[RELEASE] Netatmo Weather Station
Netatmo Weather Station brings Netatmo weather stations into Hubitat: the base station, outdoor and additional indoor modules, and the rain and wind gauges, each as its own device. It covers the weather station line only, not other Netatmo products.
The parent app handles everything that talks to Netatmo: authorization, discovery, polling and unit conversion. The child drivers only receive tidied-up values and publish them as Hubitat events, so when something looks wrong there's one place to look.
Supported devices
- Base Station
- Outdoor Module
- Additional Indoor Module
- Rain Gauge
- Wind Gauge
Features
- Netatmo authorization with no callback URL or Redirect URI to configure
- Guided setup: it shows only what you can use yet, finds your devices automatically once you've authorized, and tells you when a step isn't finished
- Choose which stations and modules become Hubitat devices
- Scheduled polling, plus manual refresh
- Optional webhooks from Netatmo (beta), with polling as the automatic fallback
- Backs off and resumes by itself if Netatmo's API limit is reached
- Keeps polling through brief Netatmo or network outages: a failed token renewal is retried on the next poll, and you're only asked to reauthorize if Netatmo actually refuses
healthStatus(online/offline) on every device, from whether Netatmo can reach it, for alerts when a module's battery dies or it drops out of range- Unit preferences for temperature, pressure, rain, wind speed (km/h, mph, m/s, knots) and wind direction (angle, text, or both)
- Daily minimum and maximum temperatures, where Netatmo provides them
- Built-in diagnostics for missing or stale values
Installation
Install with Hubitat Package Manager by searching for Netatmo Weather Station.
You can also install manually from the source files on GitHub: the drivers you need first, then the app.
Setup has two stages. Create an application at dev.netatmo.com to get a Client ID and Client Secret, then paste them into the integration under Integrations on your hub and click Authorize Netatmo. The README walks through both, including where to find things in Netatmo's developer portal:
- README and full setup: hubitat-drivers/netatmo-weather-station at main · brossow/hubitat-drivers · GitHub
- Package manifest: https://raw.githubusercontent.com/brossow/hubitat-drivers/main/netatmo-weather-station/packageManifest.json
Testing
I run the base station and outdoor module on my own hub. Additional indoor modules, the rain gauge and the wind gauge have been reported working by a user in this thread with the full set. Further reports from rain and wind gauge owners are always welcome, since those values depend on what Netatmo returns for active modules.
Notes
- If you're moving from another Netatmo integration, this isn't a drop-in replacement: dashboards, rules and automations will need pointing at the new devices. Don't run two integrations against the same station at once, or you'll get duplicate devices.
- Polling updates the devices you've created; Create/update selected supported devices creates them.
- Devices aren't deleted automatically if you deselect them.
- It depends on Netatmo's cloud API being available.
- Netatmo plans to lower its API rate limits for polling-based integrations on March 1, 2027. Poll intervals of 10 minutes or longer are a sensible choice, since Netatmo only updates this data about every 10 minutes anyway.
- An independent integration, not affiliated with or endorsed by Netatmo.
Changes and support
What's changed in each version is in the changelog on GitHub, and I post an update in this thread with each release.
Questions, feedback and bug reports are welcome here or as GitHub issues.
