[RELEASE] MyFuelPortal Integration — propane/fuel tank monitoring
If your propane or fuel supplier uses the MyFuelPortal website for account/tank monitoring (common with regional suppliers with Heller's Gas and Koppy's Propane are two examples), this app pulls your tank data straight into Hubitat.
What it does
  • Logs into your provider's MyFuelPortal portal and scrapes the Tank + account pages.
  • Creates one child device per tank, labeled by service address, so multi-tank/multi-address accounts stay organized.
  • Polls on a schedule (1/3/6/12/24 hr, your choice) plus an on-demand Refresh command.
Attributes exposed per tank
tankLevel (%), gallons, capacity, product, deliveryMode, pricePerGallon, readingDate, lastDelivery, nextDelivery, address, accountBalance, accountNumber, accountName, customerSince, plus two computed ones:
  • dailyUsage — gal/day, averaged over the trailing 30 days of readings, resets after each delivery
  • daysUntilEmpty — current gallons ÷ that usage rate, so you can automate low-tank alerts before you run dry
Install (Hubitat Package Manager)
  1. Open HPM → Install → Search by Keywords
  2. "fuel" → Next
  3. Add the app, enter your portal subdomain (the "youraccount" part of youraccount.myfuelportal.com), email, and password
Separate logging toggles for normal operation info vs. verbose debug (request/response dumps), so you can leave useful activity logging on without the noise.
Note: my account is new, so I haven't been able to fully end-to-end verify every field yet. I haven't hit a low-tank situation or had a delivery/top-up come through, so daysUntilEmpty, lastDelivery, and nextDelivery are untested against real data. Core tank level/gallons/account info is confirmed working.
Source: hubitat/myfuelportal at main · mpalermo73/hubitat · GitHub
Credit to the Home Assistant integrations this login/scrape flow was adapted from: dawg-io/homeassistant-myfuelportal, DeltaNu1142/MyFuelPortal, jterrace/ha_my_fuel_portal.
Feedback/issues welcome.
I added the Battery capability to the driver so the tank level can be plotted right on your homepage. Hubitat is very limited on what you can add there.
Nice. Just curious, does the tank sensor report to the home base via cellular?
Hey!
Yes that's what's going on. I couldn't tell you how long the battery lasts since this is all new stuff.
Looks like a plastic (vs steel) cover. Makes sense. My old Sinope (zigbee) and TankUtility (z-wave) devices magnetically mounted on the tank. This should keep things cleaner.
