All the additions are great, provides much more reason to access everything through the app, rather than the disconnect between the admin / system level and general user content (dashboards etc). I even accessed the community through the app to do this post...
If I can make one suggestion, it would be good to see the social page brought out to the same level as Dashboards, Tools and Settings, perhaps merging geofence into Settings to make space.
If you wanted to take it a step further perhaps the documentation could also be grouped together with the socials, maybe under a heading of Support...?
@moncho1138, thanks for the update. I really like having the local hub UI in the app. One thing I noticed is the My Hubs page shows "Active? No" for my one and only hub. Is that a bug or am I overlooking what that status means?
it looks like they added more granular enabling and disabling of notification too.. I really do not want to be notified of GeoEvents as I have pushbullet doing that for me.
I will need to verify that when i get home though.
If you click on the link in the OP that should bring you to a prompt to install TestFlight, the app that Apple uses to distribute public beta apps, and once installed the hubitat beta app should be available to install.
Once you go to the Hub Diagnostic UI there is now way back to the Tools menu even if you switch from the other menus you still can't get back to the default tools menu and you have to exit the app to get to that menu again.
Same with going to the Hub UI...
I suggest that if you press the Tools menu button twice you can get back to the tools menu if possible.
Android app...
In the case of HubUI, DiagnosticTools, Documentation and Community, the page is open as a webpage, and you close on the X upper left. In the case of the other pages (with back arrow) some are not working and will be fixed on next update for this beta.
Getting back to the main tools menu by pressing the tools tab once again is a good point to be included.
just installed iOS version and it hangs on launch and doesn't respond to touch.
Update: after force quitting five our six times I managed to get past What's new screen. Which is improvements, comparing to the live app store version.
