To be honest, I couldn't get it to ever work right either. The button implementation is completely different between Smartthings and Hubitat which is why I think that's the case. I actually got it working partially before but I gave up on using ST to HubConnect for my Ring devices and using the Unofficial Ring Integration located here instead created by @codahq :
I have it setup on my Server hub and using my own custom drivers so the devices are on my other hub that I use for the outdoor motion events so it triggers to turn lights on with motion and button events on my ring devices.
Below is the custom driver I created for myself for my Ring Doorbell:
* Copyright 2019 Steve White
* Licensed under the Apache License, Version 2.0 (the "License"); you may not
* use this file except in compliance with the License. You may obtain a copy
* of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS, WITHOUT
* WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the
* License for the specific language governing permissions and limitations
* under the License.
metadata
definition(name: "HubConnect Ring Doorbell Pro", namespace: "shackrat", author: "Steve White")
capability "Motion Sensor"
capability "PushableButton"
capability "Sensor"
capability "Actuator"
attribute "statusMessage", "string"
attribute "active", "string"
attribute "version", "string"
command "sync"
installed
Doesn't do much other than call initialize().
def installed()
initialize()
updated
def updated()
initialize()
sendEvent(name: "numberOfButtons", value: "1")
initialize
Doesn't do much other than call refresh().
def initialize()
refresh()
parse
In a virtual world this should never be called.
def parse(String description)
log.trace "Msg: Description is $description"
pushed
Pushes button #<btn>.
def pushed(btn)
// The server will update pushed status
parent.sendDeviceEvent(device.deviceNetworkId, "pushed", [btn], stateChange: true)
refresh
Refreshes the device by requesting an update from the client hub.
def refresh()
// The server will update status
parent.sendDeviceEvent(device.deviceNetworkId, "refresh")
sync
Synchronizes the device details with the parent.
def sync()
// The server will respond with updated status and details
parent.syncDevice(device.deviceNetworkId, "ringdoorbellpro")
sendEvent([name: "version", value: "v${driverVersion.major}.${driverVersion.minor}.${driverVersion.build}"])
def getDriverVersion() {[platform: "Universal", major: 1, minor: 1, build: 1]}
Once stub driver is installed, create a custom driver like this:
You can remove Pro off of the name if you want, doesn't really matter since it's the same for Pro vs non Pro.
Here's an example when I pushed my doorbell button just now using this custom driver on my other hub using HubConnect:
