They use the same code base, according to @dan.t There's no feature differences, they just gather Hubitat data slightly differently.
Dan and I have settled upon similar advice regarding the choice: If you have HubConnect already, then another Instance is simple and easy.. and familiar. If you don't then MakerAPI is the clear choice. I have both installed in my development environment quite often.. lots of flipping back and forth in that space and I can't tell any difference.
Admin: HubConnect will now delete virtual devices from the remote hub when they are no longer shared. (Note: device deletion may not be successful if remote device is still in use by other apps)
Admin: New "Restart HubConnect Drivers & Services" re-initializes a single, (or all) remote hubs and re-establishes Websocket connections.
Core: Added support for multiple instances of the HomeBridge Remote Client neccessary to work around the HomeKit limitation of 100 devices per bridge.
Custom Drivers: Updated navigation for custom driver section of HubConnect server.
Custom Drivers: Reset Custom Drivers now prompts for confirmation before wiping out all custom driver definitions.
Custom Drivers: Added garbage collection to custom drivers on server instances to remove old device selectors when a custom driver is deleted.
Custom Drivers: Added many additional device capabilities to custom drivers for device selection.
Custom Drivers: Driver definition form displays fields only when they are needed and in the correct order.
General: Split HubConnect utilities into separate pages (Utilities and Reports) for better navigation.
What's Fixed or Changed?
Admin: HubConnect Server no longer re-initializes all remote hubs when pressing Done to exit app. (Hitting Done when prompted to update still does).
Admin: Fixed technical support report to be more resilient to communication failures for remote hubs.
Core: Updated websocket parsing to prevent multiple duplicate events from firing on HubConnect virtual devices.
Custom Drivers: Devices using custom drivers correctly populate the latest values of all defined attributes upon initial creation.
Custom Drivers: Fixed Remote Client custom driver garbage collection that was in some instances causing device selections to be lost.
Custom Drivers: Fix for Driver Builder to properly process selector lookup against the correct attribute.
I think it's only right and proper to comment about how the upgrade impacted me for the 1.5 to 1.6 upgrade.
IT DIDN'T.
The reason for my comment is the last 2 upgrades caused major issues.
I did a complete delete of everything and started again with the 1.5 update.
I think this means that it was probably user error (ME) with the initial install.
Is there any way to find out what device the logs are talking about? My logs on the server have a bunch of these entries in regards to one of the client hubs.
Something you selected inside your "Office" hub got deleted on the other Hub... probably just go into the Device selection menu again, deep enough to see the devices and then DONE all the way back out. It will recreate any missing. Watch the Live logs on the other hub and see if there's an error building them.. such as a missing Universal driver.
Just tried that. Went in to share devices to the server, hit done to get out. Live logs on the server gave me a bunch of "exists... skipping creation" but then a few more "Device Not Found".
