Sorry for the delay. There was a bug identified that I am currently working on (multi sensor updates won't work for temperature and humidity). I hope to have something later today.
Is there a Hubconnect driver that can enable me to see the humidity value of the zooz 4-1 motion sensor? My 4 are using the Hubconnect Dome Motion Sensor which provides 3 of the 4 - 1
This is actually a bug in the device sync functionality. I've issued a hot fix to correct this. Please re-import the Server Instance and Remote Client code. That should take care of it.
All,
happy to let you know that I just published the next bigger release 0.2.0 of the homebridge plugin for hubconnect
migrated to dynamic homebridge platform that removes the need of restarting homebridge after a device selection was changed in HubConnect
ability to configure homebridge to use Celsius
ability to create switch tiles for modes and switching of modes (requires HubConnect 1.4)
HSM integration (requires HubConnect 1.4)
perform daily version check against NPMJS and print logging statement on newer versions available
streamline code to share improvements with homebridge-hubitat-makerapi
ability to exclude attributes
allows correct usage of DNS host names instead of IP address to connect to hubitat
support for fans (requires HubConnect 1.4)
Fixed issue with multi sensors not updating temperature and humidity
fixed issue that temperature can't go negative
I tried to prevent that you have to redo your room assignments, however, there is a chance that you might have to redo it. It all depends on if homebridge has cached your accessories or not. This should be the last time though!
Installation is as easy as
sudo npm install -g homebridge-hubitat-hubconnect
Updated README with new settings (enable HSM, modes and Celsius) can be found here
Really odd, I even imported all of the server code again but still can't get it to create. It didn't work on 1.3 for me either though but kept forgetting to report it. I have never gotten it to work, not really sure if that means the only way to fix is to completely delete HubConnect and redo everything again.
