If you read through this thread you will see that you need to use 'Virtual Device Sync'.
This will generate 2 'child' switches that you can use.
If you need some more guidance, just ask.
I've made some changes to @Robin's 222 driver to get it to work as expected (reporting and control):
* Fibaro FGS-222 Double Relay Switch Device Type - For use on Hubitat
* Author: Robin Winbourne
* Date: 2018-03-24
metadata {
definition (name: "Fibaro FGS-222 Double Relay Switch", namespace: "hubitat", author: "Robin Winbourne") {
capability "Switch"
capability "Relay Switch"
capability "Polling"
capability "Configuration"
capability "Refresh"
capability "Zw Multichannel"
attribute "switch1", "string"
attribute "switch2", "string"
command "on1"
command "off1"
command "on2"
command "off2"
command "updateSingleParam" // This custom command can be used with Rule Machine or webCoRE, to send parameter values (paramNr & paramvalue) to the device
fingerprint deviceId: "0x1001", inClusters:"0x86, 0x72, 0x85, 0x60, 0x8E, 0x25, 0x20, 0x70, 0x27"
preferences {
input name: "param1", type: "enum", defaultValue: "255", required: true,
title: "Parameter No. 1 - Activate / deactivate functions ALL ON / ALL OFF. Default value: 255.",
options: [
["255" : "255 - ALL ON active, ALL OFF active"],
["0" : "0 - ALL ON is not active ALL OFF is not active"],
["1" : "1 - ALL ON is not active ALL OFF active"],
["2" : "2 - ALL ON active ALL OFF is not active"]
input name: "param3", type: "enum", defaultValue: "0", required: true,
title: "Parameter No. 3 - Auto off relay after specified time, with the possibility of manual override - immediate Off after button push. Default value: 0.",
options: [
["0" : "0 - Manual override disabled"],
["1" : "1 - Manual override enabled"]
input name: "param4", type: "number", range: "0..65535", defaultValue: "0", required: true,
title: "Parameter No. 4 - Auto off for relay 1. " +
"Available settings:\n" +
"[1 - 65535] (0,1 s – 6553,5 s) Time period for auto off, in miliseconds,\n" +
"0 - Auto off disabled.\n" +
"Default value: 0."
input name: "param5", type: "number", range: "0..65535", defaultValue: "0", required: true,
title: "Parameter No. 5 - Auto off for relay 2. " +
"Default value: 0."
input name: "param6", type: "enum", defaultValue: "0", required: true,
title: "Parameter No. 6 - Sending commands to control devices assigned to 1st association group (key no. 1). " +
"NOTE: Parameter 15 value must be set to 1 to work properly. Default value: 0.",
options: [
["0" : "0 - Commands are sent when device is turned on and off"],
["1" : "1 - Commands are sent when device is turned off"],
["2" : "2 - Commands are sent when device is turned off"]
input name: "param7", type: "enum", defaultValue: "0", required: true,
title: "Parameter No. 7 - Sending commands to control devices assigned to 2nd association group (key no. 2). " +
options: [
input name: "param13", type: "enum", defaultValue: "0", required: true,
title: "Parameter No. 13 - Assigns bistable key status to the device. Default value: 0.",
options: [
["0" : "0 - Device changes status on key status change"],
["1" : "1 - Device status depends on key status: ON when the key is ON"]
input name: "param14", type: "enum", defaultValue: "1", required: true,
title: "Parameter No. 14 - Switch type connector, you may choose between momentary and toggle switches. Default value: 1.",
options: [
["0" : "0 - Momentary switch"],
["1" : "1 - Toggle switch"]
input name: "param15", type: "enum", defaultValue: "0", required: true,
title: "Parameter No. 15 - Operation of the Dimmer and Roller Shutter Controller - enabling this option allows the user to dim lighting/shut roller by associating Dimmer/Roller Shutter Controller and holding or double press of double switch (only mono-stable switch). Default value: 0.",
options: [
["0" : "0 - Dimmer/Roller Shutter Controller control is not active"],
["1" : "1 - Dimmer/Roller Shutter Controller control is active"]
input name: "param16", type: "enum", defaultValue: "1", required: true,
title: "Parameter No. 16 - Saving the state of the device after a power failure. Default value: 1.",
options: [
["0" : "0 - Switch returns to 'off' position"],
["1" : "1 - Switch saves its state before power failure"]
input name: "param30", type: "enum", defaultValue: "3", required: true,
title: "Parameter No. 30 - Relay 1 - Response to General Alarm. Default value: 3.",
options: [
["0" : "0 - Switch does not respond to alarm"],
["1" : "1 - Switch turns on after detecting an alarm"],
["2" : "2 - Switch turns off after detecting an alarm"],
["3" : "3 - Switch flashes after detecting an alarm"]
input name: "param31", type: "enum", defaultValue: "2", required: true,
title: "Parameter No. 31 - Relay 1 - Response to Flood Alarm. Default value: 2.",
options: [
input name: "param32", type: "enum", defaultValue: "3", required: true,
title: "Parameter No. 32 - Relay 1 - Response to Smoke, CO, CO2 Alarm. Default value: 3.",
options: [
input name: "param33", type: "enum", defaultValue: "1", required: true,
title: "Parameter No. 33 - Relay 1 - Response to Temperature Alarm. Default value: 1.",
options: [
input name: "param40", type: "enum", defaultValue: "3", required: true,
title: "Parameter No. 40 - Relay 2 - Response to General Alarm. Default value: 3.",
options: [
input name: "param41", type: "enum", defaultValue: "2", required: true,
title: "Parameter No. 41 - Relay 2 - Response to Flood Alarm. Default value: 2.",
options: [
input name: "param42", type: "enum", defaultValue: "3", required: true,
title: "Parameter No. 42 - Relay 2 - Response to Smoke, CO, CO2 Alarm. Default value: 3.",
options: [
input name: "param43", type: "enum", defaultValue: "1", required: true,
title: "Parameter No. 43 - Relay 2 - Response to Temperature Alarm. Default value: 1.",
options: [
input name: "param39", type: "number", range: "0..65535", defaultValue: "600", required: true,
title: "Parameter No. 39 - Active flashing alarm time. " +
"This parameter allows to set time parameter used in timed modes.\n" +
"[1-65535][ms].\n" +
"Default value: 600."
input name: "paramAssociationGroup1", type: "bool", defaultValue: true, required: true,
title: "The Fibaro Sigle Switch provides the association of three groups.\n\n" +
"1st group is assigned to key no. 1.\n" +
"Default value: true"
input name: "paramAssociationGroup2", type: "bool", defaultValue: true, required: true,
title: "2nd group is assigned to key no. 2.\n" +
input name: "paramAssociationGroup3", type: "bool", defaultValue: false, required: true,
title: "3rd group reports state of devices. Only one device can be associated to this group.\n" +
"Default value: false"
def result = []
def cmd = zwave.parse(description)
if (cmd) {
result += zwaveEvent(cmd)
// log.debug "Parsed ${cmd} to ${result.inspect()}"
} else {
// log.debug "Non-parsed event: ${description}"
return result
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicSet cmd) {
sendEvent(name: "switch", value: cmd.value ? "on" : "off", type: "digital")
def result = []
result << zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:1, commandClass:37, command:2).format()
result << zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:2, commandClass:37, command:2).format()
response(delayBetween(result, 1000)) // returns the result of reponse()
def zwaveEvent(hubitat.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd)
def result = []
def zwaveEvent(hubitat.zwave.commands.multichannelv3.MultiChannelCapabilityReport cmd)
// log.debug "multichannelv3.MultiChannelCapabilityReport $cmd"
if (cmd.endPoint == 2 ) {
def currstate = device.currentState("switch2").getValue()
if (currstate == "on")
sendEvent(name: "switch2", value: "off", isStateChange: true, display: false)
else if (currstate == "off")
sendEvent(name: "switch2", value: "on", isStateChange: true, display: false)
else if (cmd.endPoint == 1 ) {
def currstate = device.currentState("switch1").getValue()
sendEvent(name: "switch1", value: "off", isStateChange: true, display: false)
sendEvent(name: "switch1", value: "on", isStateChange: true, display: false)
def zwaveEvent(hubitat.zwave.commands.multichannelv3.MultiChannelCmdEncap cmd) {
// log.debug(cmd)
def map = [ name: "switch$cmd.sourceEndPoint" ]
def currstate = "off"
if (cmd.destinationEndPoint == 2 ) {
if (cmd.parameter.first() > 180){
if (currstate == "on"){
sendEvent(name: "switch", value: "on", isStateChange: true, display: false)
else if (cmd.parameter.first() == 0){
if (currstate == "off"){
sendEvent(name: "switch", value: "off", isStateChange: true, display: false)
else if (cmd.destinationEndPoint == 1 ) {
/* switch(cmd.commandClass) {
case 32:
if (cmd.parameter == [0]) {
map.value = "off"
if (cmd.parameter == [255]) {
map.value = "on"
createEvent(map)
break
case 37:
map.value = "off"
map.value = "on"
break
def events = [createEvent(map)]
if (map.value == "on") {
events += [createEvent([name: "switch", value: "on"])]
} else {
def allOff = true
(1..2).each { n ->
if (n != cmd.sourceEndPoint) {
if (device.currentState("switch${n}").value != "off") allOff = false
if (allOff) {
events += [createEvent([name: "switch", value: "off"])]
events*/
def zwaveEvent(hubitat.zwave.Command cmd) {
// This will capture any commands not handled by other instances of zwaveEvent
// and is recommended for development so you can see every command the device sends
return createEvent(descriptionText: "${device.displayName}: ${cmd}")
def zwaveEvent(hubitat.zwave.commands.switchallv1.SwitchAllReport cmd) {
// log.debug "SwitchAllReport $cmd"
def refresh() {
def cmds = []
cmds << zwave.manufacturerSpecificV2.manufacturerSpecificGet().format()
cmds << zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:1, commandClass:37, command:2).format()
cmds << zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:2, commandClass:37, command:2).format()
delayBetween(cmds, 1000)
def zwaveEvent(hubitat.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
def msr = String.format("%04X-%04X-%04X", cmd.manufacturerId, cmd.productTypeId, cmd.productId)
//log.debug "msr: $msr"
updateDataValue("MSR", msr)
def poll() {
def cmds = []
def configure() {
// log.debug "Executing 'configure'"
delayBetween([
zwave.configurationV1.configurationSet(parameterNumber:1, configurationValue:[param1.value]).format(),
zwave.configurationV1.configurationSet(parameterNumber:3, configurationValue:[param3.value]).format(),
zwave.configurationV1.configurationSet(parameterNumber:4, configurationValue:[param4.value]).format(),
zwave.configurationV1.configurationSet(parameterNumber:5, configurationValue:[param5.value]).format(),
zwave.configurationV1.configurationSet(parameterNumber:6, configurationValue:[param6.value]).format(),
zwave.configurationV1.configurationSet(parameterNumber:7, configurationValue:[param7.value]).format(),
zwave.configurationV1.configurationSet(parameterNumber:13, configurationValue:[param13.value]).format(),
zwave.configurationV1.configurationSet(parameterNumber:14, configurationValue:[param14.value]).format(),
zwave.configurationV1.configurationSet(parameterNumber:15, configurationValue:[param15.value]).format(),
zwave.configurationV1.configurationSet(parameterNumber:16, configurationValue:[param16.value]).format(),
zwave.configurationV1.configurationSet(parameterNumber:30, configurationValue:[param30.value]).format(),
zwave.configurationV1.configurationSet(parameterNumber:31, configurationValue:[param31.value]).format(),
zwave.configurationV1.configurationSet(parameterNumber:32, configurationValue:[param32.value]).format(),
zwave.configurationV1.configurationSet(parameterNumber:33, configurationValue:[param33.value]).format(),
zwave.configurationV1.configurationSet(parameterNumber:39, configurationValue:[param39.value]).format(),
zwave.configurationV1.configurationSet(parameterNumber:40, configurationValue:[param40.value]).format(),
zwave.configurationV1.configurationSet(parameterNumber:41, configurationValue:[param41.value]).format(),
zwave.configurationV1.configurationSet(parameterNumber:42, configurationValue:[param42.value]).format(),
zwave.configurationV1.configurationSet(parameterNumber:43, configurationValue:[param43.value]).format(),
zwave.associationV2.associationSet(groupingIdentifier:1, nodeId:[zwaveHubNodeId]).format(),
zwave.associationV2.associationSet(groupingIdentifier:2, nodeId:[zwaveHubNodeId]).format(),
zwave.associationV2.associationSet(groupingIdentifier:3, nodeId:[zwaveHubNodeId]).format(),
def updateSingleparam(paramNum, paramValue) {
// log.debug "Updating single Parameter (paramNum: $paramNum, paramValue: $paramValue)"
zwave.configurationV1.configurationSet(parameterNumber: paramNum, ConfigurationValue: paramValue)
* Triggered when Save button is pushed on Preference UI
def updated()
// log.debug "Preferences have been changed. Attempting configure()"
def cmds = configure()
response(cmds)
def on() {
delayBetween([
zwave.switchAllV1.switchAllOn().format(),
zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:1, commandClass:37, command:1, parameter:[255]).format(),
zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:1, commandClass:37, command:2).format(),
zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:2, destinationEndPoint:2, commandClass:37, command:1, parameter:[255]).format(),
zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:2, destinationEndPoint:2, commandClass:37, command:2).format()
], 550)
def off() {
delayBetween([
zwave.switchAllV1.switchAllOff().format(),
zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:1, commandClass:37, command:1, parameter:[0]).format(),
zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:2, destinationEndPoint:2, commandClass:37, command:1, parameter:[0]).format(),
], 550)
def on1() {
delayBetween([
], 500)
def off1() {
delayBetween([
], 500)
def on2() {
delayBetween([
], 500)
def off2() {
delayBetween([
], 500)
I'm having an issue with my FGS-222 when trying to use it with momentary switches.
It seems to behave like a toggle switch - even though I've set param14 to momentary.
The light only stays on as long as I hold down the momentary switch.
I've tried a couple of hard resets (holding B whilst powering on)
I've tried using the updated driver from AdamV.
Everything was working with normal toggle switches - but I'm upgrading the whole house to momentary (and from ST to HE also).
Turning the lights on and off via software works fine, just not with the hardware switches.
I've had no issues whilst updating the FIbaro Dimmer modules to momentary. Just the dual relay switch.
Its driving me nuts.
Any suggestions would be appreciated.
Any thing I can tell by looking at the logs?
I'm getting this error when I use this device with this driver.
This is the relevant portion in the driver.
Yes, I was. So I loaded up the zwave config utility, and changed it manually, since the part of the driver that was throwing erros had only to do with setting configuration.
I now have another issue, whereby debug logs are on, and I cant turn them off. I've changed the device to a type that has logs, disabled logs, but the debug logs remain......
Just so there is a log of it, for some of the people asking me why their driver isn't working, this link has a few modifications I made to Robin's driver so it should work fully in Hubitat and with child devices. I have this in HPM if that helps
Hi @cjcharles ,
I have an FGS-222. I installed the driver that you posted.
I created children, by clicking Create Children,
However , clicking on On and Off on any of the children and parent doesnt move the blind.
I know the relay is working properly as I have switched from using it on Vera to Hubitat and the physical swiches work fine.
Thanks,
Avi
I have added this driver to Hubitat Package Manager and all the updates are there. Can you check with that version first as that may hopefully fix your problem.
EDIT, just seen that this is a live link, rather than raw pasted code, hence should have the live fixes in it already.
What version of Hubitat are you running? (both the hardware version and the software version)
What do you see in Live Logging when you press the buttons?
EDIT2: Just checking you have a roller shutter device or the FGS-222? I think they are different
Thanks @cjcharles .
I have updated the hub.
My Hubitat platform version is 2.3.1.142, HW version: Rev C-7.
I have Fibaro roller shutter FGR-222 (sorry for the spelling mistake with the 's').
I've looked for Fibaro roller shutter device driver when you add a device but haven't found it, also on the new release.
So I added the driver based on the latest code you've posted on this thread.
When I click on any of the controls nothing happens, but the logs seem fine, see below.
I created child devices, and clicked on them as well, but no response.
dev:1042022-06-06 04:44:27.251 pm debugon
dev:1042022-06-06 04:44:24.907 pm debugoff1
dev:1002022-06-06 04:44:15.050 pm debugParsed: [raw:684F0100001801002043E2FF2030E4FF2000, dni:684F, endpoint:01, cluster:0000, size:18, attrId:0001, encoding:20, command:0A, value:43, clusterInt:0, attrInt:1, additionalAttrs:[[value:30, encoding:20, attrId:FFE2, consumedBytes:4, attrInt:65506], [value:00, encoding:20, attrId:FFE4, consumedBytes:4, attrInt:65508]]]
dev:1042022-06-06 04:44:13.346 pm debugoff
dev:1042022-06-06 04:44:02.163 pm debugoff1
dev:1042022-06-06 04:44:02.160 pm debugcomponentOff(0B-ep1)
dev:1072022-06-06 04:44:02.138 pm debugoff()
dev:1042022-06-06 04:43:52.459 pm debugon1
You are using the wrong driver. You should look for the FGR and not the FGS.
Have a test of the code embedded in this post
Thanks Charles and Amit. The driver works!.
I am using this driver which seems to work fine apart from the fact that it does not seem to update in Hubitat when I manually switch the lights on until it is refreshed, does anyone have an answer to this?
That's probably not a driver probably and more that the response from the device is not making it back to the hub.
Can you post a screenshot of your Z-wave details (if on a C-7 or C-8)?
Hi, thanks for the reply, I reset everything and now having trouble getting it to reconnect! Am just in the process of moving from ST and only have one Z Wave & one ZigBee item connected so far but having problems with the FGS so not going to much further until I have sorted this, have migrated 2 other hubs from ST to HE with no real issues.
Have attached screenshot of details.
Hi (again), thanks again for taking the time to reply, after a few resets I finally got the fibaro switch back onto the network and it now seems to be behaving as expected!
I strongly suggest using the version on HPM as it is much more recent and does fix issues with updates sometimes not working. Hopefully that doesn't matter here if you solved it, but just saying it for the future. Compiled here for ease
Thanks for your reply, I am now using HPM for this and my other drivers.
Has anyone been using this driver with HomeAssistant? I am haveing trouble getting the child devices switches to come accross from the C8 using the intergration.
