Seems like we passed the first phase of OAuth - but failed to get a token based on the code returned by Google. There should be an error in your logs to provide more detail on what went wrong -- please check if this is still available, so I can look into the error. The only recourse is to click on the Authorization link again - if it works, great! If not, check the logs again to see if it's the same error or different.
Hey all,
I've got this installed via Hubitat Package Manager and it's running really well, the only thing I can't find is what the "free" vs "controlled" mode means on the App screen?
I've tried searching through the forum, but "nest", "free", "integration", and "controlled" aren't exactly unique words around here!
Am I missing some documentation somewhere?
Sorry to say, you've got the wrong forum thread - that screenshot doesn't match anything provided by this app. If you can provide more details - namespace/developer on the app you're using, maybe we can get you pointed in the right direction?
That's the thermostat controller app your on.
Ah that would be the reason then...
Originally replied in the wrong place. Deleted those posts.
My Google credentials.jason was missing the secret. Not sure why, but a re-download and repast in that config did the trick. Thanks for pointing me to the logs! (duh).
Hi All. So close to getting this configured. Only taken me about a week..
I managed to authorize everything, and that went through without issues.
Now, however, when I click on the Discover button, nothing comes up.
All authorized and ready to go; no devices.
Help?
UPDATE: Figured it out. Forgot to add the device drivers
New feature -- use Google Drive for image archive storage and display -- released tonight! This utilizes the existing image
attribute, but provides a link to Google Drive for the image display, instead of caching the data locally on the hub -- enabling the capability to view the latest image in a Cloud Dashboard.
See the Google Drive README section for more details!
**Note if you are updating an existing install and enabling this feature, click the Done button on the App page, so that the updated
method is called and the retention job is scheduled.
Installed with package manager a few days ago. Updated Hubitat and google api today and still cannot get device to show up. I have one thermostat. It was listed during authorization and the slider was turned on the devices during authorize. Not sure what to do.
nevermind. checked the logs and found the problem
Is anyone else using Alexa with the Nest thermostat? Within Hubitat things work perfectly, and even issuing a voice command through Alexa the device is responding, but Alexa thinks it failed “its looks like I can’t reach your thermostat right now. Maybe because of a manufacturer issue. We’ve let them know there is a problem.” I have tried the extended thermostat option in the alexa skill app, etc. the thermostat responds instantly to the request in spite of the message from Alexa.
I don't use Alexa, but I wonder if the delay is because the App waits for the event from Google before sending the event to the driver to actually update the setPoint reported by Hubitat. I wouldn't expect a ton of latency there, but given we have to go through "the cloud", it could take a second or two?
I'm not sure. It is actually performing the action requested (setting temperature) almost instantly, but the report/trigger acknowledging that the action was performed doesn't seem to be getting back to Alexa.
Hubitat noob here...I'm running into this error when I try to authenticate from Hubitat
Error 403: access_denied
The developer hasn’t given you access to this app. It’s currently being tested and it hasn’t been verified by Google. If you think you should have access, contact the developer(MyEmailAddress)
I quickly searched through the thread and couldn't find any matching issues, so I must be doing something wrong
Any advice?
Thanks!
Hmm -- sounds like a couple things may be off -- (A) your GCP Project may be in "Testing" mode instead of "Production", and (B) you might have selected a different Google account during authorization than was used to create the Project?
Yeah it turns out it was the Testing vs Production mode of the GCP project. Got that sorted and it works perfectly.
Thanks for all the help and documentation!
My Nest Thermostat's operational state keeps transitioning from COOLING/FAN to IDLE while the thermostat is running. If I hit refresh, it grabs the correct state and runs with it for awhile. I deleted/added my thermostat earlier today during troubleshooting so my history isn't that long, but since reset I've seen it clear to IDLE from within seconds to as much as 30 minutes later. Every time it actually transitions from IDLE to COOLING or FAN, it shows up correctly until it clears to IDLE.
Here's all operational events from the thermostat today. I put a border around the 4 separate times my thermostat has run today. Every time you see it going back to COOLING, it's me hitting the refresh button from the device configuration page. I created a formula in Excel to show how long it took to go from some state to IDLE. What's going on here?
Edit: Now that it's midnight, here's a screenshot of my thermostat history to corroborate the excel image. I've also updated the excel shot with 2 additional events. Fan mode is not shown on the history.
Can you turn on Debug logs for the App, to capture the events being received from Google? My suspicion at this time is that it may be getting temp updates without any state, which triggers the App to think it is idle. If we confirm the event content that is triggering the incorrect change, I can then look at how to handle this condition
I turned on debug logging and I'm not sure what's going on. I just took that screenshot at 10:25. The event log is only showing events after 5 minutes, you can see last event time is all over the place, and the refresh button is no longer working.
Edit: I've rebooted the hub and collecting events again, they are responsive again. Looking at the logs, there was another app that was spamming the event queue. It's quiet again. Here's the latest switch to IDLE. It coincides with a Temperature event. Some previous ones also coincided with a Humidity update, it's not just Temperature.
Here's the excerpt from my log showing the temp update event with only temperature information. I also show the refresh event which grabs all data.
Based on your comment about temp/humidity change, looking through the App code, and looking through the debug log to see how events come in from Google, I found what was going on.
My changes are highlighted below. I tested this by going in and out of fan ON mode while the thermostat was set to cool and the operating state stays in COOL mode. I also waited for a humidity event to come in while it was running and it stays in COOL mode. If you come up with another solution for this, I'm interested to see it. My boolean statement is getting a bit long there and the rest of your code looks much better. This is my quick-and-dirty change to get it functional
