[RELEASE]Minoston Door/Window Sensor ( 3 in 1)
Driver Capabilities
  • Battery
  • Contact Sensor
  • Temperature Measurement
  • Relative Humidity Measurement
Configurable Options
  • Battery report threshold(1% - 20%)
  • Low battery alarm report(5% - 20%)
  • State of the sensor when the magnet closes the reed
  • Delay in seconds with ON command report(door closed)
  • Delay in seconds with OFF command report(door open)
  • Minimum Temperature change to report(0.5℃/0.9°F - 5.0℃/9°F)
  • Minimum Humidity change to report(5% - 20%)
  • Temperature Upper Watermark value(0,Disabled; 1℃/33.8°F-50℃/122.0°F)
  • Temperature Upper Notification and Association Group Control
  • Temperature Lower Watermark value(0,Disabled; 1℃/33.8°F - 50℃/122.0°F)
  • Temperature Lower Notification and Association Group Control
  • Humidity Upper Watermark value(0,Disabled; 1% - 100%)
  • Humidity Upper Notification and Association Group Control
  • Humidity Lower Watermark value(0,Disabled; 1%-100%)
  • Humidity Lower Notification and Association Group Control
Features
  • Standardized device data: FirmwareVersion, ProtocolVersion,Configurable
QQ图片20210720144617
Changelog
v1.0.0
  • Initial Release
v1.0.1
  • Syntax format compliance adjustment
  • delete dummy code
v1.0.2
  • update ConfigParams as product designed
  • update DTH name as product designed
v1.0.3
  • change lastBatteryReport to record the time of fresh battery
  • add lastBattery to record the battery value
Link to code?
Sorry, no idea.
I found the solution as below:
