[RELEASE] Goldshell BYTE miner (local)
Hi! A local driver for the Goldshell BYTE miner, using the miner's own web panel API (no cloud).
The parent device reports system status, power (W) and accumulated energy (kWh), and creates one child device per hash card with its metrics. It also exposes LED, idle mode, per-card power plan and reboot.
Install: Hubitat Package Manager → search "Goldshell BYTE Miner", or Install → From a URL with https://raw.githubusercontent.com/rngarcia/hubitat/main/drivers/goldshell-byte/packageManifest.json
Code and docs: hubitat/drivers/goldshell-byte at main · rngarcia/hubitat · GitHub
Setup: the miner's IP in Preferences. Then run setBearerToken with the JWT token from the miner's web panel (token only, without "Bearer ").
Note: the same API is also used by pyasic, a good reference for other Goldshell models.
Interesting; I'm curious - what's the use case for integrating this miner with Hubitat?
For now, just monitoring the mining status and power usage; that is, cool dashboards! :sweat_smile: I expect to be able adjust setting of it in the future, such as power profile, mining pools, schedules, etc.. Any suggestions are welcome!
