Linked Device Labeler
A custom app to simplify labeling devices linked across hubs via Hub Mesh.
Features
- Bulk updates to the Device Label values of devices to match their labels on the remote hub (i.e. removing " on Hub").
- Manual edits to the Device Label values of devices (i.e. overriding the labels derived from the names on the remote hub).
- Optional appending of strings (e.g. icons, characters) to Device Label values.
- Precise selection of linked devices on which to submit Device Label updates.
- Visibility (with counts) into all linked devices on the hub (requires "Toggle All" selection of all devices).
Installation
Step 1: Import and Add the App
- Install the application via HPM (search for "Linked" or "Labeler", requires "Fast Search")
- Install the application from this repository via the Apps Code page:
LinkedDeviceLabeler.groovy
. - Add the application via "Add user app" on the Apps page.
Step 2: Select Devices
- Select linked (and local) devices.
- The app automatically filters out local devices, so no harm in selecting them as well ("Toggle All" is your friend).
- All changes to Device Label values occur only on devices linked from remote hubs.
Step 3: Configure Controls
- Optionally restrict the display/action to linked devices currently without Device Label values (i.e. newly linked devices).
- Optionally restrict the display/action to linked devices whose Device Label values would change.
- Optionally enter a string (e.g. icons, characters) to append to all Device Label values.
Step 4: Specify Devices to Change
- Use checkboxes to select and unselect the linked devices whose Device Label values will change.
Step 5: Apply the Changes
- Apply the Device Label edits in bulk to all selected devices.
Limitations
- The app requires users to re-select devices after adding newly linked devices. HE apps cannot access devices without user selections.
Support
If you encounter issues or have feature requests, feel free to open an issue in GitHub.
