Thanks all - I'm always a little fuzzy on estimating power requirements, but little by little it's becoming more clear.
Worse thing that would happen is if your current draw is too much and the available current for the board drops too low it will just reset. That'll tell you right away if you're going to have a problem.
Also, have you thought of using the Callback function to sync the blinds within the board itself rather than through hubitat?
I'm not sure I understand. What does this function do?
It allows you to execute commands based on other messages the board sends/receives. For example, you can have local control over a relay based on a contact sensor. There's a whole bunch of info on it over in the ST forum for ST_Anything.
Interesting, I'll look into that. As it stands I've got the blinds wired up, and the servos appear to trigger in sequence, not in parallel, when using Hubitats Groups. Which of course means I don't have any power issues.
Looks great!
Yep! Works pretty well.
@ogiewon I am trying to get a servo running on an ESP-01. I am encountering an issue where it crashes.
I am using the ESP8266 2.3.0 version with Arduino IDE version 1.8.8
Here is the bootup and crash:
Everything: init started
Everything: Free RAM = 45664
Initializing ESP8266 WiFi network. Please be patient...
Attempting to connect to WPA SSID: xxxxx
Enter the following three lines of data into ST App on your phone!
localIP = 192.168.30.8
serverPort = 8090
MAC Address = xxxx
SSID = xxxx
PASSWORD = xxxx
hubIP = 192.168.30.5
hubPort = 39501
RSSI = -62
hostName = ESP8266_xxxx
SmartThingsESP8266WiFI: Intialized
Disabling ESP8266 WiFi Access Point
ArduinoOTA Ready
IP address: 192.168.30.8
ArduionOTA Host Name: ESP8266_xxxx
Everything: init ended
Everything: Free RAM = 44544
Everything: adding executor named servo1
Everything: initDevices started
EX_Servo:: Servo motor angle set to 89
Everything: Sending: servo1 49
Everything: initDevices ended
Everything: Free RAM = 44648
Device: Destroyed Device ID: servo1
Everything: Received: servo1 40
Exception (28):
epc1=0x40208e6f epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
ctx: cont
sp: 3ffef890 end: 3ffefb70 offset: 01a0
>>>stack>>>
3ffefa30: 00000010 00000001 3ffefaa0 40207f29
3ffefa40: 00000006 3ffefad8 3ffefaa0 4020805d
3ffefa50: 3fff1364 00000009 3ffeea84 402075bd
3ffefa60: 3ffe87f4 3ffefad8 00000000 402055d6
3ffefa70: 00000020 3ffeea84 3ffeea84 402076b8
3ffefa80: 3ffefc6c 00000015 3ffefad8 0000000a
3ffefa90: 3ffe8af4 00000000 3ffefad8 4020566b
3ffefaa0: 3fff125c 0000000f 00000006 40208014
3ffefab0: 3ffe8af4 00000005 40205614 40202c28
3ffefac0: 3ffe85f8 00000000 000003e8 00009a4d
3ffefad0: 3fff0c78 00000000 3fff1364 0000000f
3ffefae0: 00000009 00000000 00000000 00000000
3ffefaf0: 3fff106c 0000000f 00000000 3fff1054
3ffefb00: 0000000f 00000009 3fff138c 0000006f
3ffefb10: 00000069 00000000 00000000 00000000
3ffefb20: 00000000 3ffe87e8 051ea8c0 3ffeeb40
3ffefb30: 3fffdad0 00000000 3ffeeb39 4020585c
3ffefb40: 00000000 00000000 3ffeeb39 402020a3
3ffefb50: 3fffdad0 00000000 3ffeeb39 40208848
3ffefb60: feefeffe feefeffe 3ffeeb50 40100718
<<<stack<<<
ets Jan 8 2013,rst cause:2, boot mode:(1,7)
ets Jan 8 2013,rst cause:4, boot mode:(1,7)
wdt reset
Here is the code associated with it.
// File: ST_Anything_Multiples_ESP01WiFi.ino
// Authors: Dan G Ogorchock & Daniel J Ogorchock (Father and Son)
// Summary: This Arduino Sketch, along with the ST_Anything library and the revised SmartThings
// library, demonstrates the ability of one ESP8266-01 (ESP-01) to
// implement a multi input/output custom device for integration into SmartThings.
// The ST_Anything library takes care of all of the work to schedule device updates
// as well as all communications with the ESP-01's WiFi.
// ST_Anything_Multiples implements the following ST Capabilities in multiples of 1 as a demo of what is possible with a single ESP-01
// - 1 x Contact Sensor device (used to monitor magnetic door sensors)
// - 1 x Motion devices (used to detect motion)
// Note: The tiny ESP-01 only has 2 GPIO pins, so this example is somewhat limited. Use the ST_ANything_Multiples_ESP8266WiFi.ino example to see
// what else is possible. As long as you only try using 2 pins, you can use them for whatever you'd like.
// Change History:
// Date Who What
// 2015-01-03 Dan & Daniel Original Creation
// 2017-02-12 Dan Ogorchock Revised to use the new SmartThings v2.0 library
// 2017-02-21 Dan Ogorchock New example specifically for running everythin on a ESP-01 (no Arduino required!)
// 2017-04-24 Dan Ogorchock Updated for use with new v2.5 Parent/Child Device handlers
// 2018-02-09 Dan Ogorchock Added support for Hubitat Elevation Hub
// SmartThings Library for ESP8266WiFi
#include <SmartThingsESP8266WiFi.h>
// ST_Anything Library
#include <Constants.h> //Constants.h is designed to be modified by the end user to adjust behavior of the ST_Anything library
#include <Device.h> //Generic Device Class, inherited by Sensor and Executor classes
#include <Sensor.h> //Generic Sensor Class, typically provides data to ST Cloud (e.g. Temperature, Motion, etc...)
#include <Executor.h> //Generic Executor Class, typically receives data from ST Cloud (e.g. Switch)
#include <InterruptSensor.h> //Generic Interrupt "Sensor" Class, waits for change of state on digital input
#include <PollingSensor.h> //Generic Polling "Sensor" Class, polls Arduino pins periodically
#include <Everything.h> //Master Brain of ST_Anything library that ties everything together and performs ST Shield communications
#include <EX_Servo.h> //Implements an Executor (EX) via a Servo
//Define which Arduino Pins will be used for each device
#define PIN_SERVO 0
//ESP8266 WiFi Information
String str_ssid = "xxxx"; // <---You must edit this line!
String str_password = "xxxx"; // <---You must edit this line!
IPAddress ip(192, 168, 30, 8); //Device IP Address // <---You must edit this line!
IPAddress gateway(192, 168, 30, 1); //Router gateway // <---You must edit this line!
IPAddress subnet(255, 255, 255, 0); //LAN subnet mask // <---You must edit this line!
IPAddress dnsserver(192, 168, 30, 1); //DNS server // <---You must edit this line!
const unsigned int serverPort = 8090; // port to run the http server on
// Smartthings / Hubitat Hub TCP/IP Address
IPAddress hubIp(192, 168, 30, 5); // smartthings/hubitat hub ip // <---You must edit this line!
// SmartThings / Hubitat Hub TCP/IP Address: UNCOMMENT line that corresponds to your hub, COMMENT the other
//const unsigned int hubPort = 39500; // smartthings hub port
const unsigned int hubPort = 39501; // hubitat hub port
//st::Everything::callOnMsgSend() optional callback routine. This is a sniffer to monitor
// data being sent to ST. This allows a user to act on data changes locally within the
// Arduino sktech.
void callback(const String &msg)
//Serial.print(F("ST_Anything Callback: Sniffed data = "));
//Serial.println(msg);
//TODO: Add local logic here to take action when a device's value/state is changed
//Masquerade as the ThingShield to send data to the Arduino, as if from the ST Cloud (uncomment and edit following line)
//st::receiveSmartString("Put your command here!"); //use same strings that the Device Handler would send
//Arduino Setup() routine
void setup()
//Declare each Device that is attached to the ESP-01
// Notes: - For each device, there is typically a corresponding "tile" defined in your
// SmartThings Device Hanlder Groovy code, except when using new COMPOSITE Device Handler
// - For details on each device's constructor arguments below, please refer to the
// corresponding header (.h) and program (.cpp) files.
// - The name assigned to each device (1st argument below) must match the Groovy
// Device Handler names. (Note: "temphumid" below is the exception to this rule
// as the DHT sensors produce both "temperature" and "humidity". Data from that
// particular sensor is sent to the ST Hub in two separate updates, one for
// "temperature" and one for "humidity")
// - The new Composite Device Handler is comprised of a Parent DH and various Child
// DH's. The names used below MUST not be changed for the Automatic Creation of
// child devices to work properly. Simply increment the number by +1 for each duplicate
// device (e.g. contact1, contact2, contact3, etc...) You can rename the Child Devices
// to match your specific use case in the ST Phone Application.
//Polling Sensors
//Interrupt Sensors
//Executors
st::EX_Servo executor1(F("servo1"), PIN_SERVO, 90, true, 1000);
// Configure debug print output from each main class
st::Everything::debug=true;
st::Executor::debug=true;
st::Device::debug=true;
st::PollingSensor::debug=true;
st::InterruptSensor::debug=true;
//Initialize the "Everything" Class
//Initialize the optional local callback routine (safe to comment out if not desired)
st::Everything::callOnMsgSend = callback;
//Create the SmartThings ESP8266WiFi Communications Object
//STATIC IP Assignment - Recommended
st::Everything::SmartThing = new st::SmartThingsESP8266WiFi(str_ssid, str_password, ip, gateway, subnet, dnsserver, serverPort, hubIp, hubPort, st::receiveSmartString);
//DHCP IP Assigment - Must set your router's DHCP server to provice a static IP address for this device's MAC address
//st::Everything::SmartThing = new st::SmartThingsESP8266WiFi(str_ssid, str_password, serverPort, hubIp, hubPort, st::receiveSmartString);
//Run the Everything class' init() routine which establishes WiFi communications with SmartThings Hub
st::Everything::init();
//Add each sensor to the "Everything" Class
//Add each executor to the "Everything" Class
st::Everything::addExecutor(&executor1);
//Initialize each of the devices which were added to the Everything Class
st::Everything::initDevices();
//Initialize Watchdog Timer to detect lockups and automatically restart the MCU
wdt_enable(WDTO_8S);
//Arduino Loop() routine
void loop()
//Reset Watchdog Timer to let is know everything is running fine
wdt_reset();
//Execute the Everything run method which takes care of "Everything"
st::Everything::run();
Try commenting out the following lines regarding the Watchdog Timer. I added this in an attempt to automatically reset the ESP8266 in the event it got lucked up somehow. Unfortunately, it does not help with the lock up I was hoping this would resolve. So, I am wondering if it might be causing an issue for the ESP01. It's worth a try!
setup()
//(commented out for testing) wdt_enable(WDTO_8S);
loop()
//(commented out for testing) wdt_reset();
Is this normal?
I've never seen that before... where are you seeing that? Within the Arduino IDE? Or within the Live Logging?
Did you remove the HubDuino Parent device? Doing so will remove all of its child devices as well. Perhaps that what you're seeing?
I see that in the serial monitor of the Arduino IDE
Hmmm... Is that after you made the suggested changes?
Before and after... You can see it in the log in my original post.
**Device: Destroyed Device ID: servo1**
Everything: Free Ram = 44648
I tried to bold the line...
That's strange... I found the code that is printing it... in Device.cpp
//destructor
Device::~Device()
if(debug)
Serial.print(F("Device: Destroyed Device ID: "));
Serial.println(getName());
It is only called when the C++ object is destroyed... But I have never seen the destructor ever called. I wonder if it happen as part of the ESP01 reset somehow? Or, does it cause the reset...
Have you tried running the same sketch (different pin maybe) on a NodeMCU ESP8266 board?
I am going to try running your sketch here... might take me a while to dig out an ESP01 board/programmer circuit... It's been a long time since I messed with one of those...
I moved the servo to Pin 1 and now it appears to lock up on the initialization...
Everythi
I have reproduced the problem here on a NodeMCU ESP8266 board. I am not sure what is going on...
I just downloaded the code to a node mcu 8266 and I get the same output in the log.
from nodemcu:
