MAB does not support vacuums yet.
However, there is a HE inbuilt Matter driver : Generic Matter RVC
Matter Advanced Bridge worked to enable Hubitat control of the Orein Smart Bathroom Fan, supporting two separate devices for the RGB light and the bathroom-exhaust fan.
@kkossev Hello ... I use MAB for a switchbot hub 2 and have 2 roller shades and 2 blind tilts as child devices in hubitat via matter. For some reason 1 of the roller shades is constantly spamming the hub with postion info of the shade. like badly, to the point i get the sevre hub load warning. The other shade doesnt do this at all nor do the blind tilts, they check in occasionlly or whatever and or report movement thats it. I removed the shade and did a resync and it re added, this time with a different driver and with different info on the command page. I thought that fixed it, but i was wrong, still doing it. Any thoughts on this? Everything is up to date on the switchbot side, and hubitat is up to date as well(C7)
**dev:1069**2026-11-04 4:01:26.838 pm
info
Office side shade windowShade is open [physical]
**dev:1069**2026-11-04 4:01:26.816 pm
info
Office side shade position is 100%
**dev:1069**2026-11-04 4:01:26.596 pm
info
**dev:1069**2026-11-04 4:01:26.589 pm
info
Office side shade targetPosition is 100%
**dev:1069**2026-11-04 4:01:26.511 pm
info
Office side shade Office side shade operationalStatus is 0
**dev:1069**2026-11-04 4:01:21.199 pm
info
**dev:1069**2026-11-04 4:01:21.186 pm
info
**dev:1069**2026-11-04 4:01:21.132 pm
info
**dev:1069**2026-11-04 4:01:21.121 pm
info
**dev:1069**2026-11-04 4:01:21.070 pm
info
**dev:1069**2026-11-04 4:01:19.177 pm
info
**dev:1069**2026-11-04 4:01:19.168 pm
info
**dev:1069**2026-11-04 4:01:19.117 pm
info
**dev:1069**2026-11-04 4:01:19.106 pm
info
Hi @murv82,
It is strange that two identical shades behave differently... Anyway, I have implemented software filtering in the 'Matter Generic Component Window Shade' child driver. It should reduce the load on your hub caused by duplicate events and logs.
Could you try updating the child device driver manually? Click the 'user' hyperlink in the child device's 'Device Info' tab:
This will open a new tab with the driver code. Then click the hamburger menu in the top right corner and select Import.
The new component driver version should be 1.2.7 (2026-11-08).
Also, please send a 'Get Info' command to your shade and copy/paste the output into the logs. It should look like this:
This information can help us determine whether there is something specific about this shade.
