Closer doesn't do anything different. Battery is new. It is located about 3 ft. from a z-wave device that repeats. I have done a z-wave repair also. Tapping on the side of the dryer shows it as active but still no inactive without the refresh.
Logs show the refresh then it goes inactive. Time frame from dryer shutting off to when the refresh was given is about 2 min. So that was more than long enough for the sensor to go inactive. But it didn't until I did the refresh as you can see.
dev:28032020-01-14 05:28:05.068 pm debugrefresh()
dev:28032020-01-14 05:26:22.059 pm traceNotificationReport3: NotificationReport(v1AlarmType:2, v1AlarmLevel:255, reserved:0, notificationStatus:255, notificationType:7, event:2, sequence:false, eventParametersLength:0, eventParameter:[])
dev:28032020-01-14 05:26:22.054 pm debugzwaveEvent(hubitat.zwave.commands.notificationv3.NotificationReport cmd)
dev:28032020-01-14 05:26:22.049 pm debugLast Activity: 01/14/2020 05:26:21 PM
dev:28032020-01-14 05:26:22.041 pm traceDescription: zw device: 96, command: 7105, payload: 02 FF 00 FF 07 02 00 , isMulticast: false
dev:28032020-01-14 05:26:22.038 pm debugparse(String description)
