Left the beta app, uninstalled and reinstalled the app, and I was able to import the settings with the config file on my Lenovo duet. Then I rejoined the beta, updated the app and the settings remained. It must be an issue with the new update.
Maybe this has already been asked but are there any plans to allow a RGBW tile to change colors depending on the current color of the bulb?
@jpage4500, I have an app called "Giant Clock" that dims the screen (nice landscape clock for my Android car unit), but only for itself. I'm quite sure it didn't require any additional permissions.
Is there any way you could implement a faster unlock method for read only mode? I usually scroll the dashboard and don't want to accidentally trigger a device so I keep in read only. However, when I actually want to turn on, unlock, etc it takes a couple of seconds to do it.
If you make the bottom red read only banner alert an actionable message that could unlock read only it would be a perfect solution for me.
I've got this fixed in the next version.. I'll do an update soon
version 1.0.1052 (beta)
- fix setting variable string (date)
- support google photos Hubitat device
Just a couple of changes here.. I fixed sending the correct date/time format when updating a 'variable string' device type
Also, I stumbled across a Hubitat driver for Google Photos over the weekend and thought it would be nice to support. There's a few steps needed to set it up - see the link here.
Once you have it configured on the Hub, add the new device to MakerAPI and you'll see a photo tile. Click on it for a full-screen view. The image will change automatically every minute.
Can this app support 2 hubs in different locations similar to ActionTiles? Have not been able to find any info on more than one hub installation or even if it is possible.
I hadn't thought about this before but I'll add it to the TODO list and spend a little time thinking about it. Ultimately I think I'd just need to maintain multiple sets of the login info (IP/APP ID/TOKEN/CLOUD TOKEN) and be able to switch between them.
This is amazing. Thank you so much!!!
It would be great if you could mix and match devices (ex. Door and Water Sensors) from different hubs but even quickly toggling hubs/locations would be fine. I use a link tile in ActionTiles to toggle hubs and this may be a simple solution.
@jpage4500 First off, let me say (likely again) what a great application this is. It is almost the only dashboard I use.
NEW REQUEST! So, on my Fire HD tablet on the wall, I have the app pinned. As it is not powered, I have to remove it from the wall holder to charge once a week.
What would be a great addition is to have the tablet (or phone) battery level show up in a tile.
That way, to check the battery level, I would not have to un pin the app to check.
Would this be something useful to others?
I can confirm that the Lenovo Duet works flawlessly outside of the LAN!!! Now if I could only get my Chromebox to work
I have 3 of them on the wall using an inexpensive wall mount (amazon) that powers the device.
If you install it above some hard switch chances are you have 110V to connect to.
Works great!
Anyone figure out how to import the config file into the app on a Chromecast with Google TV? Does anyone know where the file is stored once it is imported? There does not seem to be a file location for the app data and I was wondering if I could make a folder and drop the config file into it. I would need to know what to call the folder and whether it would even work??? I have a third party app installed and the process would save me a lot of time configuring all my devices.
If you're running on the same network as the Hub, you could try backup and restore using the Hub's file manager. That's what I use. I used to use Google Drive app previously which also worked fine (just requires that app to be installed and configured).
For the import, select nav -> more options -> backup and restore -> restore from Hub. This should show a list of files on your hub. Select one to import it.
If you already have a config file, you can upload it to the Hub manually too using the Hub's built-in file manager (example: http://192.168.0.202/hub/fileManager). You will need to name the file with "dashboard-" prefix as I'm filtering out files without that.
- This does require the app to be on the same network as the hub.. it also requires no username/password security set on the hub too which isn't set by default
For the backup/restore "other" option it's a little more complicated.. I just tried it on a Pixel device. I selected the built-in option "SD Card" which saves to your device. If you have Google Drive installed, you can select that as an option too. You'll see a lot of other choices in this list too.. that might work for sending the file but it's not going to work for importing it
For the restore/other option, I get the Downloads folder by default (where I saved in the earlier step) so I can just select that file. If you were to use Google Drive though, it should show up in the left navigation panel as an option too.
Let me know if one of these steps doesn't work on Android TV and I can try it there too
version 1.0.1053 (beta)
- allow image and video tiles to be larger than 2x2
With this version, I'm starting to explore allowing tiles to be greater than just 2x2. To start, I'm just allowing this for images and videos (my primary driver is the new Google Photo's hubitat device). Instead of a toggle switch, there's a little horizontal spinner control (swipe left/right) to set the tile height and width.
,I did notice that if you make the tile too tall the screen won't scroll properly.. if you run into that, just reduce the height so the tile fits in the screen width.
Once I've spent more time making sure everything works well, I'll allow more device types to use it too.. it's not that I can't make any tile much larger - it's just that I want to make sure the image/text fits and looks good at the larger sizes.
Yuck.. my C-5 hub stopped working yesterday and won't boot anymore. The last thing I want to do is buy a new one and re-pair all of my devices but that might be the only option if I can't fix it.. I won't be able to make updates to the app for a bit but I'll post again when I can get back up and running again.
Hope you get back in business soon with an easy recovery and your devices intact!
Sorry to hear about your issue. Hope you get it back up and running quickly and easily my friend!
Backup/Restore is not working for me. I recently did a backup of my configuration to my phone and reset the app, but when I choose to restore from the txt file, it just acts as if nothing happened. Any ideas?
