I recently installed some 24V tunable-white COB strip under my shelving, using a GLEDOPTO GL-C-601P (Zigbee 3.0 Pro Max 5-in-1) in CCT mode. Hubitat kept pairing it as an RGB/RGBW bulb. None of the built-in or community drivers I tried would crossfade warm and cool white correctly: changing the color temperature mostly changed brightness, and the reported CT stuck around 6300K.
What I found
- The controller reports itself as GL-C-007P / GL-C-008P (RGBW / RGB+CCT) and advertises full color capabilities (
0x400A = 0x1F), even with the indicator set to green/CCT. Changing the mode with the Opt button and re-pairing didn't change that on my unit. - It has only one endpoint (0x0B).
- Sending a standard ZCL Move to Color Temperature (cluster 0x0300, cmd 0x0A) directly to endpoint 0x0B crossfades correctly at constant brightness, and the controller reports CT (0x0007) accurately.
So the hardware and firmware handle CCT fine. It just needed a CT-only driver.
What the driver does
- Exposes only Switch, Switch Level, Change Level, Color Temperature, Color Mode (always CT), Refresh and Configuration. No hue, saturation or RGB.
- Sends CT and level as separate commands, so dimming and color temperature are independent.
- Reads the controller's actual CT range (158โ500 mireds, about 2000Kโ6329K) and limits requests to it, with optional min/max Kelvin preferences.
- Updates its state from the device's own reports, not assumed values.
- Because there are no color capabilities, it shows up in Apple Home as tunable white only, with no color wheel.
Install
- Drivers Code โ New Driver โ Import โ paste the import URL below โ Import โ Save.
- Switch your device to GLEDOPTO GL-C-601P CCT, save, and click Configure.
- Click Save Preferences once. If the device previously used another driver with a
transitionTimesetting, that leftover value can cause errors, and this driver uses its own setting name to avoid it.
Apple Home (Maker API โ Homebridge)
I expose devices to Apple Home through Maker API and Homebridge. If the device was already in Homebridge under an RGB driver, Home holds on to the old color-light definition. To refresh it:
- Remove the device from your Maker API instance.
- Restart Homebridge.
- Add the device back to Maker API.
- Restart Homebridge again.
It will come back as a tunable-white light. Expect to reassign its room and any Home scenes or automations.
Notes
- I've tested this on one controller (firmware build 30151243) with CW/WW wired to the V2/V3 terminals. Feedback from other GL-C-601P owners is welcome.
- At 500 mireds the strip runs 100% on its warm-white channel. On a 2700K strip, "2000K" is really just its warmest setting, so the Kelvin labels at the warm end are approximate.
Code
- Repo: GitHub - newbeginin-com/hubitat-gledopto-cct ยท GitHub
- Import URL:
https://raw.githubusercontent.com/newbeginin-com/hubitat-gledopto-cct/main/drivers/gledopto-gl-c-601p-cct.groovy
