[RELEASE] Fibaro Smart Implant FGBS-222
@cjcharles im using both drivers. I use the Hubitat one for basic needs. Using this custom one I can set the auto off timer on the outputs which I needed for my TV bed lift
@christi999
Another update as I have moved to testing beta 2.4.1.114
This one broke the driver as well. :frowning:
dev:20342025-02-04 11:11:24.308
error
java.lang.NullPointerException: Cannot invoke method toFloat() on null object on line 443 (method parse)
dev:20242025-02-05 16:41:43.066errororg.codehaus.groovy.runtime.typehandling.GroovyCastException: Cannot cast object 'null' with class 'null' to class 'double'. Try 'java.lang.Double' instead on line 196 (method parse)
I can't test it until I get an official release. Hopefully it will fix itself or is probably easy to fix otherwise.
Sound good, just an FYI.
I found that this happens on the new Z-Wave platform but it seem to be ok on the old one.
Curiously, I find my probes bang on for temp in the summer (pool water 30C) but we've had a few negative days lately and -2 is actually -5 outside.
Probes must not be very linear.
I tacked on a new error to the previous with the latest build.
