[RELEASE] iStore Hot Water Heat Pump App and Driver
A Hubitat app and driver for the iStore R290 hot water heat pump, using the UNIVERS / iStore cloud (https://home.istore.net.au). The heat pump needs the Wi-Fi module and must already be set up in the UNIVERS EMS mobile app.
Features
  • Logs in with your UNIVERS / iStore email and password. You don't need to copy tokens out of browser dev tools, and the app refreshes the session or logs in again by itself when it expires.
  • Finds the heat pumps on your account automatically. If you have more than one, each gets its own Hubitat device.
  • Monitors tank top and bottom temperature, average tank temperature, setpoint, setpoint range, ambient, coil and suction temperatures, plus compressor, fan, defrost, 4-way valve, booster, work mode and both timers.
  • Controls power, booster, setpoint (checked against the min/max range), setpoint range, timers and the device name.
  • Derived attributes: operatingState (off / defrosting / boosting / heating / idle) and hotWaterAvailable (%).
  • Commands appear on the device straight away, then are confirmed by fast follow-up polls. If the heat pump doesn't apply a change within about 50 seconds, the device goes back to the real value.
  • Uses non-blocking HTTP and one batched request per poll for all heat pumps. On errors, polling backs off exponentially (up to 15 min) and healthStatus reports when the cloud or the heat pump is offline.
  • Supports °C and °F, following your hub's temperature scale.
Hubitat Package Manager Installation
  1. Install HPM
  2. Open the HPM App, Install an app and search for iStore. Select the one authored by Jamie Curnow.
  3. Profit
Configure
  1. After adding the drivers, go to Apps and add a User App. Select iStore Heat Pump Connect
  2. Follow the steps to setup the app
More info in the Github repo
Testers and feedback welcome :slight_smile:
