Just as a note I was just seeing the same thing, I didn’t even see this current version in the menu, that you are showing in the screenshot and wasn’t seeing unmatch either. The view apps and driver page was showing 1.8.6. I’ve since repair and now it shows up.
Probably not very helpful, but figured I’d give another voice to say I experienced the same thing.
There are multiple reasons for a "bad manifest" error, most of which need the developer to resolve on their end, so an auto-unmatch may not be possible.
Thanks. I'm resolved. My HPM was .2. HPM Updates did not offer to update HPM so my version was out of whack. When I ran the manual copy paste from github the feature appeared. repair may have also fixed it, but i wanted to be sure I had the latest from the link so did mine manually.
I wonder why HPM update didn't update HPM? odd. Regardless. thanks.
I've ran that test more than a few times as I verified that un-match of HPM cured the dual manifest cosmetic issue. I Soft Reset back to a date where 1.8.2 was all I had installed and an upgrade was offered. I tested both waiting for the upgrade offer and just doing a repair, knowing the manifests were pointing at a new version. Both paths worked the same.
And the Library bundle goes away, the library code does not, as expected. I manually delete it and have done the whole Install, check, delete cycle 3 times. Worked as expected for ME.
The installations always work perfectly, it’s the point release updates which fail. Install the Fob driver again and I’ll push a fake point release. Then try to upgrade the driver in place.
I have a C7 hub, and my HPM is 1.8.7. I just installed it but I get an error saying that it can't login to hub and to check my hub security login. I have tried it both with and without Hub Security enabled, but I get the same error.
HPM's switch must match the reality of the hub. If you have a login configured on your hub, then you must tell HPM how to get in by giving it the ID/pw.
If you don't have your hub configured to use a login, then don't tell HPM that you do.
Maybe you were using shorthand but simply enabling hub security won't work. You have to give HPM the correct login and pw.
