Here is a quick example sketch that I believe will meet your requirements. I have not compiled or tested this sketch, so there is a possibility of a typo. This sketch is designed to handle 1 motion sensor, 15 contact sensors, and 1 simple alarm siren (alarm sound only, no separate strobe. If a separate strobe is desired, we can make a simple tweak.)
This should get you started. Let me know if you have any questions.
// File: ST_Anything_JasonJoel_EthernetW5500.ino
// Authors: Dan G Ogorchock & Daniel J Ogorchock (Father and Son)
// Summary: This Arduino Sketch, along with the ST_Anything library and the revised SmartThings
// library, demonstrates the ability of one Arduino + Ethernet W5500 Shield to
// implement a multi input/output custom device for integration into Hubitat.
// The ST_Anything library takes care of all of the work to schedule device updates
// as well as all communications with the Ethernet W5500 Shield.
// ST_Anything_JasonJoel implements the following ST Capabilities in multiples of 2 as a demo of what is possible with a single Arduino
// - 1 x Motion devices (used to detect motion)
// -15 x Contact Sensor devices (used to monitor magnetic door sensors)
// - 1 x Alarm devices - 1 siren only, 1 siren and strobe (using simple digital outputs)
// During the development of this re-usable library, it became apparent that the
// Arduino UNO R3's very limited 2K of SRAM was very limiting in the number of
// devices that could be implemented simultaneously. A tremendous amount of effort
// has gone into reducing the SRAM usage, including siginificant improvements to
// the SmartThings Arduino library.
// Note: The orignal 'Multiples' sketch was fully tested on an Arduino MEGA 2560 using the Ethernet2 W5500 Shield.
// Change History:
// Date Who What
// 2015-01-03 Dan & Daniel Original Creation
// 2017-02-12 Dan Ogorchock Revised to use the new SMartThings v2.0 library
// 2017-04-16 Dan Ogorchock New sketch to demonstrate multiple SmartThings Capabilties of each type
// 2017-04-22 Dan Ogorchock Added Voltage, Carbon Monoxide, and Alarm with Strobe
// 2017-04-22 Dan Ogorchock Initial version for W5500 Ethernet2 Shield
// 2018-02-09 Dan Ogorchock Added support for Hubitat Elevation Hub
// 2019-11-11 Dan Ogorchock Custom version for JasonJoel
// SmartThings Communications Library for Arduino Ethernet W5500 Shield
#include <SmartThingsEthernetW5500.h> //Library to provide API to the SmartThings Ethernet W5500 Shield
// ST_Anything Library
#include <Constants.h> //Constants.h is designed to be modified by the end user to adjust behavior of the ST_Anything library
#include <Device.h> //Generic Device Class, inherited by Sensor and Executor classes
#include <Sensor.h> //Generic Sensor Class, typically provides data to ST Cloud (e.g. Temperature, Motion, etc...)
#include <Executor.h> //Generic Executor Class, typically receives data from ST Cloud (e.g. Switch)
#include <InterruptSensor.h> //Generic Interrupt "Sensor" Class, waits for change of state on digital input
#include <PollingSensor.h> //Generic Polling "Sensor" Class, polls Arduino pins periodically
#include <Everything.h> //Master Brain of ST_Anything library that ties everything together and performs ST Shield communications
#include <PS_Illuminance.h> //Implements a Polling Sensor (PS) to measure light levels via a photo resistor on an analog input pin
#include <PS_Voltage.h> //Implements a Polling Sensor (PS) to measure voltage on an analog input pin
#include <PS_TemperatureHumidity.h> //Implements a Polling Sensor (PS) to measure Temperature and Humidity via DHT library
#include <PS_Water.h> //Implements a Polling Sensor (PS) to measure presence of water (i.e. leak detector) on an analog input pin
#include <IS_Motion.h> //Implements an Interrupt Sensor (IS) to detect motion via a PIR sensor on a digital input pin
#include <IS_Contact.h> //Implements an Interrupt Sensor (IS) to monitor the status of a digital input pin
#include <IS_Smoke.h> //Implements an Interrupt Sensor (IS) to monitor the status of a digital input pin
#include <IS_CarbonMonoxide.h> //Implements an Interrupt Sensor (IS) to monitor the status of a digital input pin
#include <IS_DoorControl.h> //Implements an Interrupt Sensor (IS) and Executor to monitor the status of a digital input pin and control a digital output pin
#include <IS_Button.h> //Implements an Interrupt Sensor (IS) to monitor the status of a digital input pin for button presses
#include <EX_Switch.h> //Implements an Executor (EX) via a digital output to a relay
#include <EX_Alarm.h> //Implements Executor (EX)as an Alarm capability with Siren and Strobe via digital outputs to relays
#include <S_TimedRelay.h> //Implements a Sensor to control a digital output pin with timing/cycle repeat capabilities
//Define which Arduino Pins will be used for each device
// Notes: Arduino communicates with both the W5500 and SD card using the SPI bus (through the ICSP header).
// This is on digital pins 10, 11, 12, and 13 on the Uno and pins 50, 51, and 52 on the Mega.
// On both boards, pin 10 is used to select the W5500 and pin 4 for the SD card.
// These pins cannot be used for general I/O. On the Mega, the hardware SS pin, 53,
// is not used to select either the W5500 or the SD card, but it must be kept as an output
// or the SPI interface won't work.
// See https://www.arduino.cc/en/Main/ArduinoEthernetShield for details on the W5500 Sield
//"RESERVED" pins for W5500 Ethernet Shield - best to avoid
#define PIN_4_RESERVED 4 //reserved by W5500 Shield on both UNO and MEGA
#define PIN_1O_RESERVED 10 //reserved by W5500 Shield on both UNO and MEGA
#define PIN_11_RESERVED 11 //reserved by W5500 Shield on UNO
#define PIN_12_RESERVED 12 //reserved by W5500 Shield on UNO
#define PIN_13_RESERVED 13 //reserved by W5500 Shield on UNO
#define PIN_50_RESERVED 50 //reserved by W5500 Shield on MEGA
#define PIN_51_RESERVED 51 //reserved by W5500 Shield on MEGA
#define PIN_52_RESERVED 52 //reserved by W5500 Shield on MEGA
#define PIN_53_RESERVED 53 //reserved by W5500 Shield on MEGA
//Analog Pins
//Digital Pins
#define PIN_MOTION_1 24 //Hubitat Capability "Motion Sensor"
#define PIN_CONTACT_1 26 //Hubitat Capability "Contact Sensor"
#define PIN_CONTACT_2 27 //Hubitat Capability "Contact Sensor"
#define PIN_CONTACT_3 28 //Hubitat Capability "Contact Sensor"
#define PIN_CONTACT_4 29 //Hubitat Capability "Contact Sensor"
#define PIN_CONTACT_5 30 //Hubitat Capability "Contact Sensor"
#define PIN_CONTACT_6 31 //Hubitat Capability "Contact Sensor"
#define PIN_CONTACT_7 32 //Hubitat Capability "Contact Sensor"
#define PIN_CONTACT_8 33 //Hubitat Capability "Contact Sensor"
#define PIN_CONTACT_9 34 //Hubitat Capability "Contact Sensor"
#define PIN_CONTACT_10 35 //Hubitat Capability "Contact Sensor"
#define PIN_CONTACT_11 36 //Hubitat Capability "Contact Sensor"
#define PIN_CONTACT_12 37 //Hubitat Capability "Contact Sensor"
#define PIN_CONTACT_13 38 //Hubitat Capability "Contact Sensor"
#define PIN_CONTACT_14 39 //Hubitat Capability "Contact Sensor"
#define PIN_CONTACT_15 40 //Hubitat Capability "Contact Sensor"
#define PIN_ALARM_1 45 //Hubitat Capability "Alarm"
//Garage Door Pins
//Pushbutton Pins
//W5500 Ethernet Shield Information
byte mac[] = {0x06,0x02,0x03,0x04,0x05,0x06}; //MAC address // <---You must edit this line using the MAC address provided with your W5500 Shield!
IPAddress ip(192, 168, 1, 231); //Arduino device IP Address // <---You must edit this line!
IPAddress gateway(192, 168, 1, 1); //router gateway // <---You must edit this line!
IPAddress subnet(255, 255, 255, 0); //LAN subnet mask // <---You must edit this line!
IPAddress dnsserver(192, 168, 1, 1); //DNS server // <---You must edit this line!
const unsigned int serverPort = 8090; //port to run the http server on
// Hubitat Hub TCP/IP Address
IPAddress hubIp(192, 168, 1, 149); // smartthings/hubitat hub ip // <---You must edit this line!
// Hubitat Hub Port
const unsigned int hubPort = 39501; // hubitat hub port
//st::Everything::callOnMsgSend() optional callback routine. This is a sniffer to monitor
// data being sent to ST. This allows a user to act on data changes locally within the
// Arduino sktech withotu having to rely on the ST Cloud for time-critical tasks.
// Do not add an delay(), or other blocking statements in this function.
void callback(const String &msg)
//Uncomment if it weould be desirable to using this function
//Serial.print(F("ST_Anything_Miltiples Callback: Sniffed data = "));
//Serial.println(msg);
//TODO: Add local logic here to take action when a device's value/state is changed
//Masquerade as the network to send data to the Arduino, as if from the Hubitat hub (uncomment and edit following line(s) as you see fit)
//st::receiveSmartString("Put your command here!"); //use same strings that the Device Driver would send (e.g. "alarm1 siren", "alarm1 off")
//Arduino Setup() routine
void setup()
//Declare each Device that is attached to the Arduino
// Notes: - For details on each device's constructor arguments below, PLEASE REFER to the
// corresponding header (.h) and program (.cpp) files. Comments at the top of these
// files provide detailed documentation for each ST_Anything device class.
// - The name assigned to each device (1st argument below) must match the Groovy
// Device Driver names. (Note: "temphumid" below is the exception to this rule
// as the DHT sensors produce both "temperature" and "humidity". Data from that
// particular sensor is sent to the ST Hub in two separate updates, one for
// "temperature" and one for "humidity")
// - The new Composite Device Handler is comprised of a Parent DH and various Child
// DH's. The names used below MUST not be changed for the Automatic Creation of
// child devices to work properly. Simply increment the number by +1 for each duplicate
// device (e.g. contact1, contact2, contact3, etc...) You can change the Child Device
// LABELS to match your specific use case in the Hubitat admin web page on the hub.
//Polling Sensors
//Interrupt Sensors
static st::IS_Motion sensor1(F("motion1"), PIN_MOTION_1, HIGH, false, 500); //May need to tweak the 'HIGH' & 'false' params depending on your sensor
static st::IS_Contact sensor2(F("contact1"), PIN_CONTACT_1, LOW, true, 500); //Configured to use internal pullup resistor, just wire contact
static st::IS_Contact sensor3(F("contact2"), PIN_CONTACT_2, LOW, true, 500); //sensor to the pin and gnd on the Arduino board
static st::IS_Contact sensor4(F("contact3"), PIN_CONTACT_3, LOW, true, 500);
static st::IS_Contact sensor5(F("contact4"), PIN_CONTACT_4, LOW, true, 500);
static st::IS_Contact sensor6(F("contact5"), PIN_CONTACT_5, LOW, true, 500);
static st::IS_Contact sensor7(F("contact6"), PIN_CONTACT_6, LOW, true, 500);
static st::IS_Contact sensor8(F("contact7"), PIN_CONTACT_7, LOW, true, 500);
static st::IS_Contact sensor9(F("contact8"), PIN_CONTACT_8, LOW, true, 500);
static st::IS_Contact sensor10(F("contact9"), PIN_CONTACT_9, LOW, true, 500);
static st::IS_Contact sensor11(F("contact10"), PIN_CONTACT_10, LOW, true, 500);
static st::IS_Contact sensor12(F("contact11"), PIN_CONTACT_11, LOW, true, 500);
static st::IS_Contact sensor13(F("contact12"), PIN_CONTACT_12, LOW, true, 500);
static st::IS_Contact sensor14(F("contact12"), PIN_CONTACT_13, LOW, true, 500);
static st::IS_Contact sensor15(F("contact14"), PIN_CONTACT_14, LOW, true, 500);
static st::IS_Contact sensor16(F("contact15"), PIN_CONTACT_15, LOW, true, 500);
//Special sensors/executors (uses portions of both polling and executor classes)
//Executors
static st::EX_Alarm executor1(F("alarm1"), PIN_ALARM_1, LOW, true); //may need to tweak the 'true' to 'false' depending on the
//relay being used ('true' = Active LOW versus 'false' = Active HIGH)
// Configure debug print output from each main class
st::Everything::debug=true;
st::Executor::debug=true;
st::Device::debug=true;
st::PollingSensor::debug=true;
st::InterruptSensor::debug=true;
//Initialize the "Everything" Class
//Initialize the optional local callback routine (safe to comment out if not desired)
st::Everything::callOnMsgSend = callback;
//Create the SmartThings EthernetW5500 Communications Object
//STATIC IP Assignment - Recommended
st::Everything::SmartThing = new st::SmartThingsEthernetW5500(mac, ip, gateway, subnet, dnsserver, serverPort, hubIp, hubPort, st::receiveSmartString);
//DHCP IP Assigment - Must set your router's DHCP server to provice a static IP address for this device's MAC address
//st::Everything::SmartThing = new st::SmartThingsEthernetW5500(mac, serverPort, hubIp, hubPort, st::receiveSmartString);
//Run the Everything class' init() routine which establishes Ethernet communications with the SmartThings Hub
st::Everything::init();
//Add each sensor to the "Everything" Class
st::Everything::addSensor(&sensor1);
st::Everything::addSensor(&sensor2);
st::Everything::addSensor(&sensor3);
st::Everything::addSensor(&sensor4);
st::Everything::addSensor(&sensor5);
st::Everything::addSensor(&sensor6);
st::Everything::addSensor(&sensor7);
st::Everything::addSensor(&sensor8);
st::Everything::addSensor(&sensor9);
st::Everything::addSensor(&sensor10);
st::Everything::addSensor(&sensor11);
st::Everything::addSensor(&sensor12);
st::Everything::addSensor(&sensor13);
st::Everything::addSensor(&sensor14);
st::Everything::addSensor(&sensor15);
st::Everything::addSensor(&sensor16);
//Add each executor to the "Everything" Class
st::Everything::addExecutor(&executor1);
//Initialize each of the devices which were added to the Everything Class
st::Everything::initDevices();
//Arduino Loop() routine
void loop()
//Execute the Everything run method which takes care of "Everything"
st::Everything::run();
