I think these devices (Iris Water Leak Sensor) got picked up under GVOmniSensor driver and I have too issue:
- Watchdog Device wont see it but if I changed to Generic Zibgee driver than WD can see it.
- Does GvOmniSensor mirrors battery report?
GVOmniSensor is:
GV = Global Variable.
OmniSensor = Driver with a lot of Capabilities defined.
The name is so confusing, v2.0 is renaming it
to "HubConnect RM Global Variable Connector"
On the connected hub, those would appear, individually, using the Universal driver that matches the selection. For String Variable Connectors:
Will become:
Perhaps you want to use: "HubConnect Moisture Sensor" universal driver? It has:
Ah...that does it. "HubConnect Moisture Sensor"
Hit Sync and all is good.
Does this hold true for those of us mirroring devices from Hubitat to SmartThings only?
The HubConnect nodeJS server is completely optional and targeted towards power users. It is not a requirement of the new release. And since SmartThings does not support any type of websocket, it'll still continue to communicate using http.
Nothing to worry about there. ![]()
Curious if anyone else is trying to use the Homemade Env Sensors with HubConnect.
It doesn't seem to show up on any lists. Was hoping it would show up as an Omnisensor. Any suggestions would be appreciated!
The ‘real drivers’ specify Capabilities.
CapabilitIes dictate HubConnect Selections.
Selections dictate the HubConnect Universal driver on the connected hub.
Therefore what real driver is used and what are it’s Capabilities?
definition (name: "Environment Sensor EX", namespace: "iharyadi", author: "iharyadi", ocfDeviceType: "oic.r.temperature") {
capability "Configuration"
capability "Refresh"
capability "Battery"
capability "Temperature Measurement"
capability "RelativeHumidityMeasurement"
capability "Illuminance Measurement"
capability "PressureMeasurement"
capability "Switch"
capability "Sensor"
Chances are you already have a switch defined and therefore you can find your device in the switch selector. If you’re using Event Socket then all the attributes are mirrored automatically.
Alright, so the device was found in the Switch section. I selected it and sent over to my other hub with all attributes. I could see it in the device list and all attributes are updating.
I then tried to add it to an app looking for humidity devices. It was still not listed in the app drop down.
Sooo, I started comparing the driver to another custom driver that has similar capabilities. One thing that stuck out is "RelativeHumidityMeasurement" vs "Relative Humidity Measurement" in the driver I was comparing it to. Once I changed that it showed up in the Omnipurpose Sensor Device list. Sent the device over that way and Bingo!, it now shows up in the Humidity drop downs.
Changed Capabilities in driver... (added spaces to capabilities that didn't have them)
capability "Relative Humidity Measurement"
capability "Pressure Measurement"
capability "Switch"
capability "Sensor"
Thanks for the help!
Hubitat's documentation shows no spaces. As far as I know, Hubitat (like ST) ignores case and whitespace.
This is correct.
All HubConnect drivers are built with the white space added for readability.
app:28592020-01-27 22:00:46.026 errorFloRida is offline.
app:28592020-01-27 22:00:45.754 errorasynchttpGet() request failed with error 408
app:28592020-01-27 22:00:33.673 debugSending event to FloRida: Fridge Bar Food [temperature: 44.60 °F]
Any clue as to where to look?
408 = there's a timeout occurring.
If FloRida is ST, then the cloud is probably down. Wait.
ATTN Beta Testers: The code and upgrade instructions have been released! Please install the upgrade at your earliest convenience.
The HubConnect node server will be released in a few days to give everyone a chance to install the update and become familiar with it.
To keep this discussion relevent to the current 1.6.x branch, I kindly ask that the beta team file support tickets to report any issues found.
Question of approach.
Many of us aim to have a dedicated Rules Hub, I suspect. However, for LAN devices, for example Sonos or Ecobee, does it make more sense to keep the devices on separate device hubs and interact with the speakers/thermostats via HubConnect, or install the Sonos and Ecobee apps on the Rules Hub and manage these devices locally?
I know basically either could work, but as a design discussion - is there a better approach?
Virtually everyone using multiple hubs has an opinion on this topic, and mine is just another "voice in the choir". The important thing is to think first about what you wish to achieve, then map out the topology that fits that design. Having all devices on one hub, and all rule on the other hub could make sense if for example, you use a lot of resource-hungry energy monitoring automations.
I also view that as an all eggs in one basket approach, in this case, you have two; rules and devices. Thinking about a potential failure vector, the loss of either hub basically trashes your entire HA environment. If that's not something you are worried about then there's nothing wrong with this approach. I would prefer to share what I did for my system, and you can decide if it's right for you, rather than tell you what you should do.
When I first went multiple hubs it was to address some (long fixed) reliability issues with Zigbee. This led me to adopt an upstairs/downstairs approach, with one hub in the basement, one on the 2nd floor, and a third hub acting as the server and aggregating those events. I've since added a 4th Hubitat hub into the home on the 1st floor to offload some processing which has helped mitigate the hub slowdowns a bit.
So what I have now is:
The server hub hosts all of my dashboards, it's also the host for Hubitat's app presence. It runs mode manager to manage modes based on presence, and hosts all rules that tie in devices located across multiple hubs. This includes all of my exterior lighting automation since those motion devices are Arlo cameras via SmartThings and UniFi cameras via Homebridge.
So what happens when a hub crashes, is upgraded, or rebooted is the impacts on the overall home are mitigated.
For example, when Hub 1 is offline for any reason, we lose motion lighting upstairs, HSM, and the ability to control lamps using buttons that override automation. But the outside lighting automations run, basement motion lighting runs, basement and 1st floor security is active etc.
Or, if I reboot the server hub, I lose dashboards but still have HSM working across the entire house. I lose exterior lighting automations but virtually all other lighting automations are unaffected. My server hub was recently down for a half of a day because the hardware failed. The impact of that was noticeable in that my DW is used to using a tablet dashboard in her craft room, but the home otherwise continued to operate as we expected.
I am sure others will post their own experiences as well. My advice is to study what others are doing and pick those elements which you feel would work best and build on them.
thanks for the detailed thoughts
I like your program and I like your approach and that is what I'm doing with my hubs and like the upstairs and downstairs approach. Thanks so much for you insight it is very much appreciated. This community rocks.
