I think I have an issue here.
I'm using webCoRE on my Master hub, and when I use any device which resides on both hubs, I'm seeing double executions.
app:55172019-04-04 03:39:54.759 pm infoReceived event from Hub_1/Office Lights: [switch, off , isStateChange: true]
app:55172019-04-04 03:39:54.750 pm infoReceived event from Hub_1/Office Lights: [switch, off , isStateChange: true]
app:55172019-04-04 03:39:54.653 pm infoReceived event from Hub_1/Office Lights: [switch, off null]
app:55172019-04-04 03:39:54.565 pm infoReceived event from Hub_1/Office Lights: [switch, off null]
Maybe this wouldn't normally cause any issues, but I'm using webCoRE and its executing Pistons connected to said devices twice too. This is causing quite an overhead in processing and creating a huge queue on actions.
Is this by design, or is it an actual issue?
webCoRE is running on my Master hub, so not the Hub with the physical devices.
Another example of a button push which toggles a lamp.
You can see the push twice, and the lamp turns on twice.
app:55172019-04-04 03:51:54.059 pm infoReceived event from Hub_1/Roys Bedside Dimmer: [switch, on null]
app:55172019-04-04 03:51:53.858 pm infoReceived event from Hub_1/Roys Bedside Dimmer: [switch, on null]
app:55172019-04-04 03:51:53.680 pm infoReceived event from Hub_1/Remotec ZRC-90: [battery, 92 %]
app:55172019-04-04 03:51:53.647 pm infoReceived event from Hub_1/Roys Bedside Dimmer: [switch, on , isStateChange: true]
app:55172019-04-04 03:51:53.589 pm infoReceived event from Hub_1/Roys Bedside Dimmer: [switch, on null]
app:55172019-04-04 03:51:53.151 pm infoReceived event from Hub_1/Roys Bedside Lamp: [switch, on , isStateChange: true]
app:55172019-04-04 03:51:53.119 pm infoReceived event from Hub_1/Roys Bedside Lamp: [switch, on null]
app:55172019-04-04 03:51:53.025 pm infoReceived event from Hub_1/Roys Bedside Lamp: [switch, on null]
app:55172019-04-04 03:51:52.158 pm infoReceived event from Hub_1/Remotec ZRC-90: [pushed, 1 , isStateChange: true]
app:55172019-04-04 03:51:52.109 pm infoReceived event from Hub_1/Remotec ZRC-90: [pushed, 1 null]
update
Its not only webCoRE its doing this with. The below is from Button Controllers app, when I use my Philips dimmer. I just turned the light on and off once.
dev:12622019-04-04 03:57:27.529 pm infoGroup Master Bedroom was turned off
dev:12622019-04-04 03:57:27.490 pm infoGroup Master Bedroom was turned off
dev:12622019-04-04 03:57:24.964 pm infoGroup Master Bedroom was turned on
dev:12622019-04-04 03:57:24.841 pm infoGroup Master Bedroom was turned on
Further update
I changed "Local connect type:" back to Hubitat oAuth (http) and the double executions have now stopped.
