[RELEASE] Linptech/Moes 24Ghz Presence Sensor ES1 ( TS0225 _TZ3218_awarhusb ) drivers
This should be an easy 'hack' - just make the changes and change also the driver name ( I usually add 'KK mod' when I do the same :slight_smile: )
BTW, the battery attribute should not be visible! You can see it only in RM5, webCoRE, or if you use some utilities such as the Device Details Display Utility
