Here's a driver I developed for my Fakro roof windows.
* Fakro Roof Window driver for Hubitat
* Copyright 2021 Simon J Burke - ScruffySJB
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
***************************Version 1.0******************************************
* Version History
* 2021-09-19: Version 1.0 Initial release
import groovy.transform.Field
metadata {
definition (name: "Fakro Window Driver", namespace: "Scruffy-sjb", author: "Scruffy-SJB") {
capability "Actuator"
capability "WindowShade"
capability "Switch"
capability "Refresh"
capability "Configuration"
capability "Notification"
capability "Sensor"
capability "Health Check"
command "open"
command "close"
command "off"
command "on"
attribute "windowOpen", "String"
attribute "refreshRate", "String"
fingerprint mfr: "0085", deviceType: "0002", deviceId: "0017", inClusters: "0x5E,0x86,0x72,0x5A,0x85,0x59,0x73,0x25,0x26,0x27,0x70,0x71,0x77", deviceJoinName: "Fakro FTP-V, FTU-V Roof Window"
// Chain Execution Speeds
def chain =[:]
chain << ["1" : "Slowest"]
chain << ["2" : "Medium Slow (Default)"]
chain << ["3" : "Medium Fast"]
chain << ["4" : "Fastest"]
// Chain Execution Speeds (Rain Sensor)
def rain =[:]
rain << ["1" : "Slowest"]
rain << ["2" : "Medium Slow (Default)"]
rain << ["3" : "Medium Fast"]
rain << ["4" : "Fastest"]
// Calibration
def calib =[:]
calib << ["1" : "Calibration (Default)"]
calib << ["2" : "Decalibration"]
// Goto Position
def gotop =[:]
gotop << ["1" : "Open to Maximum (Default)"]
gotop << ["2" : "Goto Previous Position"]
//Rates for Poll
def rates = [:]
rates << ["0" : "Disabled"]
rates << ["1" : "Refresh every minute"]
rates << ["5" : "Refresh every 5 minutes (Default)"]
rates << ["10" : "Refresh every 10 minutes"]
rates << ["15" : "Refresh every 15 minutes"]
@Field static Map<String, Map<Short, String>> supervisedPackets = [:]
@Field static Map<String, Short> sessionIDs = [:]
@Field static Map commandClassVersions =
0x01: 2 // z-wave+ info
,0x20: 1 // basic
,0x25: 1 // switch binary
,0x26: 3 // switchMultiLevel
,0x27: 1 // switch all
,0x59: 1 // association group info
,0x5A: 1 // device reset locally
,0x70: 1 // configuration
,0x71: 3 // notification
,0x72: 2 // manufacturer specific
,0x73: 1 // powerlevel
,0x77: 1 // node naming
,0x85: 2 // association
,0x86: 2 // version
,0x98: 1 // security
preferences {
//parameter 7
input name: "chainExecutionSpeed", type: "enum", options: chain, description: "Select chain execution speed", title: "Window Execution Speed", range: 1..4, defaultValue: 2, required: true
//parameter 8
input name: "rainExecutionSpeed", type: "enum", options: rain, description: "Select chain execution speed (rain)", title: "Window Execution Speed (Rain)", range: 1..4, defaultValue: 2, required: true
//parameter 12
input name: "calibration", type: "enum", options: calib, description: "Select calibration", title: "Calibration", range: 1..2, defaultValue: 1, required: true
//parameter 13
input name: "gotoPosition", type: "enum", options: gotop, description: "Select position", title: "Go to Position", range: 1..2, defaultValue: 1, required: true
//parameter 15
input name: "ventilation", type: "number", description: "", title: "Close after set time (Minutes)", range: "0..120", defaultValue: 0, required: false
input name: "refreshRate", type: "enum", title: "Refresh rate", options: rates, description: "Select refresh rate", defaultValue: "5", required: false
// parse events into attributes
// log.debug "Parsing '${description}'"
def result = []
if (description.startsWith("Err 106")) {
state.sec = 0
result = createEvent(descriptionText: description, isStateChange: true)
else {
def cmd = zwave.parse(description,[0x75:1])
if (cmd) {
result += zwaveEvent(cmd)
// log.debug "Parsed ${cmd} to ${result.inspect()}"
} else {
log.debug "Non-parsed event: ${description}"
return result
def zwaveEvent(hubitat.zwave.commands.switchmultilevelv3.SwitchMultilevelReport cmd){
log.info "Report Received : Window open ${cmd.value}%"
sendEvent(name: "lastCheckin", value: new Date())
windowEvents(cmd)
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicReport cmd) {
// log.debug "Basic report received - cmd.value = $cmd.value"
windowEvents(cmd)
private void windowEvents(hubitat.zwave.Command cmd) {
def position = cmd.value
if (position > 0) {
sendEvent(name: "windowOpen", value: "yes")
switchValue = "on"
log.info "$device.displayName window is open"
} else {
sendEvent(name: "windowOpen", value: "no")
switchValue = "off"
log.info "$device.displayName window is closed"
sendEvent(name: "position", value: position, unit: "%")
sendEvent(name: "switch", value: switchValue)
log.info "$device.displayName position is $position"
log.info "$device.displayName switch is $switchValue"
def zwaveEvent(hubitat.zwave.commands.associationv2.AssociationReport cmd) {
def result = []
if (cmd.nodeId.any { it == zwaveHubNodeId }) {
result << sendEvent(descriptionText: "$device.displayName is associated in group ${cmd.groupingIdentifier}")
} else if (cmd.groupingIdentifier == 1) {
// We're not associated properly to group 1, set association
result << sendEvent(descriptionText: "Associating $device.displayName in group ${cmd.groupingIdentifier}")
result << response(zwave.associationV1.associationSet(groupingIdentifier:cmd.groupingIdentifier, nodeId:zwaveHubNodeId))
log.info "Report Received : $cmd"
result
def zwaveEvent(hubitat.zwave.commands.notificationv3.NotificationReport cmd) {
def events = []
switch (cmd.notificationType) {
// case 8:
// processPowerMgtNot(cmd)
// break
// case 9:
// processSystemNot(cmd)
// break
log.info "Notification Report : $cmd"
def zwaveEvent(hubitat.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) { // Devices that support the Security command class can send messages in an encrypted form; they arrive wrapped in a SecurityMessageEncapsulation command and must be unencapsulated
log.debug "raw secEncap $cmd"
state.sec = 1
def encapsulatedCommand = cmd.encapsulatedCommand ([0x20: 1, 0x80: 1, 0x70: 1, 0x72: 1, 0x31: 5, 0x26: 3, 0x75: 1, 0x40: 2, 0x43: 2, 0x86: 1, 0x71: 3, 0x98: 2, 0x7A: 1 ])
if (encapsulatedCommand) {
log.warn "Encapsulated command extracted sucessfully"
return zwaveEvent(encapsulatedCommand)
} else {
log.warn "Unable to extract encapsulated cmd from $cmd"
createEvent(descriptionText: cmd.toString())
def zwaveEvent(hubitat.zwave.Command cmd) {
def map = [ descriptionText: "${device.displayName}: ${cmd}" ]
log.warn "mics zwave.Command - ${device.displayName} - $cmd"
sendEvent(map)
def zwaveEvent(hubitat.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
if (cmd.manufacturerName) { updateDataValue("manufacturer", cmd.manufacturerName) }
if (cmd.productTypeId) { updateDataValue("productTypeId", cmd.productTypeId.toString()) }
if (cmd.productId) { updateDataValue("productId", cmd.productId.toString()) }
if (cmd.manufacturerId){ updateDataValue("manufacturerId", cmd.manufacturerId.toString()) }
def zwaveEvent(hubitat.zwave.commands.zwaveplusinfov2.ZwaveplusInfoReport cmd) {
if (cmd.zWaveplusNodeType) { updateDataValue("Z-Wave+NodeType", cmd.zWaveplusNodeType.toString()) }
if (cmd.zWaveplusRoleType) { updateDataValue("Z-Wave+RoleType", cmd.zWaveplusRoleType.toString()) }
if (cmd.zWaveplusVersion){ updateDataValue("Z-Wave+Version", cmd.zWaveplusVersion.toString()) }
def zwaveEvent(hubitat.zwave.commands.configurationv2.ConfigurationReport cmd ) {
// log.info "Configuration Report Received : $cmd"
def events = []
switch (cmd.parameterNumber) {
case 7:
events << processParam7(cmd)
break
case 8:
events << processParam8(cmd)
break
case 12:
events << processParam12(cmd)
break
case 13:
events << processParam13(cmd)
break
case 15:
events << processParam15(cmd)
break
default:
log.debug "Parameter $cmd received"
break
def zwaveEvent(hubitat.zwave.commands.versionv1.VersionReport cmd) {
log.info "Version Report: $cmd"
def zWaveLibraryTypeDisp = String.format("%02X",cmd.zWaveLibraryType)
def zWaveLibraryTypeDesc = ""
switch(cmd.zWaveLibraryType) {
case 1:
zWaveLibraryTypeDesc = "Static Controller"
break
case 2:
zWaveLibraryTypeDesc = "Controller"
break
case 3:
zWaveLibraryTypeDesc = "Enhanced Slave"
break
case 4:
zWaveLibraryTypeDesc = "Slave"
break
case 5:
zWaveLibraryTypeDesc = "Installer"
break
case 6:
zWaveLibraryTypeDesc = "Routing Slave"
break
case 7:
zWaveLibraryTypeDesc = "Bridge Controller"
break
case 8:
zWaveLibraryTypeDesc = "Device Under Test (DUT)"
break
case 0x0A:
zWaveLibraryTypeDesc = "AV Remote"
break
case 0x0B:
zWaveLibraryTypeDesc = "AV Device"
break
default:
zWaveLibraryTypeDesc = "N/A"
def zWaveVersion = String.format("%d.%02d",cmd.zWaveProtocolVersion,cmd.zWaveProtocolSubVersion)
def firmwareLevel = String.format("%d.%02d",cmd.firmware0Version,cmd.firmware0SubVersion)
log.info "Z-Wave type is $zWaveLibraryTypeDesc - Z-Wave Version is $zWaveVersion - Device Firmware Level is $firmwareLevel"
def configure() {
state.clear() // Clear all previous states
unschedule()
def cmds = []
cmds << zwave.configurationV1.configurationSet(configurationValue: chainExecutionSpeed == "1" ? [0x01] : chainExecutionSpeed == "2" ? [0x02] : chainExecutionSpeed == "3" ? [0x03] : chainExecutionSpeed == "4" ? [0x04] : [0x02], parameterNumber:7, size:1, scaledConfigurationValue: chainExecutionSpeed == "1" ? 0x01 : chainExecutionSpeed == "2" ? 0x02 : chainExecutionSpeed == "3" ? 0x03 : chainExecutionSpeed == "4" ? 0x04 : 0x02)
cmds << zwave.configurationV1.configurationSet(configurationValue: chainExecutionSpeed == "1" ? [0x01] : rainExecutionSpeed == "2" ? [0x02] : rainExecutionSpeed == "3" ? [0x03] : rainExecutionSpeed == "4" ? [0x04] : [0x02], parameterNumber:8, size:1, scaledConfigurationValue: rainExecutionSpeed == "1" ? 0x01 : rainExecutionSpeed == "2" ? 0x02 : rainExecutionSpeed == "3" ? 0x03 : rainExecutionSpeed == "4" ? 0x04 : 0x02)
cmds << zwave.configurationV1.configurationSet(configurationValue: calibration == "1" ? [0x01] : calibration == "2" ? [0x02] : [0x01], parameterNumber:12, size:1, scaledConfigurationValue: calibration == "1" ? 0x01 : calibration == "2" ? 0x02 : 0x01)
cmds << zwave.configurationV1.configurationSet(configurationValue: gotoPosition == "1" ? [0x01] : gotoPosition == "2" ? [0x02] : [0x01], parameterNumber:13, size:1, scaledConfigurationValue: gotoPosition == "1" ? 0x01 : gotoPosition == "2" ? 0x02 : 0x01)
cmds << zwave.configurationV1.configurationSet(parameterNumber:15, scaledConfigurationValue: ventilation.toInteger())
cmds << zwave.sensorMultilevelV5.sensorMultilevelGet(sensorType:1, scale:1)
cmds << zwave.switchMultilevelV3.switchMultilevelGet()
cmds << zwave.configurationV1.configurationGet(parameterNumber:7)
cmds << zwave.configurationV1.configurationGet(parameterNumber:8)
cmds << zwave.configurationV1.configurationGet(parameterNumber:12)
cmds << zwave.configurationV1.configurationGet(parameterNumber:13)
cmds << zwave.configurationV1.configurationGet(parameterNumber:15)
cmds << zwave.manufacturerSpecificV1.manufacturerSpecificGet()
cmds << zwave.versionV1.versionGet()
cmds << zwave.zwaveplusInfoV2.zwaveplusInfoGet()
sendEvent(name: "configuration", value: "sent", displayed: true)
log.info "Configuration sent"
secureSequence(cmds)
def updated() {
if (!state.updatedLastRanAt || new Date().time >= state.updatedLastRanAt + 2000) {
state.updatedLastRanAt = new Date().time
unschedule(refresh)
unschedule(poll)
runIn (01, configure)
sendEvent(name: "refreshRate", value: refreshRate)
switch(refreshRate) {
case "1":
runEvery1Minute(poll)
log.info "Refresh Scheduled for every minute"
break
case "15":
runEvery15Minutes(poll)
log.info "Refresh Scheduled for every 15 minutes"
break
case "10":
runEvery10Minutes(poll)
log.info "Refresh Scheduled for every 10 minutes"
break
case "5":
runEvery5Minutes(poll)
log.info "Refresh Scheduled for every 5 minutes"
break
case "0":
runIn(60*60*24, 'poll') // Must poll at least once per day
log.info "Refresh off"}
else {
log.warn "update ran within the last 2 seconds"
// PING is used by Device-Watch in attempt to reach the Device
def ping() {
refresh()
//Refresh
def refresh() {
def cmds = []
log.trace "refresh"
cmds << zwave.basicV1.basicGet() // get mode (basic)
cmds << zwave.sensorMultilevelV1.sensorMultilevelGet() // get temp
cmds << zwave.switchMultilevelV3.switchMultilevelGet() // position
secureSequence (cmds)
def secure(hubitat.zwave.Command cmd) {
// state.sec = 1
if (state.sec) {
// log.debug "Seq secure - $cmd"
zwave.securityV1.securityMessageEncapsulation().encapsulate(cmd).format()
// zwaveSecureEncap(supervisedEncap(cmd).format())
else {
// log.debug "Seq unsecure- $cmd"
cmd.format()
def secureSequence(cmds, delay=1500) {
//log.debug "SeSeq $commands"
delayBetween(cmds.collect{ secure(it) }, delay)
private currentDouble(attributeName) {
if(device.currentValue(attributeName)) {
return device.currentValue(attributeName).doubleValue()
else {
return 0d
//chainExtensionSpeed
private processParam7(cmd) {
def setValue
if (cmd.scaledConfigurationValue == 1) {
setValue = "1 - Slowest"
if (cmd.scaledConfigurationValue == 2) {
setValue = "2 - Medium Slow"
if (cmd.scaledConfigurationValue == 3) {
setValue = "3 - Medium Fast"
if (cmd.scaledConfigurationValue == 4) {
setValue = "4 - Fastest"
log.info "Configuration Report - Chain Extension Speed: ${setValue}"
//rainExtensionSpeed
private processParam8(cmd) {
def setValue
log.info "Configuration Report - Chain Extension Speed (Rain): ${setValue}"
//calibration
private processParam12(cmd) {
def setValue
setValue = "1 - Calibrated"
setValue = "2 - Out of Calibration"
setValue = "3 - Encoder Error"
log.info "Configuration Report - Calibration: ${setValue}"
//gotoPosition
private processParam13(cmd) {
def setValue
setValue = "1 - Goto Maximum"
setValue = "2 - Goto Previous Position"
log.info "Configuration Report - Goto Position: ${setValue}"
//ventilation
private processParam15(cmd) {
def setValue
// setValue = cmd.scaledConfigurationValue.ToString
log.info "Configuration Report - Ventilation - Close after ${cmd.scaledConfigurationValue} minutes"
def poll() {
log.info "Polling...."
def cmds = []
cmds << zwave.basicV1.basicGet() // get basic
void debugOff() {
log.warn("Disabling debug logging")
device.updateSetting("enableDebug", [value:"false", type:"bool"])
void zwaveEvent(hubitat.zwave.commands.supervisionv1.SupervisionGet cmd) {
hubitat.zwave.Command encapCmd = cmd.encapsulatedCommand(commandClassVersions)
log.debug "Supervision cmd received"
if (encapCmd) {
zwaveEvent(encapCmd)
sendHubCommand(new hubitat.device.HubAction(zwaveSecureEncap(zwave.supervisionV1.supervisionReport(sessionID: cmd.sessionID, reserved: 0, moreStatusUpdates: false, status: 0xFF, duration: 0).format()), hubitat.device.Protocol.ZWAVE))
void zwaveEvent(hubitat.zwave.commands.supervisionv1.SupervisionReport cmd) {
log.debug "supervision report for session: ${cmd.sessionID}"
if (!supervisedPackets."${device.id}") { supervisedPackets."${device.id}" = [:] }
if (supervisedPackets["${device.id}"][cmd.sessionID] != null) { supervisedPackets["${device.id}"].remove(cmd.sessionID) }
unschedule(supervisionCheck)
void supervisionCheck() {
// re-attempt once
/* if (!supervisedPackets."${device.id}") { supervisedPackets."${device.id}" = [:] }
supervisedPackets["${device.id}"].each { k, v ->
log.debug "re-sending supervised session: ${k}"
sendHubCommand(new hubitat.device.HubAction(zwaveSecureEncap(v), hubitat.device.Protocol.ZWAVE))
supervisedPackets["${device.id}"].remove(k)
Short getSessionId() {
Short sessId = 1
if (!sessionIDs["${device.id}"]) {
sessionIDs["${device.id}"] = sessId
return sessId
} else {
sessId = sessId + sessionIDs["${device.id}"]
if (sessId > 63) sessId = 1
return sessId
hubitat.zwave.Command supervisedEncap(hubitat.zwave.Command cmd) {
if (getDataValue("S2")?.toInteger() != null) {
hubitat.zwave.commands.supervisionv1.SupervisionGet supervised = new hubitat.zwave.commands.supervisionv1.SupervisionGet()
supervised.sessionID = getSessionId()
log.debug "new supervised packet for session: ${supervised.sessionID}"
supervised.encapsulate(cmd)
supervisedPackets["${device.id}"][supervised.sessionID] = supervised.format()
runIn(5, supervisionCheck)
return supervised
} else {
return cmd
void zwaveEvent(hubitat.zwave.commands.switchmultilevelv2.SwitchMultilevelStopLevelChange cmd) {
logDebug("SwitchMultilevelStopLevelChange: $cmd")
sendHubCommand(
new hubitat.device.HubAction(zwave.switchMultilevelV1.switchMultilevelGet().format(),
def on() {
log.trace("on")
open()
def off() {
log.trace("off")
close()
def open() {
log.trace("Open")
state.switchState = "open"
setLevel(255)
def close() {
log.trace("Close")
state.switchState = "closed"
setLevel(0)
def setLevel(level) {
log.trace "SetPosition value:${level}"
def cmds = []
cmds << zwave.basicV1.basicSet(value: level)
String startLevelChange(direction){
Integer upDown = direction == "down" ? 1 : 0
return secure(zwave.switchMultilevelV1.switchMultilevelStartLevelChange(upDown: upDown, ignoreStartLevel: 1, startLevel: 0))
List<String> stopLevelChange(){
return [
secure(zwave.switchMultilevelV1.switchMultilevelStopLevelChange())
,"delay 200"
,secure(zwave.basicV1.basicGet())
