in Package Explorer?
Regardless - I'd like to request that the What's New be modified to allow at least a few choices like 1 day, 7 days and 30 days. My argument for my request is that as thing have settled in the HE world for me, my need to see what has changed is no longer a weekly check I do, but a monthly event. Drivers and apps have settled as well and postings and updates are slowing which will lead to less often being updated.
Also along these lines - would it be useful to pull a report that shows 'apps and drivers updated in last xx days' that I could push onto a Notifications tile or in the Watchdog Tile somehow?
Thank you for what you do and your consideration!
an update to my Feature Request
In HPM, I see there is a notification function. I've created a Notification Tile specifically for Package Manager postings and am displaying that on my dashboard. Ability to see recently updated packages that I might want to apply has been solved...
I still feel the 'Whats New' could be more valuable if it had the option for 1, 7, or 30 days... but the 'report' function isn't any longer necessary.
The 'what's new' feature simply uses the data found in the json file each dev puts on their GitHub. If the dev doesn't update (or even include) the info when they update their respective app/driver, then this app has no way of knowing how 'new' the app/driver is. Nothing I can do about that!
Glad you found other parts of the app useful. :grin:
Great work here Bryan as usual. I do feel like the overview this provides would be most useful as part of HPM itself though, but it's still a fantastic addition. Thanks for all the effort you've put into sharing your hobby work with the community. It's most appreciated by all of us.
I received this on a notification tile this AM - that Package Explorer is 404.
Searched your repo and see it is indeed gone - is this 'obselete' and removed permanently? I'm aware of the whole 2sided bundles vs hpm and it is a bit funny to have an HPM package explorer by the Bundles champion :slight_smile:
Package Explorer is now available in Bundle Manager. (what!? lol)
I know a lot of DEVs do a lot of great work here and I appreciate the effort that non-programmers like mebenefit from. This reply is not a complaint, since without your efforts we'd have a LOT less useful device.
However, as a reasonably intelligent user, and someone who tries to follow the bouncing ball to get things working on home automation for years, using Google endlessly, I am COMPLETELY confused and cannot for the life of me figure out how to do the following on Hubitat:
How do I get/read/review a simple list of apps and/or drivers that are available for Hubitat?
I thought I could use Package Explorer, and tried to download the code from Github but it references this new BPTBundle and therefor doesn't install independently. So, I tried installing the bundles (now I guess 2 apps?? Not sure) and couldn't figure out what they did -- they were just "there". So I deleted everything and started fresh, but I still literally can't figure out how to look at a list somewhere and just then go to the HPM and install the drivers and apps I need.
Unfortunately using the community documentation leads you down threads that are no longer valid, and a conversation is not documentation. I don't mind doing some connecting-the-dots research, to find the answers but in this case, I cannot figure out what to do.
Can anyone help? I would greatly appreciate it. In short, I'd really just like to review a list -- in an app or on a document somewhere -- that describes what apps are available, what they do, and how to get them. Thank you.
