Features:
- Working with S2
- Availability of all device parameters
- Driver automatic version check (every 7 days at noon)
- Configurable logging levels
Status: Fully tested and working
Todo: Nothing for the moment
Download: GitHub
Features:
Download: GitHub
Hi and thank you for the Z-TRM2fx driver it works perfectly.
Is there any possibility you can include support for Heatit Z-TRM3 ?
It's basically the same unit only with an internal temp sensor as well.
https://www.heatit.com/heating-control/floor-heating-thermostats/heatit-z-trm3/
I'll give it a try in a couple of weeks but it's not always easy without having the actual device.
That would be wonderful if you could give it a try I can open RDP so you can try on my unit
