[Release] HubDuino v1.1.7 - Hubitat to Arduino / ESP8266 / ESP32 / ThingShield Integration (ST_Anything)
Announcing the release of HubDuino v1.1.7 (aka ST_Anything for former ST users)
[UPDATE 1.1.7] This is a significant update to the Parent Drivers. Changes include:
  1. MAC Address no longer required when setting up a Parent Device. Only the IP Address/Port is required to help simplify initial startup. This also means that the micro-controller can be replaced with different hardware, as long as it runs the same sketch and uses the same IP address. This ability to swap boards is only possible with freshly installed HubDuino boards, due to changes in the Child Device Network IDs. These are now based on the parent's device.Id, instead of the parent's device.deviceNetworkId.
  2. Number of Buttons no longer required when setting up a Parent Device. This will be automatically determined and configured. Please be sure to update your Arduino library's IS_Button.cpp file, and rebuild/reload the sketch for this to work on new installations.
  3. New setting for Device Timeout - number of seconds before marking the micro-controller 'not present'. In the event that your Arduino/ESP8266 boards decides to go offline, the Parent Device now implements the Presence Capability. This will indicate whether or not the micro-controller has sent data to the hub within the user defined timeout setting (defaults to 900 seconds.) You can use this as a trigger in RM, for example, to send a notification that something may be wrong.
[UPDATE 1.1.6] Adds support for Arduino NANO 33 IoT
[UPDATE 1.1.5] Adds support for Arduino MKR1010 (thanks @jrau272!), support for MKR THERM thermocouple shield, Arduino IDE 1.8.9, ESP8266 v2.5.2, updated numerous libraries, etc…
[UPDATE 1.1.4 Adds support for SHT31 Temperature and Humidity I2C Sensor
[UPDATE 1.1.3] This version brings significant enhancements to the EX_Servo class to allow asynchronous and simultaneous motion by multiple servos. Also, the speed of each servo, as well as min and max endpoint angles are now user selectable. Special thanks to @VooDooFiveTwo Jeff Albers for his contributions!
[UPDATE 1.1.2] I have added I2C sensor support for the MAX44009(lux), TSL2561(lux), BH1750(lux), AM2320(temp and humid), BME280(temp, humid, pressure), BMP280(temp and pressure), and updates for the TCS34725(color lux). A new example sketch to demonstrate these is included as well.
HubDuino allows you to integrate a custom Arduino / ESP8266 / ESP32 device with Hubitat by editing only one Arduino sketch file! No groovy programming skills are required! You simply decide what devices are attached to each pin of your microcontoller and HubDuino/ST_Anything handles the rest for you! Numerous example sketches are included to help get you started.
Please provide some feedback on your experience so the documentation and code can be improved.
Note: This release has support for LAN-connected devices AND for the ThingShield.
Note: Former ST_Anything users will need to update all of their Arduino Library code from my GitHub repository. Some minor changes were required to the Ethernet/WiFi libraries. Also, the Hubitat Hub listens on port 39501, not 39500. You will need to update your sketches accordingly while changing the IP address of the hub as well.
HubDuino Architecture
Please follow the guide in the ReadMe below and feel free to issue a pull request to improve this document.
NOTE: The v3.0.0 ESP8266 Board support package for the Arduino IDE has introduced a compiler incompatibility. Please be sure to use v2.7.4 to prevent avoid this issue for now.
HubDuino - Arduino / ESP8266 custom integration is working!
Hubitat with Homemade Temperature, Humidity, Pressure and Light sensor
Homemade Sound Sensor
Smart Home Device Manufacturers Dropped Ball
Particle Photon DH and Apps
Garage door
5V DC dual Relay
Raspberry PI GPIO support
LAN Relays
Nodemcu running wled
Saved my Petnet smart feeder with a NodeMCU
Harmony Hub
Basic Driver code
How to connect wired motion detector to hubitat hub
Question about migrating from Homeseer
Help with a Liftmaster gate
IO Board interfaces
Yet Another Garage Door Controller w/ Hubduino
Best protocol for new Raspberry Pi based hardware device - WIFI, Z-wave or Zigbee?
New to Hubduino
DIY ESPhome multisensor
12 zone valves need monitoring but how?
Wired Contact sensor integration
Need ideas for an NodeMCU and lux sensor
Things I am looking/hoping for
Non-battery powered contact sensors?
Community Device Drivers (AKA Compatible Devices Wiki)
3D printed Hubduino cases
Zigbee wired temperature sensors
Temperature Sensor for Wood Stove
Washer and dryer done alerts
Security system
JSON Integration Question
Mobilus Cosmo Gtw roller controller
Hubitat for AUS/NZ Chat
Monitor External Contacts
Smart Air Conditioning System - MyAir by Advantage Air
Chamberlain MyQ Garage Door Support [OUT OF DATE]
Capability Request - Water Flow Rate
Updating attributes via http
Subscribe() on Device to child Device
Sensor to tell me when something looses power
Driver to accomplish color changes on pool lights (hubduino relays)
Xiaomi / Aqara ZigBee device drivers (possibly may no longer be maintained)
Garage door 'opening'/'closing' rule works from dashboard, but not physical button
Garage door opener
[API] Listen a TCP/UDP port from Driver?
Zwave or Zigbee relay/switch
Raspberry Pi Zero and Relay for Garage Door Opener
How do you save in electric bills?
Sound level sensor
Current State. What makes it show?
Custom zigbee module thoughts
2 part Temperature and Humidity Question
How to deal with capabilities with overlapping commands?
Awning device please (META device)
Low Voltage or battery powered zigbee relay?
Stepper motor with node mcu or d1 mini (i.e. want to automate blinds/curtains)
Distance sensor device type?
Community Apps
How to externally detect liquid level in a container?
HE to RF?
[Project] HVAC Temperature Zone Control App
From Iris to...?
From Iris to...?
Fibaro Smart Implant
HSM Status Light Ideas
Considering Hubitat Several questions
Monitoring swimming pool water level
Button recommendation?
Something to think about
Harmony integration
Beam sensor?
How do I interface 802.11 WiFi-enabled devices?
[PORT] Hubitat MQTT Bridge
Hubitat api to get response out of Hubitat
Everything Xbee
Migrating from SmartThings to Hubitat, best practices?
Integration of a MySensors type of capability
Konnected in Hubitat?
First Impressions
Water Temperature
Interested in Hubitat, but have one question
Webcore and Node-red
Choices for DIY devices
Multi dry contact relays
Controllino Devices
Question for the electronic gurus
Is there a device that...? (Need to monitor a gas stove.)
Has anyone managed to build a luminosity sensor?
Stand alone RV control panel HE + ESP32
I was able to replicate the setup from ST very easily on a separate nodemcu much easier than anticipated. I now have a “hubduino” set up communicating motion status locally and real time to my brand new Hubitat hub. Thank you!
UPDATE:
While motion sensor works excellently, I haven’t been able to get any switches to operate. I have tried a relay as well as RF24 transmitter (works in ST). I do see in the hubduino logs that it receives the commands but the power state on the nodemcu doesn’t appear to trigger and nothing is updated in the Hubitat portal.
Everything: Received: switch5%20on
Everything: Received: switch5%20off
Did I miss a step in configuring to make it respond to the commands?
UPDATE2:
Please disregard - I did not update the libraries - the necessary change was to add this to line in the wifi lib:
tempString.replace("%20", " "); //Clean up for Hubitat
Apologies for the confusion - thank you!
Glad to hear you’ve got it up and running. Please let me know if you have any feedback, especially in the documentation.
All,
I have added support for the ThingShield. If you give it a try, please post your results back in this thread.
Enjoy!
I assume the tile layout for devices is different in Hubitat? I don’t see the option to enter a temperature offset in my child temp devices.
That’s a very good point! Let me take a look and see why those options are not showing up!
First, thank you very much for the feedback! Please give this version a try and let me know if it resolves the missing preferences issue.
 *  Child Temperature Sensor
 *  Copyright 2017 Daniel Ogorchock
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
 *  Change History:
 *    Date        Who            What
 *    2017-04-10  Dan Ogorchock  Original Creation
 *    2017-08-23  Allan (vseven) Added a generateEvent routine that gets info from the parent device.  This routine runs each time the value is updated which can lead to other modifications of the device.
 *    2017-11-04  Dan Ogorchock  Added preference for Temperature Unit Conversion: Fahrenheit to Celsius, Celsius to Fahrenheit, or none
 *    2018-02-16  Dan OGorchock  Fixed preferences to work with Hubitat.
metadata {
	definition (name: "Child Temperature Sensor", namespace: "ogiewon", author: "Daniel Ogorchock") {
		capability "Temperature Measurement"
		capability "Sensor"
		attribute "lastUpdated", "String"
		command "generateEvent", ["string", "string"]
	simulator {
	preferences {
		section("Prefs") {
			//input title: "Temperature Offset", description: "This feature allows you to correct any temperature variations by selecting an offset. Ex: If your sensor consistently reports a temp that's 5 degrees too warm, you'd enter \"-5\". If 3 degrees too cold, enter \"+3\".", displayDuringSetup: false, type: "paragraph", element: "paragraph"
			input "tempOffset", "number", title: "Temperature Offset", description: "Adjust temperature by this many degrees", range: "*..*", displayDuringSetup: false
			//input title: "Temperature Unit Conversion", description: "This feature allows you to select F to C, C to F, or no conversion", displayDuringSetup: false, type: "paragraph", element: "paragraph"
			input "tempUnitConversion", "enum", title: "Temperature Unit Conversion - select F to C, C to F, or no conversion", description: "", defaultValue: "1", required: true, multiple: false, options:[["1":"none"], ["2":"Fahrenheit to Celsius"], ["3":"Celsius to Fahrenheit"]], displayDuringSetup: false
	tiles(scale: 2) {
		multiAttributeTile(name: "temperature", type: "generic", width: 6, height: 4, canChangeIcon: true) {
			tileAttribute("device.temperature", key: "PRIMARY_CONTROL") {
				attributeState("temperature", label: '${currentValue}°', unit:"F", defaultState: true,
						backgroundColors: [
                                // Celsius
                                [value: 0, color: "#153591"],
                                [value: 7, color: "#1e9cbb"],
                                [value: 15, color: "#90d2a7"],
                                [value: 23, color: "#44b621"],
                                [value: 28, color: "#f1d801"],
                                [value: 35, color: "#d04e00"],
                                [value: 37, color: "#bc2323"],
                                // Fahrenheit
                                [value: 40, color: "#153591"],
                                [value: 44, color: "#1e9cbb"],
                                [value: 59, color: "#90d2a7"],
                                [value: 74, color: "#44b621"],
                                [value: 84, color: "#f1d801"],
                                [value: 95, color: "#d04e00"],
                                [value: 96, color: "#bc2323"]
 			tileAttribute("device.lastUpdated", key: "SECONDARY_CONTROL") {
    				attributeState("default", label:'    Last updated ${currentValue}',icon: "st.Health & Wellness.health9")
def generateEvent(String name, String value) {
	//log.debug("Passed values to routine generateEvent in device named $device: Name - $name  -  Value - $value")
	// Offset the temperature based on preference
    def offsetValue = Math.round((Float.parseFloat(value))*100.0)/100.0d
    if (tempOffset) {
    	offsetValue = offsetValue + tempOffset
    if (tempUnitConversion == "2") {
    	//log.debug "tempUnitConversion = ${tempUnitConversion}"
        double tempC = fahrenheitToCelsius(offsetValue.toFloat())  //convert from Fahrenheit to Celsius
        offsetValue = tempC.round(2)
    if (tempUnitConversion == "3") {
        double tempC = celsiusToFahrenheit(offsetValue.toFloat())  //convert from Celsius to Fahrenheit
    // Update device
	sendEvent(name: name, value: (String)offsetValue)
    // Update lastUpdated date and time
    def nowDay = new Date().format("MMM dd", location.timeZone)
    def nowTime = new Date().format("h:mm a", location.timeZone)
    sendEvent(name: "lastUpdated", value: nowDay + " at " + nowTime, displayed: false)
def installed() {
Thanks, Dan! That was fast. And it seems to work :slight_smile:
Thanks for the feedback. I tested it on ST as well and all appears to be fine. I have updated my GitHub repository.
I noticed today that HubDuino was throwing some errors in the Live Log regarding a function called ‘sendEthernet()’. This is a function that is internal to the “HubDuino Ethernet Bridge” and “HubDuino ThingShield Bridge” Drivers. It is called by the HubDuino Service Manager whenever data needs to be sent to the Arduino processor. So data was coming into Hubitat, but could not be sent to the Arduino.
I believe a recent Hubitat hub firmware change may have changed the behavior for how an App can call into a Device. I had to declare ‘sendEthernet’ as a custom “command” in my Bridge Drivers. Then the problem was resolved.
So, heads up to anybody using HubDuino. You may want to update your Hubitat-side groovy code. I have been continuing to add to ST_Anything for both SmartThings and Hubitat, so there are some additional features that have been added over the past few weeks.
Appreciate the heads-up Dan!
I was about to add a NodeMCU to my Hubitat tonight . I already did the ST_Anything with one a couple weeks ago and was meaning to send you a thanks for that. The ST_Anthing was only my 2nd Arduino project ever. Up to that point I did everything with Rasp-Pi’s since they 1st came out.
Thank you for your codes and keeping us updated.
Jeff
I’m stuck,
Installed everything as per instructions but in section “Verify you Child Devices are automagically created” I do not see the child devices in the devices list. Yes, Bridge is but no children. Went back and double checked everything that I did and what I think I did right but here I am at this point.
Any ideas for me to look?
Double check the MAC address that you entered into the Bridge device (assuming you’re not using a ThingShield.) All uppercase and no delimiters.
Also, you did install the HubDuino Service Manager app and configure it, right?
Check the Live Logs for both the Bridge a Device and HDM App to see if any data is showing up.
Rebooted Esp8266 and they started to show up. Could be my learning curve and patience (or lack of) kicking in.
Will this need a watchdog to prevent falling asleep? I didn’t do anything like that with the ESP8266 I have on my ST hub. Why I ask is that before I restarted the Hubitat ESP8266 it disappeared from my network. I will wait and see if that happens again.
Thank you again. (Hope you never get tired of all the people thanking you).
Jeff
I have never had an ESP8266 go to sleep running ST_Anything’s example sketches.
Seems ok now, probably just the reboot of the Arduino.
@ogiewon do you happen to have a spare ThingShield? I am working with a @Matthew to move his alarm panel integration over to Hubitat and he cannot pair his ThingShield to Hubitat. I have a spare Arduino and ThingShield and I tried pairing it this morning with no success. I am on the latest firmware and discover never finds it. Last weekend my ThingShield was found immediately so not sure if something changed in the latest firmware but I am hoping someone else can validate this. Thanks in advance!
I just removed/unpaired my ThingShield from Hubitat, performed the reset of the ThingShield by holding down the SWITCH button for 6 seconds, then put Hubitat in device discovery mode, and then pressed the SWITCH button one time on the ThingShield. It was discovered almost immediately as a “SmartSense Multi Sensor” (or similar). I then changed the Driver to my HubDuino ThingShield Bridge and it seems fine.
I am on 704 firmware.
OK thanks for validating. I seem to be having troubles discovering ST branded devices lately. I paired a smart power outlet today and it took over 2 minutes to show up. My water leak sensors were super frustrating last weekend. But Iris contacts pair almost immediately.
Download the Hubitat app
